Old 10-15-2015, 03:43 PM   #1 (permalink)
Default lean when drifting down or moving backwards
I'm using a microbeastx on my trex 450 and it's OK overall, but if I let the heli drift downwards it'll start leaning to the right. (this doesn't happen if i do harder collective inputs, just when I let it slowly drift down) and when moving backwards. Stumped. I've messed a bit with cyclic gain with no luck so far, just getting shakes from that.
Any help would be appreciated. I can post a video of what's happen if that would help.
Trex 700L spirit pro / Trex 700n spirit pro/ Trex 550x spirit pro / Goblin Black Nitro 700
Thestructured is offline        Reply With Quote Quick reply to this message
Old 10-27-2015, 04:08 PM   #2 (permalink)
i have the same problem with a 300cfx i own. if anyone knows anything that would be great. just been "dealing" with it.
joupscott is offline        Reply With Quote Quick reply to this message
Old 10-28-2015, 06:35 AM   #3 (permalink)
Hi,
the system measures movement by using the gyros. If you don't touch the sticks for aileron, elevator or also the rudder this commands the system to not turn the heli. So if the system doesn't measure any movement, it'll not move the servos. If it measures any movement it'll counteract this by commanding the servos until the movement stopps.
So main reasons can be if the heli turns even when you not touch the stick is that either your transmitter is sending a stick command, i.e. because the stick pots do not center properly, or the system measures a movement though there is none due to gyro drift. Or third option maybe that the system is not able to detect the movement as it is so minimal that gyros can't measure it or even the heli doesn't roll/tilt at all and it is just a sideways movement due to wind or aerodynamics.
Against the third option you can't do anything. If it's a problem with the transmitter you may try to increase the stick deadzone at Microbeast's Parameter Menu Point E. When it's a problem with vibrations (which can cause gyro drift) this can typically be seen when the heli tilts the more or less depending on the rotor head speed/motor speed. If this is the case you may use a different gyro pad or move the device to another mounting area on the helicopter ... or of course find out why the heli is causing such ugly vibrations.
I'm sorry for this very general explanation but basically it always has to do something with one of these causes when there is some unwanted rotation happening. I don't see why the heli only will drift when the heli is moving down and backwards as the thread starter described. But maybe, for example, he is flying the heli with V-Shaped throttle curve and motor speed is increasing as the rotor is unloaded which causes a little vibration and some small gyro drift in consequence!? But also maybe simply the heli is moving sideways to the right as the heli is getting in it's own downwash for a short moment!?
best regards from Germany
Stefan
BEASTX r&d Team
freakware.com
Frenchdress is offline        Reply With Quote Quick reply to this message
Old 10-28-2015, 07:07 AM   #4 (permalink)
Just to check - are you using the trims on your radio?
Goblins - Mini Comet, 380, 500, 700
BK Servos, Spartan vx1e FBL units, Switch Blades
Jeti DS-16
TORCHS member, AMA 64878, Citizen 690
Mattinfla is offline        Reply With Quote Quick reply to this message
Old 10-28-2015, 07:24 AM   #5 (permalink)
When you say 'leans to the right'.. do you mean that simply the heli leans, or that it also drifts to the right?
Leaning to the right in a hover is perfectly normal and any single rotor heli (with clockwise main rotor direction) must lean to the right in order to avoid drifting. All helis do it all the time but possibly you are only noticing it in certain circumstances. The lean is necessary to counteract the sideways 'push' from the tail rotor.
This 'leaning' has the technical name 'translating tendency' (google it)
Old 10-28-2015, 05:54 PM   #6 (permalink)
If the effect is large enough, then a video would help for sure. As you can see, those who have answered already are having to make some assumptions about what you've tried to describe.
Show us the fast punches too, so we can see it not 'drifting', as you described.
Cheers
Sutty
Regards, Sutty
Old 10-29-2015, 01:47 PM   #7 (permalink)
If I understand correctly, this is with no stick inputs? This sounds like cyclic command has decayed and gone to its 'neutral' point then you have said drift. Have you rechecked your mechanical setup, perhaps you have a swash that's cockeyed?
Steve
Nano CPX || 130X || 230S II 450 3D converted to 450X || 360CFX || 480 Fusion II 550X || Oxy 5 MEG || ALeeS Rush 700 Evolution || Goblin 770 Sport 'My flight style, determines my crash style"
crashcopterman is offline        Reply With Quote Quick reply to this message
Old 11-01-2015, 07:50 AM   #8 (permalink)
closed
hello grumpy-old-man, wouldn't the translating tendency in a right sided tail rotor helicopter cause a drift to the left? if i'm not mistaken real helis have the tail rotor on the left side and that's why their translating tendency happens to the right. in our case, a TD would cause the heli to drift to the left, i think.
i'm experiencing an inconvenient tilt to the right (not a drift) during collective pitch-pumps too. tail also won't hold properly, as if insufficient tail gain or improper tail compensation was there. it's been hard to get rid of these issues and definitely it compromises the quality of the flight. i've even modified the heli so now i have a higher tail rate, but no success so far.
hilarious is offline        Reply With Quote Quick reply to this message
