Go Back   HeliFreak > R/C Electronics Support > HobbyWing ESC's
HobbyWing ESC's HobbyWing ESC Support
Like Tree1Likes
Old 10-10-2016, 08:11 PM   #21 (permalink)
So... any workaround for the tail kick with external vbar gov?
Synergy E7se | Mikado 690SX V2 | Goblin Black Thunder T | Gaui X3 | brushless mCPx
VControl | MKS & KST Servos | Pulse
Heli-X8 | Lynx Team Pilot
prokyon is offline        Reply With Quote Quick reply to this message
Old 10-10-2016, 08:13 PM   #22 (permalink)
Only one I know of is to give the blades a spin by hand,the kick isn't so hard if you take off from grass
waheed1998 is offline        Reply With Quote Quick reply to this message
Old 10-10-2016, 08:38 PM   #23 (permalink)
Right, I just read the V4 manuals, it seems that all governor settings have no effect with Heli Linear mode. Any VBar setting to make the kick not as harsh? Or anything?
Old 10-10-2016, 08:44 PM   #24 (permalink)
It almost sounds like bumping up Start-up Time option should do the trick, since in Heli Linear mode the ESC _should_ let its internal governor handle the startup.
Old 02-26-2017, 01:30 AM   #25 (permalink)
The current "fix" is to run heli linear and disable AFW on the V4 stuff. Not sure on yours. This stuff is discussed is the HW forum at length.
Goblin 700RAW | 580 RAW | Rush 750 V2 Stretch | Synergy 516 | Align TB70 | OMP M4 | Vcontrol touch
Citizen 709
www.mad4heli.com we ship worldwide
higham83 is offline        Reply With Quote Quick reply to this message
Old 02-26-2017, 07:26 AM   #26 (permalink)
Their is a setting in vbar I think it spool up rate. I changed mine on vbar from 3 to 2 solved it for me on hobbywing 60a v4
tshelby73 is offline        Reply With Quote Quick reply to this message
Old 03-06-2017, 09:50 PM   #27 (permalink)
So I had a chance to test this setting change to eliminate the tail kick on start up.
This is with a HW 200 V4 & V-Bar NEO running pro & rescue.
I turned OFF Active Freewheeling and lowered the NEO spool up from 3 to 2.
It did help but there was still a 90 degree tail spin on a hardwood floor. For reference, the spin used to be 180+ degrees so the change did help.
I did NOT lower the V-Control "Low Limit - Motor off" from 0 to -15 though so I'll try that next.
Old 03-07-2017, 05:49 AM   #28 (permalink)
Might try using 1 also. No problems with my 60a v4 but talking different amounts of torque also. I actually set mine back to 3 with a slight 10 degree kick so it would spool up faster. Will see soon when my neo gets here for my protos max. Have a 130hv v4 on it.
Old 03-07-2017, 11:59 AM   #29 (permalink)
That's the other thing I have to take into consideration. I have autorotation bail out and I think changing that spool up setting will affect how fast the heli spools back up auto bail out.
Normally, it goes from 20% to set HS within 3-4 seconds.
That said, I will try the spoolup setting at 1 just to see how it is.
Old 03-07-2017, 04:02 PM   #30 (permalink)
Dave just to verify you are using heli linear not airplane correct?
Old 03-07-2017, 07:06 PM   #31 (permalink)
Yes, I'm using heli linear.
I have seen a few posts of guys having luck in airplane mode but it seems like the vast majority say heli linear is what works.
Old 03-07-2017, 08:54 PM   #32 (permalink)
Ok just checking if you were using airplane I think kick is unavoidable
Old 03-07-2017, 09:42 PM   #33 (permalink)
The only 2 things left to try are:
1) lower the NEO spoolup from 2 to 1
2) lower the Low Limit Motor off on V-Control from 0 to -15
If neither of those work, I'll have live with the kick until Hobbywing comes out with a firmware upgrade that finally fixes the issue.
If they don't, I will be looking at the new Scorp.
Old 03-08-2017, 02:34 AM   #34 (permalink)
I lost hope that this will ever happen. The topic was discussed over and over for a while, yet there is no official word from HW.
Michael
Kraken 700 & 580; Oxy 4 MAX; Oxy 3 TE18
mulchi is offline        Reply With Quote Quick reply to this message
Old 03-11-2017, 10:18 PM   #35 (permalink)
I did maiden today hobbywing 130 v4 scorpion 4525-520 in protos max. Hobbywing settings lvc disabled, afw off, heli linear.
First spoolup with vbar neo had tail kick with neo spoolup at 3. Lowered to 2 and kick went away. Hobbywing throttle endpoint set with other esc in vcontrol 100 -100.
Old 03-12-2017, 11:49 PM   #36 (permalink)
I'm curious (just to try to gauge the severity) was your heli on grass or blacktop/cement?
My test was on a shiny, smooth, waxed hardwood (indoor) basketball court. The heli does not have rubber skid nuts.
That combination makes it about as slippery as it can get.
I'm pretty sure if I was on grass, I would have much less, if any kick on the 2 setting.
Old 03-13-2017, 05:53 AM   #37 (permalink)
I was on a paved runway. Also at spool up rate of 2 getting to full headspeed was noticeably longer than my castle was.
Old 03-13-2017, 02:12 PM   #38 (permalink)
Ok.
I don't plan on any testing for a few weeks (still cold, 4+ inches of snow) but as soon as it gets nice again, I'll try the other setting(s).
Old 04-09-2017, 11:07 PM   #39 (permalink)
So I was finally able to try the lower NEO spoolup setting of 2 on grass.
There wasn't enough torque to spin the heli.
I haven't tried autorotation bail-out to see how the setting of 2 effects the rapid spoolup but if it's not too bad, think I can live with it at 2. I did NOT change the throttle value to -15 as some have done. I'm not sure what difference it would make.
That said, I'd still like to see Hobbywing release a firmware update that solves it.
Old 04-10-2017, 06:22 AM   #40 (permalink)
I heard their might be a new update but haven't checked myself. More than likely doesn't address the issue though or we might have heard about it already.
