Skookum Robotics Skookum Robotics SK-360 SK-540 & SK-720 Digital Flybar |
05-25-2012, 01:49 PM | #21 (permalink) |
+1 on that
Never enough time, Never enough helies |
05-25-2012, 05:13 PM | #22 (permalink) |
No trottle and I can't even arm my esc, What happen here.
05-25-2012, 06:26 PM | #23 (permalink) |
check that the esc is pluged in the right slot
05-25-2012, 08:42 PM | #24 (permalink) |
Ok got it forgot to set trottle endpoints, got it to hover, but everytime I move the collective stick up and down while heli on the ground the red light start flashing, also when I have it a hover and I move evelator foward and backward the red light start flashing. I landed the heli and unplug and replug the battery I got the green light. then same thing as above happen again.
I set this heli with governor I am using the stock esc 35a Hitec 65mg Futaba 9257 Last edited by KBaksh; 05-25-2012 at 10:53 PM.. |
05-26-2012, 09:27 AM | #25 (permalink) | |
05-26-2012, 10:53 AM | #26 (permalink) |
=] mail the log to SK, they can see the whole picture.....
USB connect should show the error report on start-up....
05-26-2012, 11:40 AM | #27 (permalink) |
Software shows (Warning Low Voltage) I have a castle bec how do I connect it to sk-540.
05-26-2012, 11:50 AM | #28 (permalink) |
=] what is your SK "low voltage alarm" set to? what is your ESC bec voltage set to?...
05-26-2012, 01:19 PM | #29 (permalink) |
2S Lipo Servo battery, and my esc bec is default setting. What volt do I run my castle 10a bec
05-26-2012, 01:40 PM | #30 (permalink) |
=] set the SK alarm to bec, the red light will now stay off!....
05-26-2012, 08:05 PM | #31 (permalink) |
ok added bec now no more flashing red light. governor seams to work sometimes, I am usind hyperion phase tachometer I test on bench without blades everything you can hear the change of speed, but when I hover and go in idle up 1 and 2 no head speed change.
05-26-2012, 11:19 PM | #32 (permalink) |
I tested mine today too, doesnt change rpm..wtf skooookkkkummms
Minion Mini Quad 4S / Mini Talon V-tail Drone / Micro H Quad on Taranis FPV |
05-27-2012, 02:29 AM | #33 (permalink) |
=] allow the gov time to engage, it's looking for it's signal on the throttle ramp. change the normal curve to 0,40,40,40,40 hold the stick at 50% and let it spool, you will hear it come in.
05-27-2012, 02:47 AM | #34 (permalink) |
I think some of us are entering just the main gear to pinion gear ratio. I just watched the video for the SK720 Gov Setup [ame]http://www.youtube.com/watch?v=FkLRyqybbzQ&feature=relmfu[/ame] and it states to take the gear ratio and multiply by number of motor poles and divide by 2
05-27-2012, 03:42 AM | #35 (permalink) |
=] correct!! https://www.helifreak.com/showthread.php?t=296946
05-27-2012, 06:19 AM | #36 (permalink) |
See, I really think he should change that interface...
Its not...people proof |
05-27-2012, 07:21 AM | #37 (permalink) |
[ame]http://www.youtube.com/watch?v=WFHD_-PhzdY[/ame]
Ok if governor is not enguage heli hover smooth, but in video above when governor is enguage heli tail wag fast does matter what gain value I have on the head or tail. In video I have 32 on tail and 45 on head. 150 = Main Gear 15 = Pinion 6 Plole = 3400kv Motor 30 = RPM Sesor Gear Ratio enter in software Head Speed , 0: 3150, 1: 3250, 2: 3350 |
05-27-2012, 07:30 AM | #38 (permalink) |
=] turn the Gov gain down (in the drive system) to low 30's or below until the wag goes away....
