MSH Brain FBL Unit MSH Brain Support Forum |
03-29-2014, 10:44 PM | #1 (permalink) |
tail authority
in my goblin everything was good until today i was making a invert and i loose tail authority
and then the tail hold again what could be that |
03-30-2014, 02:03 AM | #2 (permalink) |
try going up on the gain first go up a bit fly it around and so on.
Trex 500 ESP(DFC) Ikon, Radix] [Goblin 700 CompBK, 4525, Ikon, Helix 695 ] [Rave ENV Nitro O.S 105-R,Ikon,Cyclone] Rave ENV Electric]Scorpion 4525,Ikon, Outrage, SAB [Goblin 500] Ikon Rails 516 ]Blade 180 CFX]Goblin 570 12S Xnova |
03-30-2014, 09:01 AM | #3 (permalink) |
But in the tx only because i set the gain in the software
03-30-2014, 02:11 PM | #4 (permalink) |
You can change the gain in the transmitter at the field as well it will work
Sent from my SCH-I605 using Tapatalk
03-30-2014, 04:23 PM | #5 (permalink) |
If you didn't change the setting in the advanced menu, you can still adjust your gain through your tx. And when you get done and comfortable with it, then go into the advanced menu , under the receiver section and change it so the software has it locked in. and use your gyro switch for something else .
Atom500(FBL)., Gaui x4II (FBL) ;Trex450 sport (FBL). All with Ikon fbl gyro. AMA#1019423. Tony . |
