X7 Discussion and support of the Gaui X7 |
07-28-2014, 12:09 AM | #1 (permalink) |
Max Blade Length Gaui X7
Hi,
What is the max blade length that can be use with the X7 Thanks |
07-28-2014, 09:50 PM | #2 (permalink) |
As far as I know the x7 is fairly lenient. 713 still works with 115 on tail unlike some helis. Obviously no 800 though. What size were you thinking?
Team Empire/GAUI North America Great Hobbies Scott Gray Products iKon Flybarless |
07-29-2014, 12:50 AM | #3 (permalink) | |
Since I am new to the 700, X7 and I saw few blades that are little bit longer than the 700 blades 710-720's. that is why I ask. |
07-29-2014, 08:08 AM | #4 (permalink) |
Ah I see, yea the x7 is a big 700 then so you should be good with any blades in 700 series. As long as your not attempting a stretch I think you will be fine
07-29-2014, 02:20 PM | #5 (permalink) |
The Manual says 720mm max. with 105 Tailblades
08-04-2014, 05:43 AM | #6 (permalink) |
I know some who run 720. i have the rail 716
2 X X7 | Scorpion 4525 Ultimate 4+6T YY / Xnove 4530 525 | scorpion Tribunus 200II ESC | Edge 713 | Logo 690SX | Pyro 440 7+8T YY | Castle 120HV | X3 | 4S | HW 50A V2 ESC | Scorpion 2221 2050KV 9T D | SK540 / Brain2 | Mks |
08-04-2014, 01:31 PM | #7 (permalink) |
I'm going to be running the Align 700 with 105 tail. Previously, had 753mm with Rail 116 tail but crashed over the weekend and plan on going back to stock configuration. I thought about going with the SAB 710 blades but really like how quite the Align blades are on my buddies Synergy.
XL V2, Soxos 7.1L - Previous: Kraken 580, Nimbus, Protos 380, Kraken 700, Diabolo 700, Oxy 5/2, Logo 600 / 550SX, Protos 700, Synergy 516, Velos 880, Gaui X7 / X5, Goblin 380, Blade 120SR/180SR/ mcpx BL/300X/450XL, Align 700X/150/Leap 3D |
08-04-2014, 01:55 PM | #8 (permalink) | |
Re: Max Blade Length Gaui X7
08-05-2014, 07:32 AM | #9 (permalink) |
Yeah, it was a beast. I bought it from another HF on the site but in the end, I'm going back to original size. I don't have time to custom fabricate a bunch of parts and it was to big to get into my car anyway. Those blades were massive though. Just one was the size of my entire X5!
08-08-2014, 12:04 AM | #10 (permalink) |
I've run Rail 716's and Rail 116's on my stock length X7 without issue, although I would say it was a bit concerning, I still did fast tic-tocs and low HS. I ended up shredding the tailblades on a gravel takeoff though. The larger tail blades were completely unnecessary. Running 106's now.
Gaui X7 Tribunus 200A, Xnova XTS 4525-530, Xpert R2/T, iKon2 BT Gaui X5 HW 100A V3,Gaui 4020-910,KST, iKon[/FONT] |
08-08-2014, 12:48 PM | #11 (permalink) | |
08-27-2014, 09:27 PM | #12 (permalink) |
IMO, main blades around 700mm length are best for X7.
Bigger ones such as 715mm, although good to fly, but power consuming, have to got an excellent pair of power Lipo. I use Helix 695 for X7, amazing feeling, love it.
Gaui X7: Scorpion 4530/130A Opto, OMG H4 Servos, Micro Beast X Halo blades, OptiPower Ultra 5000mah 6s 50c, Futaba 14SG Team GAUI OptiPower OMG Servos Halo Blades USA field rep. |
08-28-2014, 05:51 AM | #13 (permalink) | |
Lower pitch for both cyclic and collective is more efficient. After that i tried a series of blades: SB 685 - very agile but you need high RPM to compensate for the length. Edge se 693- good compromise but less power Rail 716- too big! Due to wider cord. Flight times are roughly the same but more bog. The "old" edge 713 were the best for now. I still want to test SB 700 with higher RPM, or similar ones.
09-02-2014, 01:31 AM | #14 (permalink) | |
09-02-2014, 03:21 AM | #15 (permalink) |
My flight style didnt change when changing the blades.
Power increased and flight times remained the same...
09-05-2014, 11:18 AM | #16 (permalink) |
Just curious, what RPM is everyone flying, on a regular basis, and what blade size? Previously I had 753mm and was running 1900RPM. I've switched back to 700 (due to an incident with the ground) and curious what speed others are flying at this size. I have Align blades and the box says they're rated to 2200RPM which I was shooting for around 2000 or so. What flight times are you getting with your RPM, blade and battery size?
09-05-2014, 04:09 PM | #17 (permalink) |
You misunderstood my words, but anyway trust yourself and find the most suitable ones for yourself.
09-05-2014, 04:12 PM | #18 (permalink) | |
700 around length blades, hard-3D, no more than 4 minutes. If use 715 blades, same style, time reduced by half a minute. Optipower Battery 5000mah Ultra 50c 6s x2
09-05-2014, 06:04 PM | #19 (permalink) | |
I totally agree everyone needs to find what's good for them. numbers for me by the way: 713 edge blades medium to hard 3D - 4:00 with 3.8 per cell at the end (gens 5000/45C) with the 716 rails i get 3.78 per cell (bigger surface than the Edge).
