Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 03-16-2012, 04:05 AM   #21 (permalink)
Mine arrived this morning too...
Nicely cut lower battery tray and long ESC plate, and a bit disappointing blade caddy...
Groucho_ is offline        Reply With Quote Quick reply to this message
Old 03-16-2012, 05:00 AM   #22 (permalink)
Didnt like the look of that caddy anyway, ordered the Curtis Younblood things that seem to be the most appropriate.
LOGO 500SE & 600SE & 600SX
Synergy E7 -
N7 - N5C
zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzTDR + II
Alun
CyprusFlyer is offline        Reply With Quote Quick reply to this message
Old 04-27-2012, 04:03 PM   #23 (permalink)
Hey guys,
Next week I will have many new products back in stock-
TDR Frame Braces
GMAURO Motor Mounts
Croco 30mm Motor Mounts
TDR Stacked V-Bar Mounts
TDR Bracket V-Bar Mounts
Checkout www.rmqproducts.com for more info.
Rob
heli21 is offline        Reply With Quote Quick reply to this message
Old 04-28-2012, 11:34 PM   #24 (permalink)
Never heard of the bracket V-Bar mount and didn't find a picture. Could you please describe it? Thanks!
Marcos
Banshee #27, 2x TDR, Diabolo, Logo 690SX, Raptor E700, JR Sylphide E12 EX Super Gracy, Voodoo 600, Voodoo 400, Logo 550SE, Logo 400SE, JR Forza 450. Mikado Vcontrol.
marcosp is offline        Reply With Quote Quick reply to this message
Old 04-29-2012, 05:12 AM   #25 (permalink)
FYI, I just learned that frame bracers are not compatible with Jan's original frame stiffeners, bottom bolt of the bracers overlaps with top of frame stiffener and washer.
So, unless you are willing to "shave off" a bit of Jan's frame stiffener (including two washers), these two can't be installed together, which is a bit of shame because both are great upgrades.
TDR/VBar
Logo 600SX 12s VBar
MSH MINI PROTOS/CGY750
AcidDrink is offline        Reply With Quote Quick reply to this message
Old 04-29-2012, 10:40 AM   #26 (permalink)
That's not good news... I'm ok with the braces alone so far though.
Marcos
Old 04-29-2012, 12:38 PM   #27 (permalink)
Well, it's about 1-2 mm overlap based on a picture posted on another forum.
I me really gutted by this, was looking forward to have both and make the frame really stiff, but I can't really convince myself to shave off washers (carbon part of stiffener would be ok) as in my opinion that would make Jan stiffeners weaker. Your mileage may vary, some people will probably go for it.
TDR/VBar
Logo 600SX 12s VBar
Old 04-29-2012, 12:44 PM   #28 (permalink)
I have a few guys running them together but slight modification is needed. Its a bummer but my testing showed, even with a Xera 4530-500 and a Scorpion 4525-520LE flying hard 3d/speed flying, the brace is all you need. Trust me when I say, I'm not easy on my machines...
If I thought Jan's was better I would of made my own instead of the braces a while ago
Marcos, the bracket Mount is a very clean and elegant mounting solution for the full size vbar or other GPS systems etc.
You can see more in this topic
https://www.helifreak.com/showthread.php?t=401179
I'm hoping to have them ready for shipping around Mid-Week
Rob
Old 04-29-2012, 01:02 PM   #29 (permalink)
Rob, if you ever make another bacth, do you think a 2-3 mm less tall brace to make clearance for Henseleit frame stiffener bolt, would be possible and make sense?
TDR/VBar
Logo 600SX 12s VBar
Old 04-29-2012, 01:17 PM   #30 (permalink)
The Brace was designed to rest on top of the bearing block but it could be simply moved up to allow for more clearance for Jan's stiffener.
thanks,
Rob
Old 04-29-2012, 02:40 PM   #31 (permalink)
Aha, so i hope i made the holes right, because i used the included template to drill, without bearing block attached.
But the brace is enough for 4525-4530 motors, or not?
- TDSF in a box...
- TDR #2, Scorpion 4525LE, PowerJive, MKS HBL950/980, Vbar
- TDR #1 (stock, sold at 700+ flights), e-Revo, Protos 500, Jeti DS14
jointer is offline        Reply With Quote Quick reply to this message
Old 04-29-2012, 06:02 PM   #32 (permalink)
Just shave a mm off of Jans brace and use both. Took 10 min and both work great together. It does not weaken jans brace at all. It's just a bit of overhang.
TDR, Srimok N x 2, Banshee 31, Dune!
jhunter is offline        Reply With Quote Quick reply to this message
Old 04-29-2012, 06:53 PM   #33 (permalink)
It will work great with those motors!! Any motor that fit between the frames will fit the brace.
They are in stock on my website as of tonight
Rob
Old 04-30-2012, 01:46 PM   #34 (permalink)
Rob, i already have 2 of them, but i wonder why use both the brace and Jans frame kit, i thought your brace is the best solution and should be better stiffening then Jans kit?
- TDSF in a box...
Old 04-30-2012, 04:05 PM   #35 (permalink)
Jointer-
I had just micks brace on my TDR. First flight on my new 4530le I rubbed the frame. I installed jans brace with micks and now it is fine. I believe Micks brace might be the better of the two but together the frame is very stiff. It's an easy mod to make both work together.
Old 04-30-2012, 04:27 PM   #36 (permalink)
Thanks, i have only 4525LE, so i hope it will be enough.
I do not want/need to order anything from Jan right now.
- TDSF in a box...
Old 12-02-2012, 08:09 PM   #37 (permalink)
Should be installing Robs V-bar mount in the next two week or so. Will post some pics.
Spinny02 is offline        Reply With Quote Quick reply to this message
Old 12-06-2012, 03:47 PM   #38 (permalink)
I got the Vbar mount on Spunky. Very nice bit of kit if you ask me
The difference between knowing your s**t and knowing you're s**t!
Optipower - Kontronik Drives
jamin_00 is offline        Reply With Quote Quick reply to this message
Old 12-07-2012, 09:38 AM   #39 (permalink)
I also have the VBar mounr.
Would have been better, in my opinion, if all the bolts were countersunk.
John
EX-HeliFreakSwag.com guy
(arthritis got the best of me)
thehatguy is offline        Reply With Quote Quick reply to this message
Old 12-07-2012, 01:17 PM   #40 (permalink)
John
Oh, thats not the mount I got on Spunky?
