Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50 > Titan X50
Titan X50 Thunder Tiger Titan X50 Helicopters
Old 03-18-2014, 10:30 AM   #1 (permalink)
Default Redline 56 engine
Hey everyone,
I just got my X50f kit with a redline 56. I was reading several forums and I am getting mixed feedback for setup on this engine. So I am posting here to try an clarify some questions I have.
1. Do I run the shim supplied with the engine to run 30 % fuel? Some say not too but the manual says I should.
2. When breaking in the engine, did you follow the instructions for how many turns out you should be on your needles? People say they were burning engines in the break in process using the settings listed in the manual and therefore suggest not to follow the instructions. How many turns out did you go?
Thanks in advance.
TT e700, Titan x50f, Trex 450 Pro ,MCPX BL,MQX
pbpro954 is offline        Reply With Quote Quick reply to this message
Old 03-18-2014, 01:32 PM   #2 (permalink)
I am currently running a 53. I have not run a 56. My 53 came with extra shims for 30% fuel so I put them in.
I followed the manual on the needle settings as far as getting the engine started.
I found that after a short hover when landing the engine was running on longer than I like before settling back to a tickover, so I richened up the idle screw. Factory is to have it flush with the case mine is now sticking out a bit. For the main needle I just keep adjusting it so that I get a little warmth on the back plate. As it goes cold so I lean the main a couple of clicks and keep going. Obviously if I landed after a minute or two and found the back plate hotter than I like then I would of richened up the main.
I can only assume people burnt up their engines because they can't work out that the engine was lean and just accepted what was in the manual. The manual should not have such an error but to blindly keep going when I expect the engine sounded horrible is down to the user at the end of day.
Andy from Sandy is offline        Reply With Quote Quick reply to this message
Old 03-18-2014, 09:18 PM   #3 (permalink)
Default Re: Redline 56 engine
I believe they released an addendum about the break in process but I could be thinking of a different engine. I cant remember where I put mine for break in. I am using 30% and I put the thicker shim in and it has had no issues. I am almost through my 4th gallon of fuel. Only issue I have had was the needle valve body coming undone and the muffler coming loose repeatedly but its double nutted now.
Trex 250 Plus, Trex 550 Pro DFC, Trex 500L, Trex 450L, Blade 180 CFX.
Vaeloron is offline        Reply With Quote Quick reply to this message
Old 03-23-2014, 11:46 AM   #4 (permalink)
Who did you buy your Raptor from?
3drcbuilder is offline        Reply With Quote Quick reply to this message
Old 04-05-2014, 12:37 AM   #5 (permalink)
I have over 6 gallons on my X50F with the Redline 56. I have always run it with Rotor Rage 30% fuel with no extra shim. I just took it out and installed it just as it came.
I have done some updates as it was going through the fuel. I bought the heli last October I believe. It has been a great heli with lots of power.
To keep your muffler tight and never have any problems with it coming loose you need to tighten it again once it is flying and has some heat in the engine. Land the heli after about 2 min of flying and tighten them muffler bolts while its still hot and you will never have them come loose again. ( well I haven't anyway ) I have been doing this for over 10 years flying rc helis and mufflers don't come loose.
Tighten it while it is still hot is the key.
Good luck and have fun with it
skytrekin is offline        Reply With Quote Quick reply to this message
Old 08-17-2014, 12:38 AM   #6 (permalink)
I'd sure like to come up with a new in box 56. My 53 with the OS carb has been a blast. I am running the YS 60sr now, but I don't expect it to live long. I have an OS 3 needle carb ready when I come up with a 56.
= Rb43 =
Rob43 is online now        Reply With Quote Quick reply to this message
