Go Back   HeliFreak > R/C Helicopter Support > Minicopter Joker/Diabolo Helicopters
Minicopter Joker/Diabolo Helicopters Minicopter Joker/Diabolo Helicopters Discussions
Old 12-05-2016, 07:35 AM   #1 (permalink)
Default Diabolo Black edition 700
Hello
Anyone using a vbar NEO on the black edition.
Im running 125 agility and still i am not able to get the flip/roll rate fast like my other helicopters.
Can anyone help what can be done to get more flip/roll rate.
Team Pilot SAB Heli Division.
Team Pilot Scorpion Power Systems.
Team Pilot BK Servos.
Team Pilot KDlipo Batteries.
Helimaster1 is offline        Reply With Quote Quick reply to this message
Old 12-05-2016, 12:55 PM   #2 (permalink)
Hi Heli
I use vabr NEO from 4 mounths ago on my BE.
If you want, I post my configuration later
Diabolo Black Edition with NEO
Goblin 500 with minivBar
Spektrum DX8
mgaproduction is offline        Reply With Quote Quick reply to this message
Old 12-05-2016, 03:36 PM   #3 (permalink)
Sure please do. How are the roll rates. What agility are you running and what is your setup
Old 12-07-2016, 03:12 PM   #4 (permalink)
Hi Heli
these are my parameters :
MAIN ROTOR
Style 100
Agility 100
Gyro gain 70
Elevator 10
Paddle 10
Heli size 85
Integral 60
Pitch 50
Expo 0
TAIL ROTOR
Yaw Rate 100
Gyro gain 55
Acceleration 75
P gain 70
I Gain 75
D Gain 0
Expo 20
DMA Collective 30
DMA Cyclic 10
I haven't found "flip/roll"
Spektrum DX8
Old 12-08-2016, 02:04 PM   #5 (permalink)
haha thanks bro.
It will really help.
Another question how do we adjust the cyclic ring. My helicopter is hitting the cyclic ring on the bench. How do we tune that.
If i remember it is on the prof tab on the swash selection menu.
Old 12-08-2016, 03:03 PM   #6 (permalink)
Cyclic Ring in expert menu of Swash is 85 and Rescue (if you have this) is 65
I hope helping you
Spektrum DX8
Old 12-09-2016, 07:18 AM   #7 (permalink)
Thanks mgaproduction.
Factory setting is 85 on the cyclic ring. Do we decrease to fine tune it if it is hitting the cyclic ring on the bench or remain it at factory default as it doesnt bind in flight but only on the bench
Old 12-09-2016, 08:49 AM   #8 (permalink)
I'd suggest making several bench tests until the cyclic ring does not touch anymore.
Honestly I have checked everything was all right from the start during the helicopter assembly.
PS : as soon as possible, i want to test the agility with values over 100
Spektrum DX8
Old 12-09-2016, 04:21 PM   #9 (permalink)
i have my agility set at 125.
Will be trying paddle simulation at 15 or maybe 20 later on.
lets see how it performs.
can you put some light on paddle sim if you have any info.
Old 12-23-2016, 09:03 PM   #10 (permalink)
Is it too slow on full stick or just off center? Paddle sim should help with the latter, but not the former. Cyclic ring should be checked at mid stick, shouldn't have any binding there.
Team Only Fine Helis
smwht is offline        Reply With Quote Quick reply to this message
Old 12-29-2016, 02:56 AM   #11 (permalink)
At midstick its fine. Binds only at extreme collective max and min.
Old 01-01-2017, 02:55 AM   #12 (permalink)
Have you run the optimizer? The optimizer has a big impact to the agility.
tomp is offline        Reply With Quote Quick reply to this message
Old 01-01-2017, 03:54 PM   #13 (permalink)
Stock was 65 and i have taken it to 73 but havnt flown yet.
Will post results end this week
Old 01-16-2017, 12:11 PM   #14 (permalink)
I have run up to 155 on agility before to achieve the rates I'm looking for. Generally I am around 130 though. Also cyclic ring should be set at midstick, and checked with full aileron and elevator inputs.
TSA 700n, Goblin 700 Comp, Trex 700x, Oxy 2, Oxy 3, Oxy 4, Synergy E5s, Synergy N7, Logo 800 Xxtreme
Vbar Neo, VControl
Team Oxy Heli
Mark.a is offline        Reply With Quote Quick reply to this message
Old 01-18-2017, 03:13 AM   #15 (permalink)
At midstick the aikeron and elevator doesnt bind but at full positive or negative collective the cyclic ring gets actuve on the bench.
Once input is given at max or min collective the swash compensates and goes back to its original place.
Iv attached a video for the reference
File Type: mov trim.97A9B4D2-5557-4280-9405-4C0DC3CBA114.MOV (1.59 MB, 61 views)
Old 01-18-2017, 09:39 AM   #16 (permalink)
If you check your logs during flight do you ever see it say the cyclic ring is active? On the bench it will show this message a lot, but if it's not showing it in flight then it is okay.
Vbar Neo, VControl
Team Oxy Heli
Old 01-19-2017, 02:15 AM   #17 (permalink)
i will see and post results next time i am at the field
Old 01-19-2017, 02:52 AM   #18 (permalink)
IF I understand your problem, It looks like the FBL gyro is causing what you see. Try disabling the gyro, can usually be done in the FBL setup when setting the angles for pitch, and then repeat the experiment. the swash interactions should be gone or very minimal. Then dont forget to re enable the gyro. The artifact seen is normal.
minicopter DIABOLO LOGO 550sx
scorpion spirit futaba IISI
smsodhi is offline        Reply With Quote Quick reply to this message
Old 01-25-2017, 07:15 AM   #19 (permalink)
thanks everyone. Iv adjusted the cyclic ring. Reduced it for 85 to 79 and it doesnt bind now
