Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Atom 6HV, 6HVU and 550 Ultimate
Atom 6HV, 6HVU and 550 Ultimate Compass Atom 6HV, 6HVU and 550 Ultimate Model Helicopter Discussion
Old 08-27-2013, 06:59 PM   #1 (permalink)
Banned User
Post Gear mesh
Having a bit of trouble getting the gear mesh just right. I've had the motor on and off a couple of times and know that it should be smoother than it is. Does anyone have any tips they would like to share?
Also has anyone had problems with 6HV gears being out of round? I did spin it and didnt see any up/down wobble but I'm not getting my face close enough to look for horizontal wobble, even without main blades on.
kavic5150 is offline        Reply With Quote Quick reply to this message
Old 08-28-2013, 10:46 AM   #2 (permalink)
What works for me is to use a piece of paper on the main gear between the pinion hold the pinion against gear then tighten the motor mounts take paper out and your gear mesh should be good to go, As far as the main gear goes it might have a slight bit of play but I'm not worried about it'
Your is my Bread and Butter.
Compass Field Rep/KBDD Team pilot/Experiencrc.com
sewerfly is offline        Reply With Quote Quick reply to this message
Old 08-28-2013, 10:58 AM   #3 (permalink)
The method that Corey described above works very well and has been proven over time.
The main gears on most model helicopters are quite good, but not perfectly round. There is almost always a high spot.
Snug the motor mount bolts, not tight, but enough so that it takes a small amount of pressure to move it back and forth, and press the motor/pinion against the main gear.
Rotate the gear until you find the highs spot, and put a dot on it with a Sharpie (felt pen).
Rotate the gear around, stopping every 1/8 turn to rattle it back and forth-there should be the slightest amount of play that you can detect at the high spot (there will be a little more play everywhere else). Move the motor back and forth until you get it just right.
Tighten the motor and check it again (sometimes things move a bit when you tighten the motor).
If the mesh is still good, make sure all the screws are tight (so the motor cannot possibly move) then pull them out and re-install them one at at time, with thread lock.
I use this method on all of my model helicopters, regardless of brand.
Old 08-28-2013, 12:10 PM   #4 (permalink)
Banned User
Post
Thanks for the replies. I'll try to see if there are any spots where the gear is tighter and go from there.
Old 08-28-2013, 02:48 PM   #5 (permalink)
Dang, RAK, that should be copy/pasted on Compass document template and leveraged as Pro Tips!
= Rb43 =
Old 08-28-2013, 05:51 PM   #6 (permalink)
Thanks Rob!
I did not think it worthy of that.
Old 09-02-2013, 10:58 PM   #7 (permalink)
Formerly BarnStormer
+100
If there is a big difference between the high and low spots then I will set it with very little backlash on the high spot then fly a few flights and recheck. The high spot is usually reduced or removed this way.
Scorpion Power Systems
Jason O'Connell is offline        Reply With Quote Quick reply to this message
Old 09-09-2013, 05:20 AM   #8 (permalink)
Banned User
Post
Problem solved. Thanks for all the help.
My main gear has no wobble, its perfectly round from what I can see. Gear mesh was a hair too loose is all.
I did notice that the pinion shroud (dont know the proper term for it) sits awfully close to the main gear on the right side but not on the left. I removed and reinstalled it to confirm it was not installed crooked.
Old 09-09-2013, 08:50 AM   #9 (permalink)
= Rb43 =
Old 09-09-2013, 01:17 PM   #10 (permalink)
Old 09-23-2013, 12:50 AM   #11 (permalink)
Anybody else got problems with gear stripping? I run a high powered 6hv, Scorpion 4035-560, using VBar gov. I have stripped quite a few this season. The latest I tried is to run the mesh tighter than usual, perhaps a tad to tight at the tightest spot from what would seem perfect. I also use a light oil the first few flights. This seem to have cured my problems, have been running a month without stripping.
I do not use the counter bearing, don't know if this could cause issues but it shouldn't be needed.
Logo 700 | Trex 700X | Logo 600 | Logo 690SX | Gaui R5 | V-Bar Control
V-Bar Control flight analyzer (Win/OSX/Linux) - Latest release v5.0.0 July 5 - 2017
Sleipnir timing system - How fast can you fly?
Only the ground is the limit!
LinusLarsson is offline        Reply With Quote Quick reply to this message
