Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 06-08-2012, 02:51 PM   #1 (permalink)
Arrow Post your TDR setup here, please :
Just realized there's no dedicated TDR setup thread here, like we have in the minicopter section, and the "show your TDR" pic thread can be tedious to sift through if you're only looking for TDR setups...
I'll go first:
- 2011 TDR
- Pyro 700-52, 14T pinion
- PowerJive 120+ HV v9, mode 4+9, 5,6v bec, 800mah bufferpack
- 3x BLS 253
- Full size V-bar 5.2pro/ BLS 251
- Futaba r6008hs rx
- GCT/ Mavrikk 710 FBL
- SAB 105mm
- Micktech NACA duct and frame X-brace
minicopter Diabolo, Henseleit TDR, X50e, X50n, Raptor 50
Futaba 2.4 GHz
DT75 is offline        Reply With Quote Quick reply to this message
Old 06-08-2012, 03:41 PM   #2 (permalink)
Sold TDR:
- 2010 TDR, fixed head
- Pyro 700-52, 14T
- PowerJive 120, v9 (if i remember), mode 11, 6V, no buffer, +P +I -Smooth and timing to +12 for best performance
- 3x BLS451
- 1x BLS251
- mini Vbar black
- 2x Spektrum sat
- Henseleit blades, Radix FBL 710, then SpinBlades white 710 for long time
- Edge 105mm
- Tenax canopy mounts, replacing tail clevis with ball link, CF plate over the miniV (similar mount like dual Vbar mount from Rob)
- 2x Hyperion 45C 2x6S 4200mAh (2x 300 cycles) and later 2x6S Billowy 50C 5200mAh again two pairs (2x 50 cycles)
- sold after about 700 flights, no failures except unscrewing servo arms (not loctited) and the resulting crash around flight 450
- Pyro bearings wasted after 100 flights, after replacing and leaving gap for the smallest bearing another 300-400 flights without replace
TDR in build:
- 2011 (three tail bearings, two tail rod guides), fixed head (white inserts)
- Scorpion 4525LE + Mick NACA and frame X brace
- YGE 160HV with heatsink (does not fit inside frame! working on that)
- 3x JR MP82S WV
- 1x Outrage BL9188
- silverline Vbar with Rob dual mount, will use Vbar gov
- WR Super BEC will be set at 8.4V regulated
- the same 2x Spektrum sats until Jeti thumb radio will be released (should be 3-4 months from now), then RSat 2 + Jeti 200A MUI probe
- SpinBlades MattBlack
- Edge 105mm (maybe MS Composit black later)
- Heli-Innovations landing gear (longer ones)
- will use my 12S Billowy packs, with an option to go 14S later
I am hoping this one will be so good it will last for 3+ years, because i love TDR and i want to have it loaded as best as possible, but not to overpower it.
I must say that after getting new strong packs and also after tuning the Jive, the power was just right and it was a real pleasure to fly it. But the new kit is waiting for looong time and so i sold the old one to be forced to build new, better one.
- TDSF in a box...
- TDR #2, Scorpion 4525LE, PowerJive, MKS HBL950/980, Vbar
- TDR #1 (stock, sold at 700+ flights), e-Revo, Protos 500, Jeti DS14
jointer is offline        Reply With Quote Quick reply to this message
Old 06-09-2012, 07:59 AM   #3 (permalink)
  • 2011 TDR with stiffener kit; white bushings black-red o-rings; Heli-Innovations landing gear
  • GMauro Pyro 700-575kv; 13T pinion
  • GMauro motor mount
  • PowerJive 120 v9; mode 4-9; 6.0v; +P +I -smooth auto timing.
  • mini Vbar 5.3
  • Spektrum satellites
  • 3xBLS451
  • BLS251
  • Radix 710 V2
  • Radix 105
Henseleit TDR; Synergy E7; Hirobo EMBLA.
Fabio
7.62x51 is offline        Reply With Quote Quick reply to this message
Old 06-09-2012, 08:41 AM   #4 (permalink)
I thought this too with the vids so created a vids post but its like no one flys the TDR?
Vids are hard to find and again it gets tedious going through that long thread to find them but I do like looking at the awesome pics
Anyway heres mine.
Spec now:
2011 TDR with some extra bits
Kontronik Powerjive
Kontronik 700-52
Rotortech 710s
Radix 105's
Futaba BLS252's
Futaba BLS254
Spec very soon:
2011 TDR with some more extra bits.
Kontronik Kosmik
Scorpion 4535 550 LTD edition
One off special blades (can't mention who from )
Radix 95mm tails
Same servos
The difference between knowing your s**t and knowing you're s**t!
Optipower - Kontronik Drives
jamin_00 is offline        Reply With Quote Quick reply to this message
Old 06-12-2012, 02:10 PM   #5 (permalink)
3D TDR:
3x BLS156HV / BLS256HV
Hercules BEC @ 8.4v
HeliJive 120HV
Mini Vbar
Xera 4530-500
14t pinion
SB Matt Black / Radix 110
Heli-Innovations short landing gear
Speed TDR:
3x BLS451 / BLS251
Jive BEC @ 5.6v
Jive 120HV
Mini Vbar
Xera 4530-500
Croco mount
15t pinion
Radix 710 FBL / Rail 106
Shortly Kosmik 200 / Scorpion 4540 / Heat resistant gear
Marcos
Banshee #27, 2x TDR, Diabolo, Logo 690SX, Raptor E700, JR Sylphide E12 EX Super Gracy, Voodoo 600, Voodoo 400, Logo 550SE, Logo 400SE, JR Forza 450. Mikado Vcontrol.
marcosp is offline        Reply With Quote Quick reply to this message
Old 06-13-2012, 06:00 PM   #6 (permalink)
Post The Danny Rigid
Cool. Great idea. This is my setup now. Only possible change is blades*
Components:
Hyperion 4035-560kv | V-Bar Fullsize blue (gov) | YGE 120HV | MKS HBL950/980 | Radix 710v2/105 | Gryphon Quasar BEC
MickTech Brace, CrocoMount, Danny V-Bar Mount & Fence.
(more info in build thread)
Packs: 2x6S Zippy 4500mAh 45C
V-Bar setup:
See other post. Spreadsheet with my values in it.
Radio setup:
See other post. DX8 configured with bailout, gov-function and bank switching.
* I have ordered Gryphon 700 blades to try what it feels like. Also Fusuno orange tail fin to have for later use.
550E, X3 | BeastX, YGE, DX8
http://dannesholk.se/rc.shtml
Danny_Swe is offline        Reply With Quote Quick reply to this message
Old 06-13-2012, 07:58 PM   #7 (permalink)
Thumbs up
  • TDR 2011 Kit
  • Black Edition Pyro 700-52 & Heli Jive 120 HV
  • Cyclic - Futaba BLS 253 @ 6V
  • Tail - Futaba BLS 251 w/ WR Voltage Regulator @ 5.6V
  • Mini VBar w/ AR8000 and Satellite + DX8 TX
  • TM1000 Spektrum Telemetry Module (will be removing at end of season)
  • J-Log --> Must have for data and to be able to see what is happening under the hood
  • MickTech NACA Duct
  • 13T pinion but will be switching to 14T to achieve 1450/1700/1850 HS with enough PWM for the higher HS's
  • Thunder Power 6s 4400mAh 65C packs
  • Jan's Main Blades and Radix 710mm (Flybar Style)
  • Edge 105mm Tail Blades
Build Thread https://www.helifreak.com/showthread...hlight=kidheli
KidHeli is offline        Reply With Quote Quick reply to this message
Old 06-20-2012, 01:22 PM   #8 (permalink)
  • 2010 kit
  • Scorpion 4350-540LE croco mounted/13T/VBar governed.
  • Fusion Hawk 120HV ESC
  • Hercules Super BEC@6v
  • Futaba 351 cyclic
  • Futaba 251 tail
  • Radix v2 710 and 105 Radix tails
  • VBar blue
  • Fusuno canopy (crap)
  • Stock canopy (good)
  • Holes in the canopies
  • Jan's frame stiffeners
Soon:
Pyro 700-52/Helijive (black edition if they are still available, Pyro WoT if not), some 690 blades.
TDR/VBar
Logo 600SX 12s VBar
MSH MINI PROTOS/CGY750
AcidDrink is offline        Reply With Quote Quick reply to this message
Old 06-22-2012, 07:17 PM   #9 (permalink)
2011 TDR
Black bushing with black orings
White/black/red canopy w/ naca duct
Gmauro mount
Powerjive/4530le scorpion 14 tooth pinion
Blue vbar full
Bls253/251 on 5.6 jive bec NO buffer pack
JR sats
Heat resistant gear
Both Jans and Micks frame stiffeners
Cfk innovations landing gear
TDR, Srimok N x 2, Banshee 31, Dune!
jhunter is offline        Reply With Quote Quick reply to this message
Old 06-22-2012, 10:08 PM   #10 (permalink)
I couldn't find the Modeltechnic landing gear anywhere. Do you have a link?
Marcos
Old 06-23-2012, 02:12 AM   #11 (permalink)
Sorry marco, I was mistaken. I have the same ones you have I believe. Cfk innovations.
Model technik sells other bling for the TDR.http://www.cr-modelltechnik.de/rizub.htm
Old 06-24-2012, 11:22 AM   #12 (permalink)
Hi,
2011 TDR Kit
Scorpion 4035/560
13t pinion
Kontronik Jive 80HV
Mini V-bar 5.2 Express
3 x Savox SC 1257
1 x Savox SH 1290
Battery bufferpack
Black bushings/black o-rings
Edge 690 Se FBL blades
104 mm KBDD tailblades
Grtz,
Dirk
The heli virus has infected me and i hope that there is NO CURE !! Compass Support Team
__________________________________________________ _____
Warp 360 / 6HVU / CY Stingray / Invertix 400 / SH Little Spyder
Dflyer is offline        Reply With Quote Quick reply to this message
Old 06-24-2012, 12:12 PM   #13 (permalink)
Hi.
  • 2011 kit
  • Pyro 700-52LS (W-O-H Line), HSC belt drive first stage gear
  • POWER JIVE 120HV v9 mode4, J-Log
  • Futaba BLS451 cyclic
  • Futaba BLS 251 tail
  • Radix 710 regular(v1) and 105 Edge tails
  • AC-3X 2.6
  • Custom painted canopy
  • White bushes/red+black o-rings
osat is offline        Reply With Quote Quick reply to this message
Old 07-14-2012, 08:30 PM   #14 (permalink)
Kit delivered February 2012
Wobblehead, black bushings
13T pinion
Pyro 700-52
PowerJive 120HV BEC 5.6V
Cyclics: Futaba BLS 451
Tail: Futaba BLS 251
Skookum SK-720
2 x DSMX satellites
Main: Radix 710mm V2
Tail: Radix 105mm
4400mah ThunderPower 65C 6S long sticks.
Custom sized satellite wires
White gears dyed black
Shortened servo wires
8-10 minute flight times.
Mark
Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc....
mkovalcson is offline        Reply With Quote Quick reply to this message
Old 07-15-2012, 01:42 PM   #15 (permalink)
Changed it since the crash.
2011 TDR
Kontronik Powerjive
Kontronik 700-52
Radix 710 FBL
Rotortech 105's
Futaba BLS157HV's
Futaba BLS256HV
Voltz LiFe 3000 RX pack
Henseleit Frame stiffners
Some other frame stiffeners
CF Modeltecnik battery tray
Fusuno CF landing gear
Heat resistant main gear
Old 07-15-2012, 03:01 PM   #16 (permalink)
Please, can you mount it without problem, in stock frame? Thank you
sescot is offline        Reply With Quote Quick reply to this message
Old 07-15-2012, 03:03 PM   #17 (permalink)
Yes, it fits perfect
Old 07-16-2012, 08:35 AM   #18 (permalink)
2012 TDR
Jeti Mezon 130 (bec set to 6v)
Neu Heli 700-3D (510 kv)
16T pinion
TP 65C 4400 (12s)
Rail 716
Rail 96
Futaba BLS-451/251
Rob/Mike frame stiffener
Heat resistant intermediate gear
Stock canopy and decals
Danny
F1 Rocket is offline        Reply With Quote Quick reply to this message
Old 07-17-2012, 02:28 PM   #19 (permalink)
My TDR # 2:
  • 2011 TDR
  • GMauro Scorpion 4035-500kv; 15T pinion
  • Jive 80HV v9; mode 4-9; 6.0v; +P +I -smooth auto timing.
  • mini Vbar 5.3
  • 3xSC1257TG
  • BLS251
  • Spinblades 690 FBL
  • Radix 105
Fabio
Old 07-18-2012, 08:37 PM   #20 (permalink)
2012 TDR
Jive 120
Scorpion 4525-520 Ultimate
14T pinion
Rail 696
Radix 110
Futaba BLS-252/251
Jan frame stiffener
Gmauro Motor Mount
epc2 is offline        Reply With Quote Quick reply to this message
