500 Pro Class Electric Helicopters 500 Pro Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
11-03-2015, 12:26 AM | #1 (permalink) |
Trex 500l Main Shaft problem
I am a novice and building my first align trex 500l dominator and get stuck. I am trying to put the main shaft inside the main rotor housing(rotor head?) and use the screw to attach them together, but the screw holes on the rotor head and the main shaft doesn't align together. The screw hole on the main shaft seems to be too far away from the shaft end (the bigger end) so that the it doesn't align with the rotor head screw hole.
Am I missing something, or did I get the wrong part? Please help, thank you. |
11-03-2015, 06:54 AM | #2 (permalink) |
Are you sure you are inserting the correct end of the shaft. Try the other end.
Rick
Helifreak, the place to be! Oxy5 w/Brain2, Rush 750 w/VBAR,Logo 400SE, 600SE w/NEOs, TREX 450SE, 500, 600, Blade mCPX,130X, 180CFX, Nano QX, Convergence VTOL, MiniProtos w/BD3SX My products, used by top pilots worldwide, like you! http://rdlohr.com |
11-03-2015, 10:30 AM | #3 (permalink) |
The other end (smaller) could fit in with some space. But I look at the installation manual carefully, its picture clearly shows that it is the bigger end of the shaft to put into the rotor head.
11-03-2015, 01:33 PM | #4 (permalink) |
He said the bigger end, so it is the right end. Does the shaft have any writing on it? How far is the hole from the end of the shaft?
<> Trex 600 ESP FBL, Trex 500 ESP FBL, Gaui X3, Oxy 3 <> <> Builds in progress: Logo 600SX, Synergy 516 <> *Spartan Vortex VX1e*
11-03-2015, 03:12 PM | #5 (permalink) |
The shaft says Align Trex 500...and the manual picture shows the bigger shaft end should go into the rotor head too.
I guess it is only a few mm longer, I cannot see the shaft screw hole through the rotor head screw hole. |
11-03-2015, 07:07 PM | #6 (permalink) |
They will not line up. I had the same problem. They included the wrong main shaft with alot of kits. You need the main shaft for thr 500 dfc.
MCPX, MCPX BL, Nano CPX, 350QX, Blade 550X, 180cfx, T-Rex 250, T-Rex 450 Pro V2, T-Rex 500 Pro DFC, T-Rex 500 Dominator, T-Rex 550l Dominator, spedix 250, Tyrant, Chameleon TI Japalura, vortex 150, Vortex 250, DX9 |
11-03-2015, 11:13 PM | #7 (permalink) |
The shaft print as Align 500 DFC though, could it be the wrong rotor head?
Should I contact align and asked for replacement? thanks, |
11-04-2015, 06:22 PM | #8 (permalink) |
Hey I was mixed up a bit, the u need is for a trex 500 Pro and not the dfc pro
Here it is at amain http://www.amainhobbies.com/rc-helic...h50156/p215264
06-20-2016, 01:30 PM | #9 (permalink) |
Yup, had the same problem myself, called up Rotorquest where I bought it and they gave me the right one free of charge.
Vbar Control/DX9-Realflight 7 Align 250 pro DFC, Blade 450x with every blade hopup/lynx upgrades (4sale), Align 500L Dominator, Goblin 380, Goblin 700 Comp |
