Old 01-30-2013, 03:22 PM   #1 (permalink)
Default help with problem elevator servo
Hello , i have a second hand , but brand new outrage N50 with beastx ,, i had my first flight last weekend , this is my first beastx , ( other hellis with 3gx and ebar systems ).
the problem what i have , pith down = tail go down ,,, pith up = tail go up ..in flight no big problem , only in hover , but imposible to make a decent hover for some min ..
I have controld all set ups again , same problem , but this evening i find the problem ,,,
When i move the stick about 5 mm pith donw , the 2 aileron servos are going down by about 2mm , but the ellevator servo is not moving ,, when i put the pith stick about 15mm all servos are moving down , only the elev servo is moving less in the beginning ,, when i move fast the pith up about 5mm and down about 5mm , both ail servos are moving , only the elevator servo dont move ???? ...
i have changed this evening all 3 servos with new ds610 ,, same problem ,,
also changed the receiver with new one ,, same problem ,,,
Is the beastx the problem ??? all mechanic is ok , no biding ,,ballinks are free moving
Manny Thanks
hepat911 is offline        Reply With Quote Quick reply to this message
Old 01-30-2013, 03:36 PM   #2 (permalink)
hello , i use the 120°swashplate in the set up ,,
Old 01-30-2013, 05:52 PM   #3 (permalink)
To confirm your difficulty. You apply positive pitch to climb, or maintain altitude for a hover, or the reverse, and you have some elevator interaction, causing it to move forwards or backwards, as a result of the odd elevator movement?
Perhaps you have mixing of some sort enabled in the radio? I know the manual is clear not to do this, but I thought I would just mention it. Single servo, mechanical, no mixing, however it is described for your radio, is how it should be. Only the MicroBeast should be programmed with the 120 degree swash setting. Plus all trims and sub-trims to be 0, in your radio etc.
Let us know, and we can go from there.
Cheers
Sutty
Regards, Sutty
sutty is online now        Reply With Quote Quick reply to this message
Old 01-31-2013, 04:08 PM   #4 (permalink)
Default BEASTX
Hey , i did one compleet new set up ,with new reset program in Tx ,and same problem .
Both servos ail and pith ( back side off helli ) are moving with stick , while elev servo ( front off the helli ) is not moving ,, this when i use small stick movement ...
This is also the reason why the helli is going tail down with small negative pith and tail up by small positive pith ..
i miss the first 2mm on elev servo by pith negative and positive ,,
when i use the elevator , servo work perfect ,,, 1mm on tx is also 1mm on servo , its only in the pith movement ..
i start to build the new NX4 and have one new betsx coming next week , i try the new beastx first on this Outrage N50 , and see if i hve the same problem ....
Manny Thanks , Greats
Old 02-04-2013, 06:27 AM   #5 (permalink)
Hey problem solved ,, yesterday on the field reset 2 times again , afther the second time all work perfect now ??
Greats Patriek
