Old 07-26-2015, 03:14 PM   #1 (permalink)
Default Hatori Confusion
It's been a rocky month for Hatori Fans. Hatori Japan stopped production of 3D pipes for the OS 105 (#2105 105FS-3D SB-22FH) and OS 120 (#2123 120FS-3D SB-23FH) engines, and RC Japan mistakenly announced that Hatori was going out of business. That's been cleared up in various threads on HF and RR: Hatori Japan and Hatori USA are alive and well.
It looks like Hatori is now producing a new, different pipe for the OS 105. It doesn't appear on the Hatori Japan or Hatori USA websites (yet?), but Amain has started selling the "Hatori SAB-22".
http://www.amain.com/rc-helicopters/...tsab22/p450414
The box is now blue, and has a HatoriUSA label. On the label it says SAB-22FH-3D (which is confusingly close to the old model number). Description says it's the same as the SB-22FH, except notice it's 1-piece, it no longer has the Header/Grommet/O-ring setup.
I wish someone from Hatori Marketing would clear up all the confusion, they're not managing their brand perception very well
How do you make a small fortune in this hobby?
Start with a large one!
HelisRock is offline        Reply With Quote Quick reply to this message
Old 07-26-2015, 05:42 PM   #2 (permalink)
It sure looks a lot like this one.
.https://rcjapan.net/otherstudio-c-85...pv0t30sl6bk8p3
dbcaster is offline        Reply With Quote Quick reply to this message
Old 07-26-2015, 05:51 PM   #3 (permalink)
Which looks just like the OS Powerboost pipe.
http://www.amain.com/rc-helicopters/...146000/p220861
Glenn Goodlett is offline        Reply With Quote Quick reply to this message
Old 07-27-2015, 07:05 AM   #4 (permalink)
Are they possibly outsourcing the pipes for the OS105 and YS120 from OS to fill the void?
Team Rotorquest/ SAB Heli Canada
mtymyk is offline        Reply With Quote Quick reply to this message
Old 07-31-2015, 08:31 AM   #5 (permalink)
If you check now the link, the item es re-directed to: M STUDIO
Align 800e PRO DFC // KRAKEN Yellow // RAW Nitro // Align 700N DFC // RAW Yellow // 2x Goblin 420 // RAW 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo
msallua is offline        Reply With Quote Quick reply to this message
Old 07-31-2015, 01:17 PM   #6 (permalink)
Default pipe
Well from what I understand he wants to retire. And when he does that will be an issue. As for the hard mount pipe. No THANKS.
TEAM:
CYCLONE BLADES
matt blaisdell is offline        Reply With Quote Quick reply to this message
Old 07-31-2015, 01:27 PM   #7 (permalink)
A Big plus ++! on that!!
Jim Hansen is offline        Reply With Quote Quick reply to this message
Old 08-03-2015, 12:21 PM   #8 (permalink)
+3. Cracking welds...
= Rb43 =
Old 08-03-2015, 12:47 PM   #9 (permalink)
And weren't OS powerboost pipes rebadged FunTech pipes?
Baedarlboo is offline        Reply With Quote Quick reply to this message
Old 08-08-2015, 10:06 PM   #10 (permalink)
Supposedly the OS pipe is the M studio one.
marc8090 is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 01:08 AM   #11 (permalink)
Yea, to me it looks obvious it's not made by hatori and is just a re-branded os powerboost pipe.
Goblin 380, Goblin 500, Goblin 570, Goblin 700c, Goblin nitro, Synergy N7, Blade 180cfx,
DX9,icharger 4010 Duo
Sponsored by Visa
Matt Sherman is offline        Reply With Quote Quick reply to this message
Old 08-25-2015, 06:28 AM   #12 (permalink)
I wrote Hatoriusa to inquire about the pipe for 105.
This is their reply,
"Thank for your interest in hatori mufflers‎. We have a Japanese made replacement for the 105. Lots of power. Unfortunately, the hat original will not be brought back
The cost for the 45 mm diameter went up so high Hatoriwould have had to buy 4 year supply of raw material‎. That's why he discontinued the 105 and the YS120"
I'm assuming the 45mm is the internal diameter size.
Too bad that is the case as I really like the style that was discontinued.
Marc
Norman, OK - Synergy N7, TREX 700N DFC, TSA 700N, TSA 600N, Trex 550, Trex 500 ESP (FBL), 450L, RCHN - 700
mqowen is offline        Reply With Quote Quick reply to this message
Old 04-05-2016, 11:40 PM   #13 (permalink)
Received today... Ready for test the weekend.
ID:	645073   Click image for larger version
ID:	645074   Click image for larger version
Old 04-06-2016, 03:26 PM   #14 (permalink)
I found out it is just a re-branded OS power boost pipe. It's sad that Hatori has come out saying they have a new pipe for the 105 when all they did was re-brand the OS pipe. On top of that it's not even a soft mount pipe :-(
Sponsored by Visa
Old 11-28-2016, 03:42 PM   #15 (permalink)
So what is the best solution instead hatori sb-22-fh for the os max 105 with rds on goblin 700 nitro ?
artesina is offline        Reply With Quote Quick reply to this message
Old 11-28-2016, 09:33 PM   #16 (permalink)
Curtis muscle pipe works great with the os105 when I had that engine
Luis Murillo is offline        Reply With Quote Quick reply to this message
Old 11-29-2016, 05:59 AM   #17 (permalink)
I have found in USA one hatori for yamada 120. Can work and fit well in goblin 700 black nitro ? Any add on for fit that pipe?
Old 11-29-2016, 07:16 AM   #18 (permalink)
You need the 955 header from this page. The bolt pattern on the OS is different than the YS. Both pipes are the same. However, the YS pipe does not have a pressure nipple. If your using a non-regulated OS you would need to drill and tap the muffler for a pressure nipple. http://www.hatoriusa.com/?page_id=7
Old 12-12-2016, 12:39 PM   #19 (permalink)
Anyone know where to small source the silicone grommets? Everyone seems to be out of stock of the #175. Plenty of #185 but they are huge in comparison.
Thanks.
-Mike
Team QuickUK Pilot
Team Heliproz
MikeSherman is offline        Reply With Quote Quick reply to this message
Old 12-12-2016, 12:41 PM   #20 (permalink)
http://www.rjxhobby.com/rjx-accessor.../rjx-xt90-0004
Enviado desde mi SM-N920G mediante Tapatalk
