Go Back   HeliFreak > R/C Electronics Support > YGE
YGE YGE ESC Support and Discussion
Old 04-11-2012, 02:32 PM   #1 (permalink)
Default YGE Gov Store
I run the set up in gov store. But when I finish the esc have one beep.
You have this problem? let me know please
lgalarza is offline        Reply With Quote Quick reply to this message
Old 04-11-2012, 02:46 PM   #2 (permalink)
I think that means "Now spool me up to 100% at zero pitch so I can calibrate and then spool down and unplug me again".
Detritus is offline        Reply With Quote Quick reply to this message
Old 04-11-2012, 09:10 PM   #3 (permalink)
After selecting Gov store via the prog card it is normal to hear a 1 single beep before calibrating your max headspeed. After you have done your calibration properly and you have cycled the power on your ESC, you should NOT get any beeps, if you do then it means your gov store programming was not successful and you should redo the setup again.
Gaui X7 MSH Brain YGE160HV Xera4035-480 Gaui X475 FES MSH Brain YGE120 Xera4020 Gaui X5 MSH Brain YGE90HV Xera 4025
Gaui X6 vbar silver 5.3 YGE120HV 700mx
joe1l is offline        Reply With Quote Quick reply to this message
Old 04-12-2012, 10:01 AM   #4 (permalink)
Ok Thanks
Old 04-12-2012, 12:25 PM   #5 (permalink)
If all my packs are the same, should I just use regular gov? Would it be necessary to use Gov Store? Any advantages to use Gov Store if all my packs are the same?
Mike
maarset is offline        Reply With Quote Quick reply to this message
Old 04-12-2012, 03:34 PM   #6 (permalink)
If you do autos, every time you come out of throttle hold in normal gov mode it will recalibrate to increasingly lower head speeds (unless perhaps your throttle hold is a few percent rather than 0). In Gov Store mode this isn't supposed to happen, .. but it seems to for me anyway...
Old 04-12-2012, 04:13 PM   #7 (permalink)
Oh ok...
I'm not a big auto guy. I just fly / stop / change pack / fly / stop / change pack
Old 04-12-2012, 04:23 PM   #8 (permalink)
Oh ok...
Well, also means you don't have to do the little calibration ritual each time you spool up, but I'm not sure I ever did that properly anyway. If your packs are all the same, Gov Store is definately the best mode. Just remember to reinitialise it if you change any gearing, blades etc.
Old 04-12-2012, 04:33 PM   #9 (permalink)
Oh I guess I'm confused now. I thought Gov Store was better if you had packs that didn't output the same quality voltage.
Since all my packs are pretty much identical I thought it would be best to use Regular Gov
Old 04-13-2012, 02:00 AM   #10 (permalink)
That's not my understanding. In regular mode, each time you spool up it assumes nothing about your motor timing/battery/motor/drag etc and does new calculations to guess what the battery sag would be at the end of the flight so it knows how much headroom to leave, so it can give a 0-100% linear calibration on your throttle channel, for that specific set of variables.
If your motor timing, battery etc never change - i.e. none of the variables affecting governing - then it's pointless doing that calibration on every spoolup. It can just do them once and "store" the result. However, if the variables do change when in GS mode, it will be using bad calibration data so you need to recalibrate. If your variables change a lot (e.g. you have a right rum collection of packs) then it's best to stick to regular gov mode.
Old 04-13-2012, 10:41 AM   #11 (permalink)
do you have to recalibrate gov store if you change your motor?
dl5973 is offline        Reply With Quote Quick reply to this message
Old 04-13-2012, 12:30 PM   #12 (permalink)
Yes.
MSH Protos 500, SAB 630
alexf1852 is offline        Reply With Quote Quick reply to this message
Old 04-28-2012, 05:47 AM   #13 (permalink)
hi,
i have a question on the 8s x5, is that the 4025/2y-830 or 4025/2.5y-670
gona run them on a yge hv 120, vbar gov for either one i get
thanks
fusionsx00 is offline        Reply With Quote Quick reply to this message
Old 06-21-2012, 12:05 PM   #14 (permalink)
I read your answer to the case and I noticed that my "YGE" No sound!
when active mode "GOV.STORE", my "YGE" I did not notice that we are ready with no sound.
yet the "GOV.STORE" works well.
pasta_carbonara is offline        Reply With Quote Quick reply to this message
