Old 07-14-2012, 09:30 AM   #1 (permalink)
Default OS 105HZR Bearings.
Hi fellow freaks,
Just to know because my rear bearing is shot, and will order from Boca.
Boca hasn't got "the bearing" for the 105 so ...will the 91 size one be good to go?
Thanks G.
No Pitch...No Fun!!!
Egroeg is offline        Reply With Quote Quick reply to this message
Old 07-23-2012, 05:23 AM   #2 (permalink)
Ok so no one can tell for sure if the OS 105 and OS 91 have the same size bearings.
Will pull them out and let others know.
Old 07-23-2012, 07:31 AM   #3 (permalink)
Check the manual of each. Im pretty sure both bearings are the same.
Sent from my DROID RAZR using Tapatalk 2
aviator493 is offline        Reply With Quote Quick reply to this message
Old 07-23-2012, 05:33 PM   #4 (permalink)
Thanks a493, but the manual only states part number.
When googled it redirects to online vendors of the part.
I am planing on switching to ceramic therefore I want to be sure before I order but I am pretty much sure it must me the same.
Old 07-23-2012, 09:43 PM   #5 (permalink)
Sorry, I meant to research this more but got stuck at work. If you go to towerhobbies.com it has a parts finder in the top right corner when you look up a part number. You can look up each motor and look at the parts finder. If both motors point to the same bearings you'll know for sure! Ive noticed even though os uses different part numbers for 1 item, tower uses just one for both if the parts are the same.
Old 07-29-2012, 07:37 AM   #6 (permalink)
os 105 and os 91 hz are the same rear bearing.
hirobo fan is offline        Reply With Quote Quick reply to this message
Old 08-07-2012, 04:48 PM   #7 (permalink)
I have them listed. They are the same as the 91
RC-Bearings is offline        Reply With Quote Quick reply to this message
Old 11-13-2015, 08:04 AM   #8 (permalink)
http://www.amainhobbies.com/rc-helic...930000/p141309
Dimensions:
Inside Diameter: 17mm
Outside Diameter: 35mm
Thickness: 8mm
Why this bearing is not shielded?
For example
http://www.amazon.com/Bearing-16003Z.../dp/B002BBGVVI
A friend it is using and tells me that it is better, because it prevents corrosion and if the bearing fails the balls do not fall inside the engine.
Align 800e PRO DFC // KRAKEN Yellow // RAW Nitro // Align 700N DFC // RAW Yellow // 2x Goblin 420 // RAW 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo
msallua is offline        Reply With Quote Quick reply to this message
Old 11-18-2015, 09:10 AM   #9 (permalink)
I think that is a simple answer. lubrication....
Gasser Mike
Team KDE Direct, TRM Power, Byron Fuels, MKS Servos
LoveToFly1 is offline        Reply With Quote Quick reply to this message
Old 11-22-2015, 06:44 AM   #10 (permalink)
How long did the shielded bearing last..?
Eventually the oil in the fuel will wash out all the grease inside.
KDS Chase 360 | Align Trex 600NSP | Align Trex 700E | Align Trex 700X
Sirolf is offline        Reply With Quote Quick reply to this message
