Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > Futaba 14MZ - 12Z
Futaba 14MZ - 12Z Futaba 14MZ and 12Z Help and features Support Forum
Old 01-18-2008, 09:26 AM   #61 (permalink)
Default Very interesting developpement
Hi everybody,
I have some very good news!
Thanks to somebody's feedback after using the module programmer, I can provide you with new area code settings that will make your module usable in your radio WHATEVER ITS AEREA SETTING IS!!!
Basically, instead of using some code like 00, 01, 02, 03 ... 0A for the area setting you just have to use codes like these: 80, 81, 82, 83 .... 8A. Just replace the first 0 with a 8 and you can use your module with any area radio!
The table provided in the download file become this:
---------------------SEE ATTACHED PICTURE--------
You still have to match the area with your module frequency according to this table. For exemple it won't work if you choose 82 (Europe) for the area and 07 (72MHz) for the frequency as there isn't any 72 MHz in Europe area.
I am still looking for other codes like one that will allow to use a 40MHz (or 41MHz) module for both 40 and 41MHz bands in Europe. I am pretty sure these modules are hardware identical.
If you have seen this done, please PM me.:wink:
Caution:
Even if you can easily change module frequency from 40 to 72MHz it is better not to do it as there could be some hardware differences (filter setting). If you do it anyway do some extensive range check before flying.
There is no problem between 40 and 41MHz (tested) and probably not between 35 and 36 MHz too.
MZFAN is offline        Reply With Quote Quick reply to this message
Old 01-18-2008, 05:40 PM   #62 (permalink)
Wow, so that means there is still to find a "zone" in the radio which would allow ALL frequency bands to be used - maybe it exists in the radio - and you will have mastered the frequency problems with the 14MZ ;o)
Great Job !
sambogosse is offline        Reply With Quote Quick reply to this message
Old 01-18-2008, 05:57 PM   #63 (permalink)
Team Taco Member
Well thinking about it there must be as Futaba has to test each region and from my experience with software it easier to programme in an 'All bucket' and then restrict the regions later after testing
BTW I don't see them as Freq problems - It's a necessity as in we drive on the left and you on the right
Mark
Morley F1 60 Max (OS 61LX-H), Hirobo SDX (OS 55HZ-H, GY701), Trex 450SE + some planks
MarkD is offline        Reply With Quote Quick reply to this message
Old 01-18-2008, 06:08 PM   #64 (permalink)
hi, anybody have try with TM-14 module plz ?
Skymax is offline        Reply With Quote Quick reply to this message
Old 01-18-2008, 09:44 PM   #65 (permalink)
Hi,
With the 2.4GHz module no try yet... I don't have one but if you want to send one to me I will!!!
Old 01-21-2008, 12:45 AM   #66 (permalink)
DDJ
Thanks a lot to you both. I'll try and build it and see what happens.
DDJ is offline        Reply With Quote Quick reply to this message
Old 01-21-2008, 01:40 AM   #67 (permalink)
DDJ
Originally Posted by MZFAN View Post
Hi DDJ,
There are some commercial eeprom programmer that generally come with their own software. You have to check before buying that they can program a microwire 93C46 or 9346 eeprom.
If you downloaded the file I provided you should have the schematic for a simplified board, combining the base board and the microwire board.
There is nothing much in it but if electronic is not your friend try to find somebody around you who can make the board for you.:wink:
Hi MZFAN
In the picture of the pc board you have the black wire in pin 8 & the red in pin 5. Your common neg in the pic seems to be black, next to the cap. Is this right ? Please supply some more pics if possible. Also, I can't seem to open the new freq. table. Sorry for asking so many stupid questions ! Just don't want to damage the module. Thanks
Old 01-21-2008, 02:49 AM   #68 (permalink)
Hi,
Mine it's always on my local futaba distributor , he try to modify it .
Old 01-21-2008, 07:01 AM   #69 (permalink)
Originally Posted by DDJ View Post
Hi MZFAN
What do you mean you can't open the new table? It is just a jpg file.. Just click on it on this thread and it will appear bigger. Then right click on it and choose Save the picture....
I did check again and always see the black, pin 5 from the eeprom, connected to the left of the connector and then just to the right, the red, pin 8 from the eeprom.
Perhaps you were confused with the DB9 connector pin number?
The number on this schematic correspond to the eeprom pins.
Old 01-21-2008, 07:08 AM   #70 (permalink)
Even if the 2.4GHz module is more complicated, it is possible it uses the same eeprom to store area and frequency information...
Anyway, good luck.
Old 01-22-2008, 04:37 AM   #71 (permalink)
DDJ
Talking EEPROM programmer
Hi MZFAN
Just a big up to you and everyone who answered all my questions ! I've built it and it works ! I'm going to mill a box where the module just clips in on top and a DB9 on the side. That way, you just drop the module in and hook the serial cable up for programming. I post some pics sometime. Anyway, I'll try the 82 codes too.
Thanks again.
Old 01-25-2008, 04:06 PM   #72 (permalink)
Hi MZFAN
Thanks again.
I think that this same would have to of operating for the modules of 2,4Ghz
Regards !!!
sinver is offline        Reply With Quote Quick reply to this message
Old 01-30-2008, 11:59 PM   #73 (permalink)
DDJ
Default Module programmer
Hi guys
Just some pics of module programmer. This makes it very quick and easy to program the eeprom. I have a lot of friends with radios from HK and this box saves you from checking which pin goes where everytime. I used engineer's pvc which machines very easy.
Name:	Module box 001 (800 x 600).jpg
Name:	Module box 003 (800 x 600).jpg
Name:	Module box 005 (800 x 600).jpg
Old 01-31-2008, 08:22 AM   #74 (permalink)
Hi guys
Attachment 37147
Attachment 37148
Attachment 37149
Hi DDJ,
Excellent work !!! :wink:
A question, please
if your programs that module ( 35Mhz HK ) and you let it free, you can transmit with the same radio ( HK ) in the channels of all the band of 35Mhz ?
thanks & regards !!!!
Old 01-31-2008, 11:51 PM   #75 (permalink)
DDJ
Originally Posted by sinver View Post
Hi DDJ,
A question, please
Hi sinver
No, you still have to set the region to Europe. But that's pretty easy now.
DDJ
Old 02-01-2008, 04:52 AM   #76 (permalink)
Hi sinver
DDJ
But then, it does not serve to configure the module as European because the radio not will recognize it, it is not thus ?
How it can be changed the region in the radio ? (my radio is one new Futaba 12FG)
regards !!!!
Old 02-01-2008, 05:24 AM   #77 (permalink)
DDJ
sinver
On the 12Z and 14MZ you have to match the region to the module. Or use the "8" codes and still match the band setting bit in the eeprom.
OK ?
Old 02-01-2008, 05:30 AM   #78 (permalink)
DDJ
sinver
What region is your radio now and what freq. is your module ? What freq. do you want ?
Old 02-01-2008, 06:44 AM   #79 (permalink)
sinver
OK ?
ok, but my radio is fixed in Hong Kong region
I can not select other region in my 12FG
I understand as reprogrammer my module HK in European region but not the radio
regards !!!!
Old 02-01-2008, 06:56 AM   #80 (permalink)
I have successfully reprogrammed my module of 35MZ HK version to 35MZ European version with all 35MZ European channels with "82" code and can be used in my 12FG tansmitter of Hong Kong region.
apleichau is offline        Reply With Quote Quick reply to this message
