View Poll Results: did you have a rusty shaft and/or a lousy setup on you cfx?
I had both, the corroded shaft and the lousy setup 2 18.18%
I had a rusty shaft, but the setup was OK 0 0%
My setup was crap, but the shaft was clean 4 36.36%
I did not have any of the two issues 5 45.45%
Voters: 11. You may not vote on this poll
Old 06-03-2014, 04:21 PM   #1 (permalink)
Default 300 CFX - rusty shaft and lousy setup poll
I wanted to check, how many of you also had two of the issues ootb with the 300 CFX.
Please answer only if you do own a CFX.
the question is about wether you had a corroded shaft tip under the rotor head, and if you also had a bad setup ootb (e.g. dial 1 at minimum, or servo arms not horizontal)
Active: 130X / 300 CFX /KDS 550 V2 / 350QX / lots of foamies / DX8 / DX6i
Retired: mSRX / 120SR / 300X / B-SR / HK450V2 DFC / mCPX (all versions)
Familyman67 is offline        Reply With Quote Quick reply to this message
Old 06-03-2014, 04:33 PM   #2 (permalink)
Default Re: 300 CFX - rusty shaft and lousy setup poll
I had a bad setup.
Sent from my VS930 4G using Xparent Red Tapatalk 2
Street Brothers motoclub
R1Ryder is offline        Reply With Quote Quick reply to this message
Old 06-03-2014, 04:35 PM   #3 (permalink)
Dial 1 @ minimum.
Unsure of the arms.
No rust on main.
Doom Buggy is offline        Reply With Quote Quick reply to this message
Old 06-04-2014, 12:29 PM   #4 (permalink)
thanks for the feedback folks
Old 06-04-2014, 12:43 PM   #5 (permalink)
I've never heard of a bird arriving with a rusty shaft, before. But I don't doubt if the birds spend a lot of time on humid cargo ships that rust or corrosion could eventually set in... But that would be a really good indication that they're going about it all wrong in their shipping, so I doubt that's the case. I just don't see how one could arrive with a rusty or corroded shaft. Would you mind sharing pics?
Uriah is offline        Reply With Quote Quick reply to this message
Old 06-04-2014, 01:46 PM   #6 (permalink)
check out this posting I did the other day, it includes the pic with the rusty shaft tip.
https://www.helifreak.com/showpost.p...7&postcount=70
Old 06-04-2014, 01:52 PM   #7 (permalink)
The Airetic
Nobody wants a rusty tip!
Seriously though, I know its an eyesore when the head is off, but is this really that big of a problem?
Free Agent....With standalone opinions.
KiloXray is offline        Reply With Quote Quick reply to this message
Old 06-04-2014, 01:57 PM   #8 (permalink)
Everything is fine on mine
vronny is offline        Reply With Quote Quick reply to this message
Old 06-04-2014, 02:03 PM   #9 (permalink)
to me ? yes it is. I had to use brute force to take the head off. Had I not done that, it might have become impossible to get it off in a few months from now, which would have meant to buy a new one.
Old 06-04-2014, 02:05 PM   #10 (permalink)
The Airetic
That's fair.
Do you think that now that you have it off, you can clean it up and oil it well enough for it to not be an issue any further?
Old 06-04-2014, 02:09 PM   #11 (permalink)
yes, I am positive on that one.
here's a pic of how it looked like after treatment with a type 1000 sanding paper.
Old 06-04-2014, 04:58 PM   #12 (permalink)
Wow, blade going .500 on setup so far. BNP (bind-n-pray)!
Go fly one!
Dustin Mustangs is offline        Reply With Quote Quick reply to this message
Old 06-04-2014, 08:45 PM   #13 (permalink)
As a follow up- Changed the dial 1 from full negative to dead center, feels fine.
Just did some hovering, piro's and small circuits in the backyard after the rebuild and BX walkthrough Horizon cust Svc - planning on ripping around tomorrow, will post a f/u...hopefully ill get the same results as everyone else.
Old 06-04-2014, 09:25 PM   #14 (permalink)
I had the bad setup and a rusted tail pitch lever bolt but the main shaft is ok.
Goblin 770 Tri-blade, Goblin 700 KSE, T-Rex 700X, Goblin 570 KSE, Goblin 500 USA, T-Rex 500 Pro DFC, Goblin 380 KSE, 450X, 300 CFX, 300X (3), 230 S, Blade SR, 180 CFX (2), 130X, Mcpx BL, Mcpx (2), Nano CP X, Nano CP S, Nano QX
n20dave is offline        Reply With Quote Quick reply to this message
Old 08-10-2014, 05:22 PM   #15 (permalink)
Dial#1 was at minimum
battery plug are very close to the motor they often touch and resulting less power
3 flights and stock tail servo is not burning and annoying main shaft snap like first 300x
it doesnt feel as faster like the 300X and need more input to lift but with carbon and metal part you get rid of vibrating but I would say I love better my 300X original, my CFX is 1,5 time heavier and feel like big helicopter well but blue canopy and no white part that you cant see. Put some carbon brace on your 300X and its okay!
Blade 300X all control by Devo8S with Deviation 3.0 firmware
Eflite ask-21 powered
Eflite Sbach 342
Walkera Super CP, Ladybird
dalid is offline        Reply With Quote Quick reply to this message
Old 09-22-2014, 07:36 AM   #16 (permalink)
I have a rusty tail bolt and a rusty shaft. Had a horrible time getting the head off.
Kinens is offline        Reply With Quote Quick reply to this message
Old 09-22-2014, 07:16 PM   #17 (permalink)
The Airetic
HAHAHAHAH
This thread belongs in the CFX forum.
Old 09-22-2014, 07:42 PM   #18 (permalink)
That's what SHE said.
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
