700 Class Electric Helicopters 700 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
04-02-2012, 03:22 AM | #21 (permalink) |
It's just gossip
T-Rex 700N: JR DS8717HV; Vortex VX1+Outrage BL9188HV; Outrage BL9080HV/Throttle; Gryphon regulator; SG Pro; OS MAX 91HZ-R T-Rex 700E: JR DS8717HV; Spartan Quark+Outrage BL9188HV; CC ICE HV 160A; RCM-BL750MX (450KV); WR Super BEC T-Rex 250SE 350Watts |
04-02-2012, 01:22 PM | #22 (permalink) |
Care to make a friendly $20 PayPal wager on that?
That's right Iceman, I am dangerous |
04-02-2012, 01:27 PM | #23 (permalink) |
Have you seen it?
NO FLYBARS |
04-02-2012, 06:21 PM | #25 (permalink) |
Well here is some new and interesting news that pretty much made me look super retarded. So I spoke to my brother to see if he knew if align had a new 700 coming out. (and I takeback everything previously) He spoke with Tim from Assurance Align usa. Here is the scope, the new align 700 fbl is coming out in about 3 months. It will have the new tail up grade which is similar to the kde direct, it will have the dfc head, it will have direct servo to swash link set up and will come with the new brushless servos. They said it will be about 250 to 300 higher then the normal kit. It has been redisigned to go up against the newer helicopters such as the goblin, compass, etc.
04-03-2012, 09:28 AM | #26 (permalink) | |
Align 450 PRO DFC 4S KDE 450XF // Blade 450X 450MX, 3GX, Savox // Align 450 Sport V2 Airwolf Align 600EFL PRO, DFC, 3GX, KDE Align CHP DL 800, XERA 4530LE, ICE160HV, AR7200BX, SB-2271MG, SB-2272SG, KDE, Lynx, 115s Thunder Power 65C LiPo & JR 12X |
04-03-2012, 11:14 AM | #27 (permalink) |
sure lol I will let them know, not sure how much influence I have though. I am not any good at bribing people, too shy for that.
04-20-2012, 07:35 AM | #28 (permalink) |
Hey guys,
Is this new rudder control available yet? If so, from where?
Trex 700e V2. All stock except for V2 tail upgrade and BeastX FBL. 2x Zippy 5000mah. Hitec Aurora 9 TX, Optima 7 RX. |
04-20-2012, 08:46 AM | #29 (permalink) |
Flyhelirus or aligntrexstore should have them. Servos have also been released.
04-21-2012, 07:42 AM | #30 (permalink) |
I am in on that wager, $20 says Align releases 700E V3 before end of year.
"If you think you can or you can not you are right" Goblin Xera 4530, YGE 160,VBar Diablo, HJive, 4525 Ultimate,VBar Synergy N5C sitting in Box... |
04-21-2012, 11:56 AM | #32 (permalink) | |
04-21-2012, 12:36 PM | #33 (permalink) |
No Idea but I did not obtain that info from any where on helifreak if that is what your asking
04-23-2012, 03:58 PM | #34 (permalink) |
Got mine fitted - very smooth indeed.
---- JR Vibe SGE12 Hiroki Ito Scorpion Tribunus 200A 4525 Ultimate Spirit FBL—-Minicopter Diabolo Pyro750-56 Kosmik200 Vbar v5.3 ----- T Rex 700N DFC OS105HZR Spirit FBL --- RJX Vector 700 Pyro750-56 Comp Kosmik 200 —— |
04-23-2012, 04:03 PM | #35 (permalink) |
Darn, I thought it replaced these as well:
http://www.kdedirect.com/TREX550600700PTUV2.html I have an issue on my 600 and 700 where when I tighten the screw that goes through that into the blade grip to what I think is reasonable, then the tail gets tight.
04-23-2012, 09:17 PM | #36 (permalink) | |
04-24-2012, 07:55 AM | #37 (permalink) |
you guys are on track about the new E but there is more coming than just a new E
Dino Spadaccini Team Capt Align Factory Team USA / Team Futaba |
04-24-2012, 07:58 AM | #38 (permalink) |
The 700E is solid, over 500 flights on mine, with all the upgrades, top notch heli.
04-24-2012, 09:58 PM | #40 (permalink) |
E is the only power system of interest to me. I've heard rumors of a G. G and/or N would certainly please some others.
vbar T700E v2 DFC head, Pyro 700-45L, Jive 120HV, BLS451/BLS251, Edge 693/115 vbar CF Protos Scorp 3026-880kv, Ice lite 75, 9650/BLS251, SAB 430/KBDD 82 |
