Old 03-28-2014, 05:19 AM   #61 (permalink)
Weekends here guys, don't forget those auto video while your out there flying!
Fly... crash... rebuild... repeat... Fly hard my friends! Team Lynx Mini Protos
Trexwilly is offline        Reply With Quote Quick reply to this message
Old 03-28-2014, 08:37 AM   #62 (permalink)
Originally Posted by Trexwilly View Post
the X3 made it out alive too, I didn't shoot as many with this bird but did do 12 flights... The YEP has no bailout, and each time you hit TH and start again, the machine losses some HS.. weird, I am going to see if I can build a mix to get a near zero, and see if that will allow for bailouts, and hopefully it will allow the ESC to keep it's stored HS like it should
http://youtu.be/wqXsgblkTbs
There is a trick to getting a bailout working for the YEP esc
In normal flight mode you set a throttle curve of 5% or 6% flat in governor mode. Idle up 1 and Idle up two use throttle curves you usually fly at in stunt modes. Anything below 5% and the headspeed does not spool up fast enough to recover (bailout will not be activated). If you go above 7%or 8% the esc will drive the rotor blades to rotate when you flick down to normal form idle up 1. You do not want this, you want the headspeed to drop to zero when flicking between idle 1 to normal flight mode. Test this on the ground.
When you do an auto instead of using throttle hold use your flight mode switch and flick down to normal mode. If you get in trouble flick your switch from normal to idle up 1 and the headspeed spools up quickly enough to recover and fly again.
Try it on the ground first to see how it works and then when you see it works you can try it in autos. It usually takes three to 4 seconds to spool up to full headspeed. More than enough time to recover.
dl5973 is offline        Reply With Quote Quick reply to this message
Old 03-28-2014, 08:41 AM   #63 (permalink)
So the normal flight mode becomes your throttle hold switch when doing autos on the YEP esc. The trick is to remember never fly on normal flight mode.
Old 03-28-2014, 09:32 AM   #64 (permalink)
Since I have a DX-8 can I set that line up in one TH since I have two?
Old 03-28-2014, 11:59 AM   #65 (permalink)
pretty good auto. i do it with my 600 from a good height. but with my 450 just from about head height. It looks funny from that high up. Good video
Frank R is offline        Reply With Quote Quick reply to this message
Old 03-28-2014, 12:41 PM   #66 (permalink)
What your doing is a baby auto. Its not a true autorotation unless you have to use negative pitch to keep the blades spinning before the flare at the end
Tachead is offline        Reply With Quote Quick reply to this message
Old 03-28-2014, 01:03 PM   #67 (permalink)
I like this kind of video best, a half good 3D flight, and finish it off with an auto...
This machine is tired. I bought it used, and the motor has to have 500+ flights on it, maybe more... The ESC may have double that, the guy who had it before me, used the ESC on his last three 450s, and he flies ALOT!!
[ame]http://youtu.be/LdvkduhZxw8[/ame]
Old 03-28-2014, 04:22 PM   #68 (permalink)
Will try to get some on the target
It has been rainy weather but tomorrow looks fine!
XL Power 520(soon to become a 480), Warp 360 , Tarot 360Sport, Logo480 LowRpm , Logo 500
T500 AP
Luigi_tuga is offline        Reply With Quote Quick reply to this message
Old 03-28-2014, 05:09 PM   #69 (permalink)
I'm not sure what you mean
You can only set up in a flight mode. So you can use normal flight mode idle1 or Idle 2. Pick the flight mode you use the least. I have a dx8 and use throttle hold switch to power up the motor for flight in idle 1 or idle 2. I use normal flight mode If I want to practice my autos.
If you use this method for auto's the esc will always think its in a flight mode and will return to your idle up headspeed every time you try an auto on a battery.
If you use throttle hold for autos the esc detects that you are no longer in a throttle mode and when you switch back to a flight mode the esc reads what voltage the battery is at and then returns to the headspeed based on the voltage in the packs and thus the headspeed will change every time as voltage of the cells drop the longer you fly.
Old 03-28-2014, 07:00 PM   #70 (permalink)
i was going to play this game this weekend but i cant get my tail hub off of my tail shaft so i can change my tail shaft.....
M&P_Hooligan is offline        Reply With Quote Quick reply to this message
Old 03-28-2014, 07:39 PM   #71 (permalink)
Did you try heat?
Old 03-28-2014, 07:51 PM   #72 (permalink)
Did you try heat?
i sure did, apparently when i put it together last fall i used my god strength along with loctite and it wont come back apart... stripped the grub screw head out
Old 03-28-2014, 07:54 PM   #73 (permalink)
That's too bad... no easy outs?
Last option is to drill it?
Old 03-28-2014, 07:56 PM   #74 (permalink)
they are all in my tool box at work....
Old 03-28-2014, 10:25 PM   #75 (permalink)
Default Re: 450 size Auto Rotation challenge!!
Just change the tail shaft too then;-)
Sent from my SGH-I337M using Tapatalk
Old 03-28-2014, 10:43 PM   #76 (permalink)
thats what i was trying to change!
now i have to change my tail box too
Old 03-28-2014, 10:49 PM   #77 (permalink)
Cut it off...
Old 03-29-2014, 06:20 AM   #78 (permalink)
op did you let one rip at 1:35? lol
T-rex 450/MD500
Mini Titan E325
T-rex 600 CF
CWDoherty is offline        Reply With Quote Quick reply to this message
Old 03-29-2014, 08:19 AM   #79 (permalink)
Cut it off...
tail box has a stripped screw anyways ive had it through bolted with a nut, i will just use up some store credit and get a new one
Old 03-29-2014, 08:18 PM   #80 (permalink)
Default 450 size Auto Rotation challenge!!
[ame]http://youtu.be/tngEQrU92D0[/ame]
My entry from today's flight. Auto at the end.
Oxy 3 - MSH Mini Protos - MSH Protos Max 700 - Taranis
Thanks to Oxy Heli and MSH-Direct.com
Former Username: Code3Medic
Russell Harding is offline        Reply With Quote Quick reply to this message
