Go Back   HeliFreak > R/C Helicopter Support > Bergen R/C Helicopters
Bergen R/C Helicopters Bergen Intrepid 90 Intrepid Turbine Observer Industrial Twin Observer Turbine Support Forum
Old 03-24-2014, 11:16 AM   #61 (permalink)
ohh ok. there was one in there. I figure it keeps the thrust bearing off both races at the same time. thanks
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
Skookum support pilot
geomecc is offline        Reply With Quote Quick reply to this message
Old 04-29-2014, 04:16 PM   #62 (permalink)
another question. what's the best way to keep the 2bolts that screw into the top of the fan that holds the bushing with the plastic "hat" to connect the clutch to the fan? mine keep coming loose (3rd time). I replaced the bolts and cleaned the fan and bolts and used lock tight. fwiw I'm using a hanson g26 pro plus engine
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
Old 04-29-2014, 07:23 PM   #63 (permalink)
"Standard Blue" (Medium strength like Loctite 242 or 2033) should be adequate. I think that stuff is good to 150C so unless your clutch is slipping and generating a lot of heat, those bolts should hold.
I used 242 when building the turbine and haven't had an issue, even with the gas producer blowing +/- 450C gasses into the free turbine in the gearbox.
-Kevin
Skiddz is offline        Reply With Quote Quick reply to this message
Old 04-29-2014, 08:15 PM   #64 (permalink)
+1 on what Skiddz said. I've used 242 for years with no problems. A couple of other things come to mind to check. Sorry if this is too blatantly obvious but be sure the clutch full engages the bushings on the cooling fan and that the fan and clutch are perfectly parallel to each other. If they are tilted relative to each other, that wouldn't help and it doesn't take much
Good luck,
Steve R..
Intrepid175 is offline        Reply With Quote Quick reply to this message
Old 07-01-2014, 09:58 AM   #65 (permalink)
what other heli horizontal fin/boom brace would fit on the tail boom? i need it for my intrepid eb? chris u got any on hand by chance
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
Old 07-01-2014, 11:22 AM   #66 (permalink)
I do! Somewhere....
Chris D. Bergen
cbergen is offline        Reply With Quote Quick reply to this message
Old 08-23-2014, 05:39 PM   #67 (permalink)
is there any blade grips with 5mm bolt for any model bergen or can i buy a set that can me machined to accept a 5mm bolt.? i would do it but i dont wanna screw anything up
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
Old 08-25-2014, 07:46 AM   #68 (permalink)
Better to use a 5mm to 4mm insert in the blade root.
We DO NOT recommend drilling out the blade grips to 5 mm. It's unnecessary.
Chris D. Bergen
Old 08-25-2014, 06:27 PM   #69 (permalink)
ok. I noticed a lot of new blades don't come with them anymore.
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
Old 08-26-2014, 09:55 AM   #70 (permalink)
You can make your own from brass tube stock, or we sell them.
Chris D. Bergen
Old 09-24-2014, 09:10 PM   #71 (permalink)
my front canopy standoffs keep striping out. is there something better that people use for their canopy standoffs? I'm using rc booya in the rear standoff but I need something small in the front
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
Old 09-26-2014, 10:27 AM   #72 (permalink)
Which part is stripping out? Ensure the 12mm setscrew is centered between the Battery Tray Spacer and the front mount. Too much on one side leaves too little on the other...
Chris D. Bergen
Old 09-26-2014, 11:08 PM   #73 (permalink)
the side the canopy screws into always it seems front right. i did center the canopy stand off on the set screw going into the battery plate
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
Old 09-28-2014, 10:23 AM   #74 (permalink)
Are you losing that canopy thumbscrew? During flight maybe? And does the opposite side seem overly tight?
Chris D. Bergen
Old 09-28-2014, 12:13 PM   #75 (permalink)
I am losing it during flight but when I replace it I notice that all the threads are gone. no the other side isn't overly tight but I do make it pretty snug so the dont back out from vibes or what ever.
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
Old 09-28-2014, 06:25 PM   #76 (permalink)
I suspect you may have a high freq vibration, which can either cause the thumbscrew to over tighten, or loosen, in flight, in both cases wearing out the threads...
Chris D. Bergen
Old 09-28-2014, 08:38 PM   #77 (permalink)
where would be the usual suspects be in a situation like that?
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
Old 09-28-2014, 11:15 PM   #78 (permalink)
Tail rotor and engine are the two high RPM spots in a heli.. I'd start there.
-Kevin
Old 09-30-2014, 10:10 AM   #79 (permalink)
Engine/main drive train (clutch, bell) are the makers of high freq's...
Balance and straightness are a prerequisite, but engine tuning is the common culprit, too lean and high freq's result.
Chris D. Bergen
Old 09-30-2014, 05:22 PM   #80 (permalink)
if I was to get anew fan would you be able to balance it for me?
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
