MSH Protos MSH Protos Helicopter Support Forum |
05-26-2013, 07:59 PM | #61 (permalink) |
Mine:
Stretch Protos (sab 470mm blades) Hyperion DS16 Cyclic, Futaba BLS251 tail Brain Turnigy 3000 mAh 6S packs ~1850g (a bit over 1900 now I have added a bunch of telemetry stuff to it)
-DX8 -MSH MiniProtos Stretched, SK720, DS95/DS95i, Hyp 4S 25C 2500mAh -MSH Protos Stretched, Brain, Hyp DS16/BLS251, 6S 3000mAh -Goblin 500, HC3SX, Hyp DH16/MKS980BL, Scorp 4015-1100 |
07-26-2013, 01:38 PM | #62 (permalink) |
Protos 500 carbon Stretch (from manual: 1600g)
low fbl head alu pulleys msh brain stock yge esc 60A spinblade 470mm asymetric (175g, +60g versus stock MSH 430mm) 1250MG savox 1290MG savox (good, but heavy 60g) Jeti Rsat2 Rx Castle BEC 10A (30g) Zpower Z20A (+30g versus stock motor) Canomod Canopy (+25 more than stock) Hyperion 6s 2600 45C (450g) 1750grs |
07-28-2013, 02:44 AM | #63 (permalink) |
Protos Plastic Flybarless
All stock Blades: SAB Motor: Scorpion (MSH) ESC: YGE 60A Cyclic: Align DS515M Rudder: Align DS655 FBL: Spirit System RX: Futaba w/ S-BUS Weight without battery: 1166g With 6S 2500mah battery: 1556g |
09-10-2013, 02:38 PM | #64 (permalink) |
low fbl head alu pulleys msh brain stock yge esc 60A Edge flybarless 473mm Fusuno tail blades 72mm 3x1250MG savox 1290MG savox (heavy 60g) Jeti Rsat2 Rx JETI SBEC 10A + 1x4700uF Cap motor Zpower Z20A (+30g versus stock motor) Fusuno canopy KYPOM 35C 6S 3700mha (550 grs) 1850grs |
12-12-2013, 04:43 PM | #65 (permalink) |
FB plastic stretch
Savox 1250 cyclics Ino lab d261hb tail Stock lipotech motor and esc Align gp750 Sky lipo 2600 40c Rjx 470mm blades Airframe: 1261g AUW: 1703g
Protos Max Leggero 700, Logo 600SE, Blade 230s DX9 |
01-18-2014, 01:18 PM | #66 (permalink) | |
protos carbon stock motor esc and blades ds515mg sh-1290mg Brain Bluetooth rpm sensor align 3300Mha 1756g
Trex 150 DFC. Trex 450 pro V2. Trex 550e Pro DFC |
01-19-2014, 02:00 PM | #67 (permalink) |
How much does your Protos weigh?
Cf frame, tall FBL head, unstretched
Rail 423 blades Hc3sx Mks 9660a+ Mks ds760 Stock MSH 60 esc Stock scorpion motor THOR 2700mah 6s Futaba r6208sb 1698 grams Sent from my iPad using Tapatalk HD
Synergy E5S 606 | Synergy 516 | Goblin 380 Buddy | Oxy4 |
01-23-2014, 05:54 AM | #68 (permalink) |
Protos plastic composite frame stretched
Turnigy 3025 850Kv motor Tarot ZYX fbl unit 3x Hitec HS-5245mg on cyclic Futaba S9257 tail servo YGE 80A ESC MSH classic canopy MSH51081 [ looking for a spare ] HK 430mm Carbon/Glass Fiber blades FrSky receiver Body weight: 1172g |
06-11-2014, 09:14 PM | #69 (permalink) |
Stretched carbon
880 scorpion 60a yge Bd3sx 1 dsmx sat. Ar8000 receiver Tm1000 w/ full telemetry Spektrum gps Mks 9660a+'s & ds760 tail Lynx tail pitch lever & tail servo supports 1 Msh Aluminum servo mount & all aluminum pulleys Boca ceramic hybrid bearings throughout Rjx 470mm red mains Lynx tails 1760 grams all up with nanopuff 2650's and classic canopy
Prôtos Max v2 ~ brain,castle,MSh,Bk Goblin 700c ~ Ferarri carbon,Ikon,Castle,Quantum,Torq Goblin 500 ~ Bx,castle,Scorpion,Kst MSH USA team pilot |
05-21-2016, 12:07 AM | #70 (permalink) |
why not.....
Carbon Stretch 3Digi FBL 1 DSMX sat 1 OrangeRX Nano Sat 3xSavox 1350 Turnigy 505HV Tail MSH 470mm Turnigy 2650mSh 405gram batteries approx MSH Scoprion 880kV YEP80 Stock Can 1780grams
Stretched Blade 270CFX w/Custom Scorpion+3Digi MSH Stretch Carbon Protos 500+Custom 770kv Scorpion 4015+80A YEP+BrainV1 https://www.youtube.com/c/RCBound#699RCHN |
04-06-2022, 09:39 AM | #71 (permalink) |
it is never too late for a Protos 500. Just rebuilt and remaidened
stretched carbon protos 500 FBL head, stock msh 880 motor, roxxy 960-6 esc (50g), spinblades 470 asymetric, kbdd tailblades, turnigy s306g tail servo, futaba s3150 swash servos, homebuilt fbl, frsky XSR receiver + FLVSS + msrc-current sensor 1250 g sum 0380 g 4S-3700 1630 g AUW |
