Old 03-28-2009, 01:03 AM   #161 (permalink)
Cool,
Thanks... Any particular brand? I have an extra koolflightsystems 3-5 amp "Ultimate BEC" in my box. Will that really be adequate? Because I do have a Durallite complete separate battery regulator system which I KNOW would be overkill but very reliable. I'm just concerned about the extra weight.
Are most guys just running a separate BEC using the main flight pack?
HoverOver is offline        Reply With Quote Quick reply to this message
Old 03-28-2009, 02:20 AM   #162 (permalink)
The SportBec is made by dimension engineering
Mcik
aussiemick is offline        Reply With Quote Quick reply to this message
Old 03-28-2009, 04:57 PM   #163 (permalink)
ccbec and a hv85 for me
Jeff
500cf, cchv85, ccbec, 5452mg, 7703d, 3400g, ....>400 flights > 5 crashes make an offer!
600N Sport, os50hyper, mp5sb, 8717, thunder tiger 600mm, solid g, 8900g, 7100r
Compass K3D, os50hyper, outrage, 8717, 8900, spartan, 8900, radix, 7100r
rupps5 is offline        Reply With Quote Quick reply to this message
Old 03-28-2009, 10:07 PM   #164 (permalink)
Perfect! So it sounds like everyone is either using the stock BEC (built in the Align ESC) or a separate BEC when stepping with an after-market ESC. A completely separate system for the electronics is just too overkill (not to mention, heavy)!
Old 03-29-2009, 10:21 AM   #165 (permalink)
Probably been answered before, but I have not found it. The average flyer, can expect how many recharges for a Trex 500 battery before it dies. I realize this is all realtive but an average would be helpful.
mentor34 is offline        Reply With Quote Quick reply to this message
Old 04-02-2009, 02:08 PM   #166 (permalink)
What best ESC to use with Scorpion 1400KV??Is necessary use BEC(what bec cc sport bec...)??
I have doubt what motor i buy Medusa 1600KV v2 or Scorpion 1400KV what you think is best??What motor most powerful for trex 500??
Trex 700E 12s Pro DFC
Trex 600E 10s with Vbar
Trex 450 Pro with Vbar
Trex 250 with scorpion 3600Kv
VDFS is offline        Reply With Quote Quick reply to this message
Old 04-02-2009, 02:09 PM   #167 (permalink)
I use the CC 45HV and CCBEC.
--Kevin
jones007 is offline        Reply With Quote Quick reply to this message
Old 04-02-2009, 02:16 PM   #168 (permalink)
What best motor you suggest to run with 6s(I like my heli insane power)??
Old 04-05-2009, 10:41 AM   #169 (permalink)
Default TREX 500 over heats on dual 2500 Evo lites
I recently have purchased a TREX 500 ESP, and built it as per Bob's excellent videos.
The stock BEC is configure as per the video on mid timing.
I am using a pair of Evo Lite 2500 3S 11.1v packs wired in series to get 22.2v out of them.
After performing some hovering in the garden, I landed the heli and noticed the motor was V hot. The BEC was V hot, and both of my batteries where V hot too.
The throttle curve was at around 80% at mid stick, and 90 at 3/4. I never went above these values as I was just hovering.
After I let the batteries cool down, I charged the first one fine, but the second said there was an open circuit while charging.
I have since used the battery in my 450, and charged it again without any problems.
Does anyone know why it got so hot in the first place?
Also does anyone else use this configuration with the packs?
Cheers in advance..
TREX 450SE- HS56 Servos, GY401 and S9650
TREX 500 ESP - Align DS510 Servos, GY401 and Align DS520
idea72 is offline        Reply With Quote Quick reply to this message
Old 04-06-2009, 04:36 PM   #170 (permalink)
Scorpion 3026-1210 on 8s 2200mah, INSANE peaks 1700 watts!
Really really really insane, 12s and same motor or the 1000kv, peaks 2700 watts.
Trex 450 Pro Stretch Neu Scorp 1630, 8s, CC30HV. Mini V
Trex 700 DFC V-bar
Helipsyko is offline        Reply With Quote Quick reply to this message
Old 04-06-2009, 06:50 PM   #171 (permalink)
Now i to me do not compense run with 8s or 12s because i have 2 packs 6s goods but in future i think run with 8s or 12s.Now i pretend to buy 1400KV because some guys tell me it is insane.Esc i will buy CC80 with SportBec.You think compense more i buy CC85HV with SportBec to run with 1400KV with this in future i have a ESC to run with more cells??
Old 04-06-2009, 06:55 PM   #172 (permalink)
A HV gives more options, I use hv45 for the 8s, but it is no good for the 6s 1400.
compense=?
Trex 700 DFC V-bar
Old 04-06-2009, 08:27 PM   #173 (permalink)
But CC85HV in my case to run with 1400KV is a better choice compared with CC80??Tell me what is more vantage i buy CC80 or CC85HV??
Old 04-08-2009, 11:16 PM   #174 (permalink)
Cool Trex 500 on A123
Has snyone tried these packs and what kind of results and setup did youu have?
PawBear is offline        Reply With Quote Quick reply to this message
Old 05-02-2009, 11:07 AM   #175 (permalink)
Isn't the CC HV-85 heavy compared to the CC80 ?? I think the HV-85 weighs in at 119g vs 60g for the CC80................
Airscrew is offline        Reply With Quote Quick reply to this message
Old 05-02-2009, 04:46 PM   #176 (permalink)
Excelent point! 60 grams worth of MAH in the battery would be much better served!
BobOD is offline        Reply With Quote Quick reply to this message
Old 05-04-2009, 12:09 PM   #177 (permalink)
about how long should I be setting my timer for stock 500 with 13T and zippy 2650 20C ?
(just hovering and starting to learn small foward flight)
BigStatiK is offline        Reply With Quote Quick reply to this message
Old 05-04-2009, 12:48 PM   #178 (permalink)
I imagine 6min would be a good starting point. Check how much you put back into the battery, try not to exceed 80% capacity discharge
Russell Bear is offline        Reply With Quote Quick reply to this message
Old 05-04-2009, 12:51 PM   #179 (permalink)
thanks. will do.
Old 05-05-2009, 11:22 PM   #180 (permalink)
Just thought I'd post my Flasher 500 power setup. This is the new version (100% T-Rex compatible) with the torque tube upgrade.
Motor: AKE ICECold 500R1700TF (1700kv)
Pinion: 13t
ESC: HobbyWing Platinum 80A
Battery: 1st run - 2x 3s 2150 Rhino 20C
2nd run 6s 2650 FlightMax 20C
ESC setup governed to 2675rpm. I haven't verified the RPM, I haven't got the optical sensor working.
The video is of the 2nd run.
http://www.youtube.com/watch?v=y4r10fk89lk
bwoollia is offline        Reply With Quote Quick reply to this message
