Flight Stabilization Flight Stabilization |
07-12-2012, 11:21 AM | #21 (permalink) | |
I'm sorry ...did I miss something here???? Where is "everyone" accusing ALIGN of anything?
MSR x1 / mCPX x2 / 450 x4 / Chaos600 test bed / Chaos600 Air-Wolf / American WereWolf 800 / KFrame800/900/1000 / Assorted Fixed Wing JR9303 / JR9503 / Futaba10CHP |
07-12-2012, 11:31 AM | #22 (permalink) |
I have a feeling vojta works for Align...
07-12-2012, 12:06 PM | #23 (permalink) |
I don't have an APS, but I'm a Ace Onel user. Going through the setup and checking direction of movement is always a must. But i must admit i also went through the setup with a fine tooth comb and happen to miss the Pitch direction and was reversed. When i flipped the switch to auto the heli plunged very fast but was able to flip out of auto and regain control. Make sure you check the pitch direction in Auto mode also not just in 3gx mode!
Felipe |
07-14-2012, 02:34 PM | #25 (permalink) |
Neither Align, nor Captron (HeliCommand), just curious system analyst. So, nobody interesting in the cause of the crash? No info on RX,3GX,APS connection used, TX configuration, flight mode used, gyro gain setting for APS mode switching, flight time for APS settlement, set of preliminary tests carried out, etc. What was the reason for this thread?
vjj TRex 700L Dominator TOP 3+3 Speed TRex 600EFL PRO DFC BL750MX w/Performance Booster |
07-15-2012, 01:00 AM | #26 (permalink) |
So you have something to be mad about and reply
07-15-2012, 07:54 PM | #27 (permalink) | |
align gets 900.00 a pop
and cant make a english vid..........wow
07-16-2012, 10:24 AM | #28 (permalink) |
It does have English sub-titles. Tell you what, this is the telephone number of Align headquarters in Taiwan, 886-4-25279117. Give them a call and see what the language of conversation is. Where is it chiseled in stone that the spoken language of a video HAS to be in English?
MQX Quad,Align 550E/NazaH/GPS,Align450 Pro/CPII, Flame Wheel F450 Quad NazaM/GPS/GoPro3, Blade 350 QX/ GoPro3 Never lend money. It causes amnesia. |
07-16-2012, 12:17 PM | #29 (permalink) |
This is sad.
Been thinking about getting a system to help me improve my flying (save my arse!). I also don't know why so may think Align is being attacked. They have good and bad. And who says they should have English vids ect...it's not like English speaking people are it's largest customer base! Seriously, they make some good stuff and a lot of $, I'd think they would quit alienating their market base. I.E. hire someone to make clear English instructions for the majority of the people buying their products, geez. Anyway, interesting reading and hope to make my decision on which system to get soon. Cheers, Ken
Sigma, MCX, MSR, BOL, B400 BSR, EXI 450 Pro FBL, mCPX Align 500ESP FBL AXN FPV |
07-16-2012, 06:35 PM | #30 (permalink) |
@Daddy check out the helicommand hc3sx units can get them around $450 these days if you look around, best bailout system nobody else comes close, best horizon level system that turns your FBL Heli into a co axial Heli it works that well for learning and dialing down till you can fly better and better.
Doesn't have GPS return or position hold but depends how useful those are to you. |
07-16-2012, 09:45 PM | #31 (permalink) |
Oops ... Just did that?.. Or close
I spent two days installing DJI WK-h lite and within two flights had a major... My fault! Everything seemed perfect but my pitch was wrong.. My swash plate was good with my stick but backwards with the baro altimeter. So the higher it went the higher it went.... I flipped the switch to manual and roceeded to fall to earth about 50 feet.. It all happened ssooooo fast.
The lesson is when overwhelmed with NEW it is easy to misunderstand or just miss something. In this case there was a checkout procedure on another page I didn't see or understand. It all seemed so cool until I hit alti. Sitch. I got off with a set of blades, and some minors parts needed and a cracked canopy. had the 600E for years so it kind of bummed me out. Three days later and things are beginning to work nicely. When we give up control to a smart dumb machine we best check our work. Now I just need to get a DJI GPS to upgrade to the full version from the lite. |
07-16-2012, 09:58 PM | #32 (permalink) |
DJI mode switch
Anyone understand the DJI WKH mode switch and auto take off.. Can't seem to get the throttle to work in atti. Have to hover in manual then go into atti mode even (method before latest firmware) though I upgraded to latest firmware. when landing throttle won't shut down until I switch back to manual then I have no throttle control (as in cant fly again) until I unplug and start from scratch... Sure I am missing something.. Read the instruction about 1000 times and still can't seem to figure out. Old use some assistence.
07-17-2012, 10:27 PM | #33 (permalink) |
dJI WK-H
1fastt2 if you are still upset I have a 2 week old DJI WKH lite I will swp you, in perfect condition. Seriously! .?
07-23-2012, 10:57 AM | #34 (permalink) |
Hey,
I am desparate to find a good source of info for this unit. Sound sto me like the op set Alim to the left not right and the heli rolled over inverted and crashed. Has anyone extended the control unit to GPS unit cable yet? I can't find the right connector and so was thinking about cutting it adding some more length in. but I am worried I may make an aerial out of the long cable ? Basically for my ap ship the batteries are on the boom fit where the GPS unit sits which by all accounts is not a good idea. Anyone got any pointers they would like to share? |
07-23-2012, 03:40 PM | #35 (permalink) | |
BEE_CAZ
Because a bad translation, means bad crashes..........and on the web i count 10 so far......so 2000.00 bird, and a 900.00 align.........makes nice paper weight,
i think if i had the money, and someone was selling their already setup bird, i would go that direction......i bought a flymentor and it flew into a wall.......but the cost was 300.00 lost.....all clone stuff.....but i do got a new flymentor, and i did work it all out and i love it.... MY2CENTS Quote:
07-23-2012, 05:17 PM | #36 (permalink) | |
"You can always tell a pilot,but not much" Gaui X 5 Phanthom 2 |
07-23-2012, 05:48 PM | #37 (permalink) |
Same thing happend to my buddy 550 every thing was good went to aps straight down same outcome now he's afraid to play with aps system maybe align is using wookong or helicommand on there video typical align not testing there hardware properly ..
Sent from my SCH-R920 using Tapatalk
Logo 500se V-bar Trex 500 V-bar Trex 550 V-bar Trex 600 V-bar |
07-24-2012, 05:46 AM | #38 (permalink) |
The system works well. The misunderstanding from conversations I have been having are its for or to help beginners. While to some extent that may be true you must be a competent heli pilot to set this up, this means comfortable in all orientations upright and inverted.
Fly in 3GX mode and the heli is unchanged APS mode if you've installed the equipment wrong or set AiLim or EleLim backwards then when you switch to APS your heli will invert and head for the ground. just flick back to 3GX recover and land. |
07-25-2012, 01:33 PM | #39 (permalink) | |
I know that you do not have to be a good pilot to set one up. I am a good builder and can precisely follow written directions. My job and livelihood depends on it. I am a sub-par pilot at best, I'm not bad on Phoenix but awful on the real thing, that's why I had my friend fly it to do the necessary tests. After all tests were done I did semi-autonomous take-offs and landings and flew it around in both 3GX, APS and GPS modes. Flying in APS mode does not teach you how to fly a CP heli. To move the heli around in APS mode you have to lay into the cyclic. When you let the stick go the heli stops and hovers. I believe that even a coaxial won't do that! This is just my opinion on what I have experienced and opinions are like... well you know what I'm getting at! SN |
07-31-2012, 10:56 PM | #40 (permalink) |
I'm at a complete loss as to how a heli could roll over and invert itself if everything on the bench passed. Not being critical but if you put it in APS mode and check all of your stick movements, tilt test and lift test then why would turning blades make for such an extreme effect?
I ask this because I'm planning on maidening one myself in the next couple of days. |
