Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600 PRO Class Electric Helicopters
600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 07-03-2013, 03:52 PM   #1 (permalink)
Default Would this cause a tail wag?
Hey everyone,
So I just rebuilt my 600 after an unfortunate BEC failure, and now there is a slight wag, that just won't go away.
The tail only goes back and forth a few inches, and I have changed the gain all over the map with no effect on it.
I lowered the governor game on the castle ESC to low, and that helped a little but its still there.
Upon close inspection of the tail one grip is a little loose. I can pull the grip straight out away from the hub a little bit.
I bet that this is causing the vibration in the tail, I think the bearing that you put in before the screw to attach the grip to the hub has gone bad on me, I'm going to take it apart and make sure I'm not missing a part.
Do you guys think that this little bit of play is causing my wag? Or should I check other things?
If this is the cause can anyone point me toward the part number for a replacement bearing?
Thanks,
Seb
Trex 600 - Scorpion HK-4025-890kv 8s, microbeast
Align 250, tarot FBL controller
Align 800 (not actually mine) for research into autonomous flight
Spektrum Dx7s
sebsmash is offline        Reply With Quote Quick reply to this message
Old 07-03-2013, 05:49 PM   #2 (permalink)
Default Tail wag
Just cured the same wag with my 600. Had to adjust the transmitter gyro gain down to 50 from 60. No more tail wag. Hope this helps.
TREX 550E Stretched, DX8, ICE 100, CC BEC PRO 600 AS 350 fuselageTREX600 pro, DX8,CCBEC Pro, CC HV80' AR7200BX
rascat06 is offline        Reply With Quote Quick reply to this message
Old 07-03-2013, 06:27 PM   #3 (permalink)
I've dropped the gain a ton and still no change.
I think I'm doing the vbar right. I have it set to control it by tx and I adjust the gain on the transmitter after short hovers and it seems to have minimal effect
Spektrum Dx7s
Old 07-03-2013, 06:27 PM   #4 (permalink)
The tail grips need a little play in them right?
Spektrum Dx7s
Old 07-03-2013, 06:35 PM   #5 (permalink)
They will have a bit but it should be the same on both sides. Take the main and tail blades off, spin the heli up and feel if you have a ton of vibrations. If one tail blade grip can slide out more than the other that will cause a lot of vibration.
My guesses...
1. Vibration
2. Messed your V-Bar up in the crash. If you've already lowered the gain a lot it's probably not a configuration issue.
Mike A. is offline        Reply With Quote Quick reply to this message
Old 07-03-2013, 06:51 PM   #6 (permalink)
I just went through and checked through the thrust bearings and found no issues, everything in the tail seems normal, just the right amount of give, and equal on both sides.
I don't imagine any electronics were damaged because the crash just bent the tail boom at 90 degrees and barely effected the main body of the Heli.
I'm going to run through the vbar setup and completely redo the tail since this has to be my problem. I can't find anything mechanically wrong! Makes me scared I'm not noticing something.
Spektrum Dx7s
Old 07-04-2013, 06:34 AM   #7 (permalink)
tail servo ok? not a too high load needed to move tail blades aka chinese weights?
apper001 is offline        Reply With Quote Quick reply to this message
Old 07-04-2013, 06:52 AM   #8 (permalink)
Have you spun the heli up with the blades to check for increased vibrations? Sounds like a vibration issue to me. If you didn't change settings in your vbar that caused the tail wag then something else is causing it.
I had an issue once with a bad tail grip bearing in my 500. On the ground it moved fine but once in the air and spinning at 8000rpm the tail was binding slightly and causing a big wag.
Old 07-04-2013, 10:29 AM   #9 (permalink)
I too had a wag. Tail was slick as butter. Thought it might be the ICE2HV gov. It was.
When governed, it needs to see 30, 70 or 100 from the transmitter. In my case, the 70 to 100 was too close even after setting the endpoints. There was a bit of a chirp, a fast, inconsistent wag, and the rotor sounded not quite right. I'd flown about 40 flights without the problem, then it suddenly came up. After messing with the tail gain and gov gain, I decided to set the throttle endpoints (I'm lazy and it did work fine out of the box without needing it).
I put her on the ground and put another two points up on my throttle endpoints, and that solved it. Confused me for a month, and I was scared to use idle up, lest the quick load/unload of the gear train cause me to strip a gear.
confusionsays is offline        Reply With Quote Quick reply to this message
Old 07-04-2013, 10:36 AM   #10 (permalink)
So it was switching back and forth between the two headspeeds constantly?
Old 07-05-2013, 05:06 PM   #11 (permalink)
Yup. I first thought it was wag caused by rudder gain too high, then thought it was the gov gain too high. It went away when I went out of IU. I then noticed the lower headspeed sound when it settled out.
Old 07-06-2013, 11:00 AM   #12 (permalink)
Mine did the same thing after I built it last year and the fix was turning down the gain in my beastx.
Trex 600efl Pro with Beastx, Blade 450 3D with ZYX Tarot FBL, Blade 450 3D stock, MCPX v2, Sr120, Spektrum DX8
celltech is offline        Reply With Quote Quick reply to this message
Old 07-10-2013, 07:21 PM   #13 (permalink)
So today I tried her out again,
I started with the gain on 30 on the tx (90 on vbar) and dropped it down to 15 on tx.
I also raised the head speed and tightened the tail blades which seemed to help.
I'll try dropping the gain a little more on Friday.
The little wag only shows up while hovering,
The second I start forward flight the wag goes away, so I think it must be the gains.
I also reset the endpoints and moved the ball in on the servo horn, which helped.
Spektrum Dx7s
Old 08-07-2013, 11:34 PM   #14 (permalink)
Assuming your Vbar sensor is not bad, 99% of the time a slow tail wag is a result of a mechincal issue. Just because everything is smooth on the bench doesnt mean something isn't binding in flight. Also check your tail control arm for being loose or to tight. The tail control also has a plastic cup that the ball sits in, I've see that cause a slow tail wag from being to tight. I see your in So Cal. I fly in ontario. If you cant figure it out, your welcome to come out and fly with us and I'll give you a hand with it.
Mickey
mickeyjohnston is offline        Reply With Quote Quick reply to this message
