bavarianDEMON/HeliCommand Factory Sponsored Bavarian DEMON and HeliCommand Support |
02-03-2014, 03:09 PM | #1 (permalink) |
How to setup bailout using only one P-mix
Hi guys,
I was trying to zero my cyclic on my Futaba 14sg when using bailout. The problem was I needed 6 mixes: 2 p-mixes for self level (for 2 different gains) 2 p-mixes for bailout 2 p-mixes for zeroing the cyclic (1 for ail and 1 for ele) but my radio only has 5 p-mixes. I think I have found a way to setup bailout using only one pmix instead of two. Here is the mix: and here is an example of a p-mix to zero elevator (the same applies with aileron) I have not flown the heli this way but so far everything looks as it should on the transmitter servo screen, the diagnose tab and on the bench. Tell me what you think. |
02-06-2014, 01:22 AM | #2 (permalink) |
FWIW I tested these settings yesterday on my 7HV and they work perfectly.
02-07-2014, 12:55 PM | #3 (permalink) |
Nicely done, thanks for sharing!!
03-31-2014, 10:04 AM | #4 (permalink) |
CHC Benefactor
Really appreciated!
Just double checking, for the mix #4 it is AIL->AIL? The reason I ask is that I'm confused as to why to use AIL as a source for the SL mixes. Just a quick note: it took me a while to figure out how to get SH as mix source for mix #3. For anybody having trouble just choose h/w under source on second page then the switch list will pop up. Cheers. |
04-01-2014, 02:17 PM | #5 (permalink) |
Yes, it is AIL ->AIL.
Mixes 1 & 2 are for the different gains for self level. Mix 3 is the one that activates the bailout. I use the offset to overcome the fact that the 14sg is limited to 100% in the mixes. Mixes 4 & 5 neutralize cyclic inputs during bailout. As far as using AIL for SL, honestly I just used seasick78 videos without putting much thought into it. I don't use SL much (actually I only used it a couple of times to see how it works) so never really bothered with it. |
04-01-2014, 07:12 PM | #6 (permalink) |
CHC Benefactor
Thanks. I don't intend to use self level either but setting it up just to try out since it is available. The curve on mix 3 looks funky but a cool solution
Cheers. |
06-10-2014, 02:16 PM | #7 (permalink) | |
The Mix 3 is very similar to the DX8 Mix, just that the screen is a different format.
Thanks Taz, very much appreciated. Jim Quote:
~Jim~ Goblin700 Gasser TRM-300, BD Axon, Align700E w/HC3SX, and a Goblin 380 w/BD3SX, using Futaba 14SGH |
06-10-2014, 07:14 PM | #8 (permalink) | |
I must be missing something...
Helicopters Don't Fly - They Beat The Air Into Submission Logo 500SE Minicopter Diabolo 700 Banshee # 45 700 LE and 850 |
