HBFP V1/V2 E-Sky Honey Bee V1 & V2 Fixed Pitch |
09-06-2013, 12:53 PM | #1 (permalink) |
Honey Bee 2 Tail spining fast!
Hey guys! Need help please!!
Just installed the CP3 tail mod, now the Bee spins as fast as it can go to the right as you increase throttle on the ground. Tail blade spinning clockwise, has Super Skids/ Super hover blades. Left stick input has very little effect, and Gyro adjustments not doing any good. Connectors both have the red wire on top. I also installed the tail fuse mod while I had the tail off, and replaced a dented tail boom. Any ideas or help will be appreciated! Thanks, |
09-06-2013, 04:36 PM | #2 (permalink) |
Hi hb1201
No worries mate, sounds like you have the Prop spinning the wrong way. With the CP3 tail mod, the Prop needs to spins counter clockwise to be correct. Just unplug the tail motor at the 4in1 and flip the plug around, this will get the prop spinning the correct way and you should get your tail authority back. Hope this solve your problem and remember to always unplug the 4in1 every time you make adjustments to the proportional pot.
09-06-2013, 09:11 PM | #3 (permalink) |
Well from the amount of views this got and with only one reply, I assume everyone thought the same thing......I am an IDIOT!
I have no clue how the wires got crossed. I was sure everything was wired back correctly!? THANK YOU! That worked and it sits perfectly still now! I really appreciate your reply. Sometimes I get tunnel vision at my age and don't see the forest for the trees! Just hope I don't crash into them! |
09-07-2013, 06:46 AM | #4 (permalink) |
Glad to have helped and I’m sure nobody here thought that. The thing is, there’s not many Bee owner that still visited this forum. Sadly, most of the hard core Bee guys that I’ve known over the years have moved on to bigger and better things, but please don’t get me wrong. If you have questions, please ask away, there are still a few guys around here that can help, it just might take a little while to get a response is all.
