Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600 PRO Class Electric Helicopters
600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 02-22-2012, 02:36 PM   #1 (permalink)
Default swashplate setting and DX8
hi dose anyone have the swashplate setting for the new DX8 or can upload full setup file for trex600 efl off there DX8 please.
swashplate
set aileron =
set elevator =
set pitch =
bedlam is offline        Reply With Quote Quick reply to this message
Old 02-22-2012, 05:15 PM   #2 (permalink)
here are my setting's do they look right ? T-Rex 600 EFL PRO
swashplate
set aileron = -43
set elevator = +37
set pitch = +41
Expo = off
E-Ring = off
Old 02-23-2012, 01:01 AM   #3 (permalink)
Are these with 3GX?
How much are ur pitch and cyclic curves?
erni66 is offline        Reply With Quote Quick reply to this message
Old 02-23-2012, 04:22 AM   #4 (permalink)
the heli as 3GX on it i am using AR8000 with DX8
on swashplate i setup pitch 12+/12- and the aileron/elevator to 11+/11-
then on my dx8 i set aileron/elevator switch 0 to 9+/9- and switch 1 to 10+/10- and switch 2 to 11+/11-
i setup my pitch on F mode/idle switch 0 to -2 ,+5 ,+10 and F mode/idle switch 1 to -5 ,+5 ,+10 i did F mode/idle switch 2 the same as 1 for now
ars thses ok swashplate
set aileron = -43
set elevator = +37
set pitch = +41
Expo = off
E-Ring = off
or is there something not right in my build?
Old 02-23-2012, 07:34 AM   #5 (permalink)
ok i just set it up again now i have
then on my dx8 i set aileron/elevator switch 0 to 8+/8- and switch 1 to 9+/9- and switch 2 to 10+/10-
set aileron = -50
set elevator = +44
set pitch = +43
Expo = Act
E-Ring = Act
Old 02-23-2012, 02:15 PM   #6 (permalink)
set aileron = -50
set elevator = +44
set pitch = +43
Expo = Act
E-Ring = Act
Your numbers don't look unreasonable for the 600E. You should turn off the Expo and E-ring since this can mess with the FBL system and Align states to turn this stuff off in the manual. I don't understand exactly what you are doing with your switches in regards to pitches. Can you explain how and why you are doing this? I'm asking because it is very important to set-up a radio in a fashion that doesn't change things like pitch in different modes and such. This makes it very difficult to get the correct "feel" on the sticks.
I pretty much use the same settings on every heli I own in regards to pitch / throttle curves and it goes as follows:
Pitch
Normal: 30, 40, 50, 75, 100 or 0, 25, 50, 75, 100
Idle 1: 0, 25, 50, 75, 100
Idle 2: 0, 25, 50, 75, 100
Hold: 0, 25, 50, 75, 100
Throttle (w/o governor):
Normal: 0, 45, 65, 85, 100
Idle 1: 100, 95, 90, 95, 100
Idle 2: 100, 100, 100, 100, 100
Hold: 0, 0, 0, 0, 0
Throttle (w/ governor)
Normal: x1, x1, x1, x1, x1 (rpm #1)
Idle 1: x2, x2, x2, x2, x2 (rpm #2)
Idle 2: x3, x3, x3, x3, x3 (rpm #3)
Hold: 0, 0, 0, 0, 0
NOTE: I use the Hold switch to turn the heli on and off when I use this function.
mtuccio is offline        Reply With Quote Quick reply to this message
Old 02-23-2012, 02:38 PM   #7 (permalink)
hi i think i've got it right now my 0 pitch was off i have redone the head and ball links now i have
set aileron = -42
set elevator = +42
set pitch = +42
Expo = off
E-Ring = off
on swashplate i setup pitch 12+/12- and the Cyclic pitch to 10+/10-
DX8 as a switch F.Mode 0,1,2 it the same as Normal,Idle 1,Idle 2
F.Mode 0 to -2 ,+5 ,+10
F.Mode 1 to -5 ,+5 ,+10
F.Mode 2 to -5 ,+5 ,+10
Old 02-23-2012, 07:55 PM   #8 (permalink)
I think Align wants you to use as high of ail/ele swash mix % as you can. 42% seems too low. You should probably be around 80%. Try using the inner holes on the arms and make sure your endpoints are at 100.
NRPY is offline        Reply With Quote Quick reply to this message
Old 02-24-2012, 09:56 AM   #9 (permalink)
hi can anyone post there swashplate setting's on here please
