Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 12-22-2015, 07:58 PM   #1 (permalink)
Default Trex 700N with Vbar Control satellite, anyone?
Would like to see how some have accomplished installing their VBC sat and antennae on this model. I've puzzled this until my puzzler is tired to determine a suitable installation. At first, I thought it would be as easy as acquiring a long enough cable to each aft to the tail drive/boom clamp as an ideal place for good reception. But, I've not seen that Mikado offers a VBC sat cable for Vbar that's long enough. Need at least 300mm, and ideally more like 350-400mm to each back there with Vbar in the nose.
= Rb43 =
Rob43 is online now        Reply With Quote Quick reply to this message
Old 12-23-2015, 02:55 PM   #2 (permalink)
Under the canopy it is protected from the exhaust and reception is no problem at all.
Logo 800 Xxtreme, Signature 4540, Kosmik 200, BK7001/8005, Neo
Logo 690 SX v2, Scorpion 4525, Jeti Mezon 130, MKS960/BK8005, Neo
Urukai Carbon, Scorpion 4530, Kosmik 160, Neo
Trex 700N, TT 1.00RL, Vbar
RunarSL is offline        Reply With Quote Quick reply to this message
Old 12-23-2015, 10:37 PM   #3 (permalink)
Hey, thanks for your reply and pic. Do your antennae tips rest against the inside of the canopy?
Right now, my Silverline lives where you've placed your sat. I am thinking of placing my sat and and antennae up on top. Just on a thin plastic template for test fitting right now. I will make it in carbon when I have it figured out.
= Rb43 =
Old 12-25-2015, 08:35 AM   #4 (permalink)
Just mount it on top of your vbar an route the antennas out to the sides.
Old 12-25-2015, 09:23 PM   #5 (permalink)
I don't like covering my Vbar. It will work well as above. No hurry to fly here. I still expect to inspect the rear bearing soon, and may remove the engine for a replacement.
Rob
= Rb43 =
Old 12-31-2015, 05:03 PM   #6 (permalink)
I've made my initial attempt using carbon fiber pattern Kydex I found from Amazon. It's pretty tough stuff, so should be fine. Formed the supports for the mounting plate from it as well. Just takes a little heat from a heat gun. I actually spaced the sat a distance from the antennae ends so they wouldn't lie as much straight back. I found the antennae support didn't stay in place with only servo tape once the canopy was pressing against the antennae tips. So, I used a couple of tiny screws to secure it. Flat head screws attach the plate to the supports. Pics don't show well, but there's about 1/8" clearance between the mounting plate and the top of the Vbar.
ID:	627221   Click image for larger version
= Rb43 =
Old 01-02-2016, 05:55 PM   #7 (permalink)
Nice install! Looks great
Old 01-03-2016, 09:20 AM   #8 (permalink)
Thanks! Pics are pretty dark as I look at them now.
= Rb43 =
Old 01-07-2016, 02:32 AM   #9 (permalink)
Well, im new to nitro from Dec 2015 and flow 3 gallons with this setup without an issue
TT_insist is offline        Reply With Quote Quick reply to this message
Old 01-07-2016, 06:56 PM   #10 (permalink)
Cool! I am playing with the new update on the Vbc and made a screen setup just for my two nitros.
Old 01-08-2016, 12:02 PM   #11 (permalink)
I'd be interested to see what you did...
= Rb43 =
Old 06-21-2018, 08:01 PM   #12 (permalink)
Pictures of the VBAR NEO Vlink in a 700N DFC?
Thanks in advance
Align 800e PRO DFC // KRAKEN Yellow // RAW Nitro // Align 700N DFC // RAW Yellow // 2x Goblin 420 // RAW 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo
msallua is online now        Reply With Quote Quick reply to this message
Old 04-08-2019, 11:03 PM   #13 (permalink)
Thanks in advance
Hi Guys
New to VControl / Neo and have the same question / request.
Changing my 700N (Turbine) over to a Neo and was wondering if they still mount ok on the little 700N FBL Mount?
It will obviously have a bit of overhang and not sure if I should try and make the mount longer (bit of CF) or just leave it un supported (servo plug end facing forward)?
Could anyone offer up some pics or advice?
Cheers
Comet 700 / Goblin 770 Comp / Goblin 700 Nitro Sport / Goblin 700 Black Thunder T Line / Goblin 380 KSE / VControl
Goody63 is offline        Reply With Quote Quick reply to this message
Old 04-12-2019, 12:30 PM   #14 (permalink)
I mounted mine here, I had it on the fbl mount spot at one point but it didn't fit very well with the battery and the support brace right above the mount.
Team Only Fine Helis
smwht is offline        Reply With Quote Quick reply to this message
