Old 05-11-2012, 08:59 PM   #1 (permalink)
Default subtrim or not
so i finally got my receiver today and i am ready to start programing my 3gx unit, my first problem is subtrim, do i use the transmitter subtrim to 90 my servo's or is it adjusted in the 3gx v2 unit?
Anthony
raw 500, xl power nimbus 550,Tron 5.8 heritage, Tron Dnamic, cgy760-r, futaba
anthony1 is online now        Reply With Quote Quick reply to this message
Old 05-11-2012, 11:51 PM   #2 (permalink)
First get the servo arm as close to 90 as possible, swap them all the way around the other servos in order to find the best suit.Than you can use few clicks of subtrims in your TX, but ONLY in DIR mode.
Chris
Oxy2 - Oxy 3 -Oxy 4 - Oxy 4MAX - Oxy 5 MEG - Oxy 5HF - Nitroxy -Flash700
scoio is offline        Reply With Quote Quick reply to this message
Old 05-12-2012, 06:29 AM   #3 (permalink)
what do you mean by ONLY in dir mode
Anthony
Old 05-12-2012, 08:25 AM   #4 (permalink)
dir mode is what you go into to set up the 3gx while in dir mode you set up your servo(subtrim) level your swash find 0 pitch your max and min collective and your 8 deg cyclic if any subtrim is ever used again you only do it in dir mode read the manual or use the software and follow it step by step
control crash expert!
blade 450x, edge blades, more coming. trex 550e v2, hc3sx, cc100, edge 553, cc bec pro trex 550e v2, 7200bx, cc100, cc bec pro, edge 523trex 450pro v2 7200bx, dx8 edge blades, hs5065 mg, kds 450sv,
kdsguy1 is offline        Reply With Quote Quick reply to this message
Old 05-12-2012, 08:28 AM   #5 (permalink)
Mean that you can use subtrim only during programming mode (DIR), when you have to get 90 on servos, swash leveled, desired pitch and cyclic on blades.
Meaning, do not give any trim or subtrim on the hely while you are flying it.
Hope It helps
Chris
Old 05-12-2012, 08:29 AM   #6 (permalink)
EDIT: Kdsguy1 beat me for 3 min!!
Old 05-12-2012, 09:43 AM   #7 (permalink)
Quick Question on 450 Pro 3gx:
Swash Level: is it Only In Middel Is Has To Be Leveled? Or Top, middel and Buttom?
Thanks In Advance.
Align T-Rex 450 Pro V2, Super Combo with ar7200bx.
Align T-Rex 500EFL Super Combo, ar7200bx
Spektrum DX7S
Random_Hero is offline        Reply With Quote Quick reply to this message
Old 05-12-2012, 10:37 AM   #8 (permalink)
thanks you both i will jump on it right away
Anthony
Old 05-12-2012, 10:50 AM   #9 (permalink)
sorry we are all here to help!
Thanks In Advance.
it is best to get level at low middle and high there is debate about not being level in all positions causes drift as well as pitch being the same 360 deg around the heli, i have heard also that the 3gx (only leveling at mid stick) will take care of the high and low in flight but i dont know about that. i had a drift and went back to the bench and releveled and made high and low level and no more drift soooooo the debate continues
Old 05-12-2012, 12:24 PM   #10 (permalink)
[QUOTE=kdsguy1;3935389] sorry we are all here to help!
it is best to get level at low middle and high there is debate about not being level in all positions causes drift as well as pitch being the same 360 deg around the heli, i have heard also that the 3gx (only leveling at mid stick) will take care of the high and low in flight but i dont know about that. i had a drift and went back to the bench and releveled and made high and low level and no more drift soooooo the debate continues [/QUOTE
Ok. Thanks. I Guess Its best to level all 3 Pos.
And To Do that it is with Subtrim And Travel-length? (off Course In Dir-mode)
Thanks!
Spektrum DX7S
Old 05-12-2012, 03:01 PM   #11 (permalink)
ok next question, i have been told that i need to set my swash mix to 120 ccpm or sr3 in my futaba radio but the first page of the 3gx setup says to disable swash mix if available, what do i do, i have to say that the setup so far is very confusing and not giving me a lot of confidence that i am getting it right
Anthony
Old 05-12-2012, 03:02 PM   #12 (permalink)
I saw this great system on a raptor 90 4g today. With this system, compatible with align servos, the 90° angle is everytime perfect !!I will buy a set for my 600 efl.
http://www.fast-lad.co.uk/store/pv1603_metal_cyclic_servo_horn-p-16689.html
GOBLIN 700 competition / CC 160HV / KDE 700XF 495 / MSH Brain/IKON (ordered)
ALIGN T-REX600EFL Pro / CC 80HV+ / KDE 600XF-530 / MSH Brain/IKON
d.porte is offline        Reply With Quote Quick reply to this message
Old 05-12-2012, 08:18 PM   #13 (permalink)
ok i think i've finished the setup, not very confident its all good but i will give it another check tomorrow, last thing i noticed is that the gov light is green should it be off for no governor or is this light for something else, very confusing to set up!
Anthony
Old 05-12-2012, 08:22 PM   #14 (permalink)
Means nothing but cant be dissabled by turning off gear channel and then it will go red.
Align 450Pro 3GX, 500ESP/DFC 3GX, 500L, 550 DFC MicroBeast , Velocity 50 Vbar OS55 HZ-R, D380 DFC D420, G500 Sport Microbeast, All HW V4,
X5 stretch 220 Flame Emax Bullet Force V2 VTX
bad007 is offline        Reply With Quote Quick reply to this message
Old 05-12-2012, 08:25 PM   #15 (permalink)
It doesn't say to disable swash mix, it says to dissable any mixing and that's different.
If you not comfortable with your setup I wouldn't fly it unitil you sure.
Confused about something post it so you can make sure your on track
Old 05-13-2012, 06:02 AM   #16 (permalink)
good morning, so i have checked my setup this morning and everything is moving in the right direction, and now for the $65,000 question, there are a lot more settings that i can adjust, is there a procedure for doing this, can i try it on the default settings ? do i add expo in my transmitter? i know its personal prefference but is there something i should adjust before the test flight?
thank you
Anthony
Old 05-13-2012, 07:37 AM   #17 (permalink)
thank you
This is the 450Pro right?
for initial flight since you don't know what to expect, set expo in the software to third setting/ none in the tx for cyclic expo. Drop the flip and roll rates / control rates 10 from default.
On a 450 drop travel limits aditional 5 points from where the swash binds on the main shaft with the cyclic stick held in the corners.
Set normal TC 0 60 80 85 90 and PC 0 40 45 50 75 100. 12 - 13 max pitch, 60 for TC ,1/4 stick gets the head speed up and stabulizes it before it gets light on the skids.
When checking max pitch use standard gauge and rotate the head 360 and make sure it reads the same all the way around. If it doesn't it = wobbly piros and drift
Old 05-13-2012, 07:51 AM   #18 (permalink)
thank you very much,yes its a 450 pro, the only change is that i am using the castle ice lite 50 set to governor mode but all the rest is standard, i will still take your advice on the rest as it makes sense, again thank you so much for your time
Anthony
Old 05-13-2012, 07:57 AM   #19 (permalink)
Your welcome, good luck
Old 05-13-2012, 11:33 AM   #20 (permalink)
thank you, just going to go and spool it up and iy started raining so this is a good time to triple check everything
Anthony
