Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Old 04-01-2012, 05:38 PM   #381 (permalink)
Yes Tom One Guy (Me) told you it was just over 12mm wide because it is.
Why do you not believe me? you could always just measure your belt.. that's right you dont have a Goblin.. you are just an expert on them that accuses other owners of not having one.
Henseleit TDR Xera Vbar gov, MA whiplash YS120 VBar gov, Rex700N VBar gov, Stretch 450 Pro 6s Vbar , FPV Quad, Planks a plenty, Turbine Eurosport.
Nutbag is offline        Reply With Quote Quick reply to this message
Old 04-01-2012, 05:52 PM   #382 (permalink)
Cool it mate and try to remember the 'Fun, Learning, Friendship and Mutual Respect' that this forum stands for.
I've built, setup, and flown one for a local buddy who is now on holidays so no I cannot measure it right now. When I built it I compared the belt to one of my old 9mm Ion-2x belts and I though it looked about the same, but not 100% sure now (old age memory, lol).
Just wanted confirmation so that we are all clear what the actual widths are since some may want to look at specing out local supplies of belts and pulley's.
Thanks for the picture showing the measurement nutbag. I'm sure you are correct, it's a 12mm belt not 9mm as stated earlier by SAB admin. Probably explains why the Goblin belt drive appears to be heaps better than my old Ion-x2 belt drive which was only 9mm (just measured again myself). Belt life should be a lot higher too. All good news imho.
Cheers,
TomC
Blade nQX,mCPX-BL,450x,500x Bell 222(bd3sx),550x(bd3sx)
TT X50E, 10s, bd3sx
Now also a FPV addict; Quads and Planes (soon to try heli's!)
TomC is offline        Reply With Quote Quick reply to this message
Old 04-01-2012, 06:09 PM   #383 (permalink)
Thanks for reporting my post Tom...
First one in over 5 years on the forum
Old 04-01-2012, 06:37 PM   #384 (permalink)
Default Lame
TDR, Srimok N x 2, Banshee 31, Dune!
jhunter is offline        Reply With Quote Quick reply to this message
Old 04-02-2012, 02:49 AM   #385 (permalink)
Only one in 5 year, then you're not talking from the heart mate, lol! HF Moderators take the action, not me btw. I've had lots worse squabbles (incl. reports) over my last 7 years with HF and in all cases we have ended up as good heli-mates. Hope the same works out here.
Many thanks again for your picture showing the true motor pulley belt width (12mm). It explains a lot why the Goblin belt system works so much better than my old Ion-2x (9mm) belted system. Thanks
Cheers,
TomC
TT X50E, 10s, bd3sx
Old 04-03-2012, 03:33 AM   #386 (permalink)
the parts list says 9mm width for the main drive belt
http://www.goblin-helicopter.com/sho...ROUP_rev01.pdf
So perhaps this is the redesign in drive train why it was delayed?
GAUI X5 with Eznov Neuron and T10J
DannyvG is offline        Reply With Quote Quick reply to this message
Old 07-05-2013, 11:39 AM   #387 (permalink)
Default main gear slop on the shaft
is this right ?main gear is louse on the shaft
wperry38 is offline        Reply With Quote Quick reply to this message
Old 07-05-2013, 12:49 PM   #388 (permalink)
HF MR Support
Helical main gear and pinion should not have any up or down movement, if you have movement you need to use the shims that come in the kit to remove any play.
clouseau is offline        Reply With Quote Quick reply to this message
Old 07-06-2013, 02:28 AM   #389 (permalink)
Originally Posted by goblinhelicopter View Post
We will answer technical support questions in this thread.
Please post technical questions only.
Goblin Helicopter
Is it normal for the motor to become hot after flight? My 630's scorpion becomes too hot to keep my hand on after a flight.
Life holds no guarantees. You wannna play? You gotta pay!
Heli-max Novus N200. Stock & custom Blade CP Pro2's, Blade SR's, Blade 230s. Blade AH-64 Apache & Black Hawk. Walkera HM 4F200LM. Goblins 630 & 770. Vario Bell 47GII.
Nade is offline        Reply With Quote Quick reply to this message
Old 07-06-2013, 02:51 PM   #390 (permalink)
your hypothesis is incorrect:
Thickness Vertical Fin: 2.5 mm
Motor Belt is 9 mm wide
Tail belt is 6 mm wide
Originally Posted by TomC View Post
Can someone confirm that these belt widths are correct. Had one guy tell me that his motor belt was 12mm wide? Thanks.
Cheers,
TomC
Old post, but anyway, my G700 belt is a Gates 240-3MGT-13
13mm wide.
Not a standard width for Gates - their closest match is a 240-3MGT-15
SAB Goblin 700 - CCHV120 - BEC Pro - AR7200BX - TM1000 / 450 Pro - GT5 - Tarot head / T-Rex 550 V2.1 - CC100 - BEC Pro - AR7200BX - TM1000 /
1004ron is offline        Reply With Quote Quick reply to this message
Old 11-01-2015, 06:17 AM   #391 (permalink)
Goblin Helicopter
Hello,
I noticed on my 630 that the tail blade has a few degrees of rotating play on it. It moves back and forth with no belt movement. Seems odd! Apparently I have a worn part?
