Go Back   HeliFreak > R/C Helicopters > R/C Helicopter Tools and Supplies
R/C Helicopter Tools and Supplies Tools and Products used with R/C Helicopters
Old 11-20-2011, 11:47 PM   #21 (permalink)
I got a Heliproz set that was inexpensive and came with a ball end and regular end for each size.
Havoc is offline        Reply With Quote Quick reply to this message
Old 11-21-2011, 12:11 AM   #22 (permalink)
I have a set of the pink handled dynamites I have had for about 7 or 8 years and never had a problem with them built and torn down many many rcs with em.
BuddmanTx
BuddmanTx is offline        Reply With Quote Quick reply to this message
Old 11-21-2011, 01:08 AM   #23 (permalink)
+1 on MIP
The more I learn the more I realize I don't know
T-Rex 800DFC Pro, 700LTOP, 700L Night, 550V2, 470LT, 250DFC, Oxy-2 x2, 3 x2, 4, Goblin 500 Sport(soon), Fireball x2, Blade 230s Night, 180CFX, MCPS, Nano CPX & NQX2 FPV, Vortex 250, Inductrix FPV. K110 Cars/Trucks/Planes AMA#L965241, Part 107 Pilot
#iamundeservedlyblessedandiknowit
TeeJayShelton is offline        Reply With Quote Quick reply to this message
Old 11-21-2011, 01:13 AM   #24 (permalink)
The dynamite work for me, I have ground the tip down a bit to get fresh surface but itll last another year b4 I put in the extra bit I bought with the 1.5. Its also good to have a few different brands, fasteners vary so sometimes a different hex fits better. I had a hobbyking with 4 bits in the handle, its good but I broke the 1.5 by chucking it in a drill to redo a frame. It snapped but thats because it was hardened, it was a good tool. The reviews on hk said the tool changed quality so I havent rebought.
Volcano is offline        Reply With Quote Quick reply to this message
Old 11-21-2011, 01:30 AM   #25 (permalink)
I use the Turnigy Hex drivers from hobbyking and they are the best I've ever seen and a lot cheaper than Thorp. 1 year full-time use on the 1.5 mm one and it still looks like new.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
PRÔTOS 500 FBL "Sky Whip" | Robird G31
Audacity P6 FBL "Phoenix" | MSH Brain | 12s
Goblin Speed | iKon
Dr. M is offline        Reply With Quote Quick reply to this message
Old 11-21-2011, 03:31 AM   #26 (permalink)
Do they make them for men?
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Atom 500
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote Quick reply to this message
Old 11-21-2011, 07:45 AM   #27 (permalink)
+1 for MIP thorps. After my cheaper 1.5mm hex driver broke I got an MIP, it's lasted through much use and abuse. The tip still has totally rigid corners with no sign of rounding.
Trex 450 Pro V2 - Stock with BeastX
mCP X, Nano QX
Fuzzy Toaster is offline        Reply With Quote Quick reply to this message
Old 11-21-2011, 07:54 AM   #28 (permalink)
andrew you're being kinda harsh with Horizon, they seem to be bending over to please you.
I expect the chinese tools to be garbage, raising the price doesn't turn junk into gold
Outrage Fusion 50 FBL / Futaba 8FG / Beastx / Scorpion HK4025
sansone is offline        Reply With Quote Quick reply to this message
Old 11-21-2011, 08:29 AM   #29 (permalink)
Originally Posted by FourT6and2 View Post
Been using Losi drivers with no issues at the recommendation of Nankin Hobby. So far so good.
These are what I have:
The harder the metal, the more brittle.
Yep.... I have these too, have been providing quality service for years with no issues.
The tips are spring steel that is TiN coated, so, if you are breaking them there may be something else up.
These are just as good as MIP or HUDY....
~SAB~ Goblin 700 ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team BOCA Bearings**
BaconRaygun is offline        Reply With Quote Quick reply to this message
Old 11-21-2011, 08:40 AM   #30 (permalink)
Originally Posted by TeeJayShelton View Post
+1 on MIP
+2...
700LE : 105HZR AR7200BX JR8917 Multi gov , JR9503
600ESP : 100AMP Castle. Scorpion Motor . AMA #962896
400 Blade : Scorpion 2221-6 ,Castle ICE 50 Sonix Head and t
Align 450 pro V2 3G MKS DS95 MSR , 2 x MCPX (brushless C05 & HP05), Blade 130X.
whoanelly is offline        Reply With Quote Quick reply to this message
Old 11-21-2011, 09:07 AM   #31 (permalink)
Registered User
I have a set of the Dynamite and the MIP. They both have been doing very well for years.
William James
Old 11-21-2011, 09:15 AM   #32 (permalink)
Originally Posted by SYMAWD View Post
Yeah, but I've only read of one breaking once. They don't need a warranty they are so good.
the metal is tough, that's for sure. but, I've spun the shaft inside of my 1.5. it still works for 90% of the stuff i'd need it for. but, if i really need to put some torque on it, it lets go.
i have a set of WIHA that are guaranteed 100% for life. but, i got tired of sending them in.
i still go with MIP 100%. but, now you've heard of 2 ;-)
˙ʇı ʞɐǝɹq 'ǝʞoɹq ʇ,uıɐ ʇı ɟı
cudaboy_71 is offline        Reply With Quote Quick reply to this message
Old 11-21-2011, 09:39 AM   #33 (permalink)
make that three, I had a MIP 1.5 that I spun the shaft inside the handle the FIRST time it was used......but I got it replaced and no issues since......
lang123s is offline        Reply With Quote Quick reply to this message
Old 11-21-2011, 10:28 AM   #34 (permalink)
Isn’t there a grub-screw holding the shaft in? Just tighten the screw....
If you need to apply that much torque to remove a bolt… then heating up the screw/bolt is probably a good idea as there is a good amount of thread-lock holding it.
AMA# 977012
Old 11-21-2011, 10:34 AM   #35 (permalink)
Bri
I have the below set made by "Dynamite", but plan on getting some MIP's, just because.
http://dynamiterc.com/Products/Defau...ProdID=DYN2833
Brian
T-Rex 700F3C / T-Rex 450 Pro / Blade mCPX / Blade mSR / Blade mCX / Walkera 53Q3
JR X9503 /
Spektrum DX7
Phoenix Sim
Bri is offline        Reply With Quote Quick reply to this message
Old 11-21-2011, 10:37 AM   #36 (permalink)
My Dynamite drivers have lasted me for about 5 years now, maybe they were better back then?
THIS IS MY SIGNATURE. THERE ARE MANY LIKE IT BUT THIS ONE IS MINE.
Mojappa is offline        Reply With Quote Quick reply to this message
Old 11-21-2011, 10:45 AM   #37 (permalink)
Only $282.25
http://www.hudy.net/eshop/products/p...a4acc69819f280
Dogs come when called. Cats take a message and get back to you later.
Cailid is offline        Reply With Quote Quick reply to this message
Old 11-21-2011, 11:09 AM   #38 (permalink)
Ya, sounds steep.... but pretty standard. @ $15-30 a pop (depending on size, tool type) it adds up.
AMA# 977012
Old 11-21-2011, 11:16 AM   #39 (permalink)
I expect my Mip drivers to last as long as I'm in this hobby. They are brilliant.
Atom 500
Spektrum DX8
Old 11-21-2011, 12:57 PM   #40 (permalink)
LOL. These are not spring steel, no way..
Those were the first set I had (still have them) and the larger drivers are OK but the 2mm and 1.5mm are weak and round off easily even on the Align screws..
AndrewAZ is offline        Reply With Quote Quick reply to this message
