Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage Fusion 50
Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum
Old 02-11-2011, 03:53 PM   #21 (permalink)
motor: Hyperion HS-4025-630
ESC: Robbe Roxxy 975-12
cyclic servos: Turnigy (MKS) BLS-950
tail servo: Turnigy (MKS) BLS-980
gyro / FBL: Spartan DS760
blades: TIG Z-Weave 600, Mavrikk G4 2Q
tail blades: stock
misc: 2x Turnigy Nano-tech 5S 4000mAh (?), ElyQ voltage reg., JR RD921
CX450PRO / Scorpion 2221-8 / Roxxy 940 / LTG2100T / Outrage G5 tail upgrade
CX450SEV2 / AXI 2217-5H / Roxxy 940 / LTG2100T / MicroHeli tail/cyclic levers upgrade
CX250SE / Scorpion 2206-3900 / Roxxy 918 / GP780 / MicroHeli tail upgrade
Peter_SVK is offline        Reply With Quote Quick reply to this message
Old 02-11-2011, 09:28 PM   #22 (permalink)
Scorpion 4025 630
Jr 8717 x3
Jr 8900 tail
Heli command hc3x
CC 80 hv
Bec pro
Dx8
Edge 600 fbl
12s
Team EMPIRE/ GAUI USA / Cyclone blades/ Scorpion Power Systems / YS Engines / JR Radios / Opti Power
kovar is offline        Reply With Quote Quick reply to this message
Old 02-12-2011, 09:49 AM   #23 (permalink)
Scorpion 4025-550
Ice 80a ESC
Sk720 and bus bar @ 8v
8717 yclic
Outrage 9088 tail
SWE 630 blades
2- Voltz 6s 3300 = 485 g each
Hyperion 2s 850 mah 49 g 1 flight
AUW = 3706 grams or 8.170 lbs Ready to Fly
Cheers, Glenn
Outrage Fusion 50 FBL SK720 12s Xera 4025-560,Kon.HV 80 ,JR8717,OR 9088 on 6v TP 6s 65c 3300's
Trex 700CHP FBL SK720 MX510,Kon HV 80, JR 8717,OR 9188, 6v, TP 6s 45c 4400's
Gernejr is offline        Reply With Quote Quick reply to this message
Old 02-12-2011, 01:18 PM   #24 (permalink)
Closed Account
Scorpion 4025-550
CC ICE 80HV
Mikado V-Bar V5 Full Size
BL 9180 Cyclic
BL 9188 Tail
Voltz 3300mAH 6s Packs x2 (12s)
Edge 623 FBL Main Blades
Stock Tail Blades
Bart101 is offline        Reply With Quote Quick reply to this message
Old 02-12-2011, 03:57 PM   #25 (permalink)
Scorpion 4025-630
CC ICE 80HV
CC Pro BEC
Spektrum AR8000 w/TM1000 Telemetry
Helicomand HC3SX
BL 9180 Cyclic
BL 9188 Tail
Mavrikk G5 Pro FBL - 600mm
Stock Tail Blades
Unsure of batteries, I've got a set of 3000 mah 5s packs for an EDF and several more 2650 mah 6s packs for a Trex 500. I was building the Fusion for 10s but could I run the Trex 6s packs through it as well? I'll likely order some 5s packs in the 3800-4000 mah range.
supertoyz is offline        Reply With Quote Quick reply to this message
Old 02-12-2011, 09:46 PM   #26 (permalink)
Skookum SK720
SWE 630 dc blades
Scorpion 4025-630 12T pinion
CC ICE 80HV gov high, throttle set to 62%
CC Pro BEC
BL 9180 Cyclic
BL 9188 Tail
2 Outrage NRG 6S 35C 3300mah
TEAM OUTRAGE RC
TEAM SAVOX
SKOOKUM ROBOTICS
Jason_Adamo is offline        Reply With Quote Quick reply to this message
Old 02-12-2011, 10:21 PM   #27 (permalink)
motor: Kontronik Pyro 700-52
ESC: Kontronik Jive 80HV
cyclic servos: Outrage Torque 9080
tail servo: Outrage Torque 9188
gyro / FBL: MocroBeast
blades: For now ZigSaw 600 mm (might change depending on performance)
tail blades: stock
misc: (Lipos / BEC / Rx)
2 - Hyperion 6s 2950mAh (35C) - Receiver pack Hyperion 2S 2500 mAh. (no BEC - Running all High Voltage)
Pitch settings +/- 15 collective (on FBL) and +/- 13 on cyclic.
im4711 is offline        Reply With Quote Quick reply to this message
Old 02-13-2011, 09:52 AM   #28 (permalink)
Originally Posted by Bart101 View Post
Scorpion 4025-550
CC ICE 80HV
BL 9180 Cyclic
BL 9188 Tail
Stock Tail Blades
That's mine as well.
TDR/VBar
Logo 600SX 12s VBar
MSH MINI PROTOS/CGY750
AcidDrink is offline        Reply With Quote Quick reply to this message
Old 02-13-2011, 10:08 PM   #29 (permalink)
Scorpion 4035-560
CC ICE 80HV
Microbeast
Align Servos
Voltz 4500mah 5s 35c Packs x2 (10s)
Mavrikk wide core FBL 600mm
Stock tail blades
John
-- Helidirect
-- VELOS
JohnThompson is offline        Reply With Quote Quick reply to this message
Old 02-14-2011, 11:15 AM   #30 (permalink)
Default Fusion
Fusion FBL kit
Scorpion HK-4035-530
Kontronik Jive 80+ HV
Helicommand HC3X Extreme
BLS251 tail servo
JR 8717's on cyclic
Edge Blades
still looking at batties.
cant wait to fly
pitts3 is offline        Reply With Quote Quick reply to this message
Old 02-14-2011, 02:48 PM   #31 (permalink)
Whats the target pack weight?
I am thinking about 1000-1100 grams would be a fairly light weight flight pack on a 600 size heli with a good balance of weight vs flight time, well depending on your head speed and flight style. My experience is based on a Logo 600, ideal flight packs IMO for 10S are around 4200 and 12s 3300.
rotaryguy is offline        Reply With Quote Quick reply to this message
Old 02-16-2011, 07:53 AM   #32 (permalink)
scorpion 4025-550 12t-13 pinion
SWE 630 dcn
v-bar v5.1 full size
outrage 2500 reciever pack
outrage hv 9080 cyclics
outrage hv 9088 tail
scorpion 90a 50v commander esc
spectrum remotes via v-bar
turnigy 3300 x 2 12s and turnigy 3000 x 2 12s batts
HV setup so no reciever
oh and the all important orange boom
Fusion 50 sk-720 ,Fusion 50 v-bar , Velo 90 v-bar Outrage uk field rep...
millerman is offline        Reply With Quote Quick reply to this message
Old 02-17-2011, 03:57 PM   #33 (permalink)
Guys pls post your setups...
Also the volts 3700 fit in the Fusion 50.. because the weight is not a problem..!
AP Logo600SX:Pyro 700-52 -Vbar-3x610 -bls251-Vbar GOv-Hw PL120HV-Thundepower
Logo6003dXera 560 - VbarGov - 3x8717 - Bls251 - Hobbywing PL 120Hv-Thunderpower
Cinestar 8 Cs gimbal - HoverFlypro - Tiger motors 710-Radians-Turnigy Plush 40A
MaSt0RaS is offline        Reply With Quote Quick reply to this message
Old 02-17-2011, 06:07 PM   #34 (permalink)
Default Fusion 50 setup
Mine is almost done here is my set up so far>
Fusion 50 FBL
Futaba GY750 flybarless system (as soon as it comes out)
Outrage BL 9180 X3 Cyclic Servo
Outrage BL 9188 Tail Servo
Scorpion 4025-550 Motor
Castle Creations Phoenix Ice HV 120 ESC
Castle Creations BEC 20A Pro
SAB 620mm Main Blade
SAB 95mm Tail Blade
Voltz 3700mAh 6S X4
TEAM:
CYCLONE BLADES
matt blaisdell is offline        Reply With Quote Quick reply to this message
Old 02-19-2011, 07:29 AM   #35 (permalink)
double post
John
-- Helidirect
-- VELOS
Old 02-19-2011, 03:42 PM   #36 (permalink)
Fusion 50 FBL
Skookum 720
CC Ice HV 80 ESC in set rpm 2125HS @ 96%
Scorpion 4025-550 motor 13t pinion
WR 14s Super BEC
8717 cyclic
Outrage 9088 tail
2- Voltz 6s 35c 3300
SWE 630 Blades
Stock tail blades
ATF weight 8.1 LBs
Cheers, Glenn
Old 02-20-2011, 09:48 AM   #37 (permalink)
can you tell me what are your flight time in several RPMs with the voltz 3700??!
Old 02-20-2011, 02:29 PM   #38 (permalink)
Gernejr,
What pinion and what set rpms did you pick? I plan using set rpm w/ the same motor and want 1800, 2000, and 2150.
HugoCraft is offline        Reply With Quote Quick reply to this message
Old 02-21-2011, 12:54 AM   #39 (permalink)
Fusion 50 FBL
14 tooth gear
CC BEC 20A Pro
Align 3G FBL
Align DS610 x3
Align DS620
620 Maverick wide chord pro blades
Turnegy 30C 6S3300 x2
RCBooya Canopy mounts
MA Whiplash-BeastX Fusion 50 3G FBL Trex 700E 3G FBL
Trex 600E 3G FBL (#1) MD500E fun scale Trex 600E 3G
Trex 450 SE V2 Trex 450 SE (Night Flyer)
AMA# 50163
Hangarace is offline        Reply With Quote Quick reply to this message
Old 02-21-2011, 08:08 AM   #40 (permalink)
Fusion FBL kit
Scorpion 4025-550kv w/14T
Kontronik Jive 80+ HV (using BEC)
Skookum SK-720 (sbus futaba)
Futaba BLS451's on cyclic
Outrage BL9188 tail servo
Edge 623 FBL Blades
joe_dejesus is offline        Reply With Quote Quick reply to this message
