Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > 4#3, 4#3a, 4#3b, 4#3Q
4#3, 4#3a, 4#3b, 4#3Q Walkera 4#3, 4#3a, 4#3b, 4#3Q Helicopter Support
Old 01-13-2010, 07:41 AM   #301 (permalink)
Originally Posted by jperkosk View Post
The day will come that Walkera puts HH giro on their micro helis, but it's not here yet...
The new 4G6 and 4#6 both have a HH gyro. The days of wandering tails are long gone with these new helis... Walkera's new line up is the CB100 for "easy indoor flight", the 4#6 for "quality FP indoor flight", and the 4G6 for "quality CP indoor flight".
Steve Joblin is offline        Reply With Quote Quick reply to this message
Old 01-13-2010, 12:26 PM   #302 (permalink)
You see? It's not that difficult to be a prophet after all, especially after the fact...
Jerry
jperkosk is offline        Reply With Quote Quick reply to this message
Old 01-13-2010, 09:35 PM   #303 (permalink)
Many thx!
hiwattheli is offline        Reply With Quote Quick reply to this message
Old 02-19-2010, 09:23 AM   #304 (permalink)
Default Bell-Hiller in 30 seconds!!
Well not exactly, but this mod gets your 4#3b responding to control inputs as fast as the Bell-Hiller head. I call it, the Timewerx-Hiller head
But as the saying goes, "you get what you pay for". It's not as precise as a true Bell-Hiller head. The only advantage is any weight or drag added to the system is negligible! And if you're fast at tying knots, you can do the mod in under 30 seconds
One thing that would pose a challenge to this mode is getting the right tightness. Think of the tightness as the 'Bell-Hiller mixing ratio' or something like that. Tighter gives more Bell Ratio, better response time, faster cyclic rates, but your 4#3b might demonstrate gyroscopic precession effect. Lose gives more Hiller ratio, more docile and will be easier to handle.
Okay, here's the problem if you set it too tight - you will get incredibly sensitive cyclic... and... if you try to give elevator inputs, you will also get a bonus roll of the same intensity, conversely with aileron inputs too! How's that to test your piloting skills!
timewerx is offline        Reply With Quote Quick reply to this message
Old 02-23-2010, 01:12 PM   #305 (permalink)
I don't get what you are trying to say here???
Cheers, OD.
If you make a mistake and learn from it, that's progress
2 x Nano heli's - now passed on to Megan, HoneyBee V1.....Awaiting test flight, T-Rex 250 V1, Hitec 5084MG tail servo, DX6i, Walkera 4#3A (it's in fairly good hands Bugster).
oliverdots is offline        Reply With Quote Quick reply to this message
Old 02-23-2010, 07:48 PM   #306 (permalink)
got any videos of how this flys?
- Trex 700 LE (Spartan Quark, Multigov Pro, 91H + Outrage); JR9503 & DX7
- Trex 600 Nitro Pro (Futaba 611, Mutligov, Align 55 + Outrage)
- Trex 450 Pro (GP 750)
- 2 * Trex 250 Pro (GP 750)
- Walkera CB100/4#3a/4#3b/4#3b DB/5G6
davidz58 is offline        Reply With Quote Quick reply to this message
Old 02-24-2010, 08:31 AM   #307 (permalink)
I'll try soon(got to get used to the new handling first), I did other mods in addition to get as much cyclic rates as possible, it's insane and almost flipped it! Too bad it's just FP
Old 02-26-2010, 09:01 PM   #308 (permalink)
LL-Cool-T is offline        Reply With Quote Quick reply to this message
Old 02-26-2010, 09:03 PM   #309 (permalink)
Here is an interesting mod to add tail supports... kind of gives the 4#3 a "proper" look!
It bolts on using the existing battery holder mounting screws. It uses two 30mm lengths of 1mm carbon rod and one small brass nut and bolt. The Rod fixings and boom shackle are made from 0.016" aluminium sheet.
This mod completely removed tail wag.
Do u have a photo of the modification and where do I purchase it?
Old 03-05-2010, 11:39 PM   #310 (permalink)
X-Plane runs on
Mac OS X, Windows, Linux
TowPilot is offline        Reply With Quote Quick reply to this message
Old 03-12-2010, 06:15 AM   #311 (permalink)
I just did, pls check the 4#3b threads!
Old 03-15-2010, 04:07 PM   #312 (permalink)
Default walkera 4#3 problem
Hi everyone,
I am trying to get this little beast in the air again. It won't lift up one inch from the ground . It has brushless main motor installed. It is all metal head and swash but linkages are pretty loose. I would like any advice how to get it back in the air!!!
AceTheAxe is offline        Reply With Quote Quick reply to this message
Old 03-15-2010, 04:45 PM   #313 (permalink)
These batteries age pretty quickly. Have you tried a new one?
Besen is offline        Reply With Quote Quick reply to this message
Old 03-16-2010, 08:33 AM   #314 (permalink)
Originally Posted by AceTheAxe View Post
Hi everyone,
Loose linkages are normal and shouldn't affect it being able to leave the ground. If the lipo checks out, check the gear mesh which needs to be loose - looser than on bigger helis, just tight enough so the teeth don't have any chance of skipping.
Are you plugging the lipo into the esc and not the 4in 1 ok?
Dusty
Blade 400, mSR, mCPX - Sonix SX450SE - Walkera 1#A, 4#3, 4#3A, 4#3B, 4G3
Dusty1000 is offline        Reply With Quote Quick reply to this message
Old 12-12-2010, 08:20 AM   #315 (permalink)
What motor did you put in it? There's a chance the pinion is slipping. This is going to sound silly, but is the spur gear pinned to the shaft?
that's what I can think of, beyond what has already been suggested. A known, good, fresh batt would be a good start. How are the wires/connectors? Any corrosion in the batt connection?
regards,
Bill
Air Vaca is offline        Reply With Quote Quick reply to this message
