Old 05-09-2012, 08:53 AM   #1
dscottj
Default dumb move, wire cut
I got careless long ago snipping zip ties and accidentally cut one of the wires to my tail servo, very close to the servo body. The mechanical splice I made came loose without even flying it, so I'm wondering if it's possible to just order a new wire set for it? Any links on how to replace that?
Don't worry, I already broke the stick you'd use to beat me on my own head .
MSR, MCPx. MSH Protos 500 plastic ("Tosaerba Volante").
dscottj is offline        Reply With Quote
Old 05-09-2012, 09:20 AM   #2
banditpowdercoat
You can resolder them onto the servo board. There small, but not that tough. Tin the wire before attempting to solder it to board, then a quick touch with iron and shes good to go
Dan Pesonen
mCX2, nCPX, mCP X, Blade 400, MSH PRÔTOS
"Tri-Flow"
banditpowdercoat is offline        Reply With Quote
Old 05-09-2012, 09:20 AM   #3
Thunder Fighter
You can buy leads with plugs on them or even buy an extension lead and cut the female plug off the end. You can usually pop the bottom off the servo to access where the lead is soldered onto the board and replace it. BUT I would not try this unless you have the right soldering gear and experience.
//Dennis.
Mini Protos FBL Stretch - 4s MSH Brain : Protos FBL Stretch - SK-720 : Protos FBL Stretch Night flyer SK-720
SAB Goblin 500 Ikon : Logo 600 FBL V-bar, 10s : SAB Goblin 700 Vbar, HK5020, Hawk 120A
Thunder Fighter is online now        Reply With Quote
