BeastX FBL System BeastX FBL Flybarless System Software and Hardware Support |
10-11-2014, 03:10 PM | #1 (permalink) |
Where to send a faulty micro-beastx unit in?
I purchased a used beastx off ebay about 3 months ago. I installed this on my trex 500 shortly after receiving it. Flew amazing IMO for the first 5-6 flights. Now, I went to check something on the bench and it did not power up when I plugged in the flight pack. I thought I connected the plug funny...nope. So I repowered it and it came to life. (I just pulled the plug and stuck it back in.) At this point in time, I am sketcky about the unit so I went and re-powered it yet again. Powered up ok, again. I then went into the solid amber menus. Here's the next issue. I could get to menu G, but no matter what I did I can not get past this menu letter. After several tries, I tried it w/ the servos un-plugged. Guess what? It doesn't power up at all. It is a orange brick at this point.
I'm not new to set-up on beastx's and there is definetly an internal problem. Being that was said, I have no idea where I can send this in for repairs. Horizon hobbies? The beastx website is way different than the last time I was on that page. I'm beginning to think I have a paper-weight because you can type whatever you want to try to find beastx repair on google and I come up w/ nothing. And I got it used, not new *stupid me!* At least this happened while on the bench vs in the air! Do I own an expensive paperweight? This thing is dead-dead...It will no longer power up. I'm using s-bus on a rex 500 w/ CC esc and a life flight pack directly connected. HELP! |
10-11-2014, 03:48 PM | #2 (permalink) |
if its the ar7200 beast x , then call hh ,, if its the stand alone beast x (no built in reciver) then contact beastx directly
10-11-2014, 04:00 PM | #3 (permalink) | |
Thanks. |
