Like Tree1Likes
Old 01-17-2015, 05:37 AM   #21 (permalink)
Originally Posted by prototype3a View Post
The 4525-370 is only ~3000w on 12s. The 3750w spec is on 14s.
I would also add the HK3 4035-450 as it is both lighter and more powerful than the stock motor. It is also bundled with the 'weaker' 600se and so any argument about stripping gears, breaking oneways or otherwise is invalid.
FWIW, I have read that production JivePros shutdown at just 20A over their continuous rating just like the Koby.
While , IIRC, Jives shutdown on a microburst of something on the order of 215A.
My Jive pros decidedly do not shut down from a microbursts of a mere 140 amps. My JLOG logs show lots of higher spikes,
Could you find where you read this and provide a link
Logo 480 XXtreme, Logo 550SX, Logo 690SX, Logo 800 XXtreme, TDR, Minicopter Diabolo 550, Minicopter Triabolo, Goblin 500, Goblin 700, Goblin 770, KDS Agile 5.5, Voodoo 600, Voodoo 400, HD Cell 500, Thunder Tiger E700
taosgraveyard is offline        Reply With Quote Quick reply to this message
Old 01-17-2015, 10:40 AM   #22 (permalink)
It was in a thread in the Kontronik Drives section here on HF. I don't know the exact thread and without any of us actually seeing the code in the JivePros, it's mostly speculation. The general consensus in the thread was that the JivePros do certainly have much lower cutoffs than the older Jive,HeliJive and PowerJive.
FWIW, I know that 14pole motors really only have advantages when the motor is held close to it's maximum ratings continuously (ie flown very hard continuously) which honestly, I doubt very many pilots in this hobby actually do and even then the advantages are fairly small. In most cases and for most pilots, a 10pole motor will perform better.
Jeti DS14us -- TT e700 -- 6s Logo600se UL -- Logo600-3d -- Logo500 UL -- Charge Case
prototype3a is offline        Reply With Quote Quick reply to this message
Old 01-17-2015, 12:18 PM   #23 (permalink)
When his attempt to call out the Jive Pro was challenged, the accuser back pedaled and quickly turned his attention to belittling Kontronik motors. I think we've unlocked a troll!
Kidding. Whatever you want to believe is fine. May even be technically true (I have no idea). Those of us running the Pyro 750 on the 690sx have had very good results, all running much less than full power.
Team MikadoUSA
hemp is offline        Reply With Quote Quick reply to this message
Old 01-17-2015, 12:33 PM   #24 (permalink)
Well, if you don't want to believe both PowerCroco's and several other's findings when it comes to motors that's your choice.
As PowerCroco says, it's physics and there's no getting around it.
I've personally shutdown a Koby 90 repeatedly with peaks around 110-125A. When the weather gets better, I plan to log it to see exactly where it is shutting down. Maybe the JivePros can handle microbursts similar to the old Jives (was it 220A?) but shutdown on longer term (1-2sec) but lower amplitude peaks?
Either way, the evidence is out there if you care to do the research that the JivePros can not be run anywhere as hard as the older generation.
Old 01-17-2015, 05:35 PM   #25 (permalink)
Team MikadoUSA
Old 01-18-2015, 03:00 AM   #26 (permalink)
Default Logo 690SX motor choice
Does it matter what the jive pro can not handle when talking about the 690sx, p750 , jive pro 120 HV discussion?
This combination works very effectively and the jive pro doesn't shutdown, according to my experience as well as some others in this thread.
This combination absolutely rocks.
Last edited by taosgraveyard; 01-18-2015 at 07:06 AM.. Reason: Redacted, removed response to other statements in thread that aren't even relevant to the thread topic
Old 01-23-2015, 09:57 AM   #27 (permalink)
Regarding the esc option, the YGE 120HV with heatsink would be sufficient for the stock Scorpion motor?
|Michalis|
...let the flying be second nature!
acidla is offline        Reply With Quote Quick reply to this message
Old 01-23-2015, 11:11 AM   #28 (permalink)
Maybe.... Depends.
Old 01-23-2015, 01:15 PM   #29 (permalink)
I thought so...
My other option would be the CC Edge 160A.
|Michalis|
Old 01-23-2015, 01:18 PM   #30 (permalink)
Originally Posted by acidla View Post
I thought so...
I opted for the YGE 160HV just to be safe
ToddM is offline        Reply With Quote Quick reply to this message
Old 01-23-2015, 01:26 PM   #31 (permalink)
I used YGE for a while. I would use a 160 amp... More than safe,
Old 01-23-2015, 04:15 PM   #32 (permalink)
It really depends on how you fly. The 4525-370 generally is not a high current motor, so 120A continuous is probably enough to stay within specs for most pilots. However, if you're hard on collective or you fly in high temperatures then what's likely to happen is over-temp. Those aren't so bad with the YGE, it will just drop power and beep at you. However, hitting over-temp frequently can damage the unit, not to mention it's really frustrating to have your flights cut short.
Personally I run a YGE 160 on my 690sx, but I tend to be hard on speed controllers. I believe most people would be fine with a good 120A ESC.
Team MikadoUSA
Old 01-23-2015, 05:54 PM   #33 (permalink)
This might Piss off a few but the 690 utilizes the same main gear as the 600se. All logo has done is lower kv increase pinion and gone from 10s to 12s. You can fly the same configuration in this heli as the 600se.
Lower kv and higher cells same main gear
Higher kv lower cells same main gear . hs is hs
Lower kv higher cell count lower temps
The pyro 700-45 10s with 14t pinion 2000 + hs jive pro 80%
Same motor 12s 12 t pinion same hs
I would go 10s and lose weight on an already super light heli
Diabolo S #6
Diabolo
TDR
N7
crash at 42 is offline        Reply With Quote Quick reply to this message
Old 01-23-2015, 07:52 PM   #34 (permalink)
Yes but the 690SX has a much bigger OWB than the 600SE. And that is why you get away with flying it hard at 2000 HS.
maarset is offline        Reply With Quote Quick reply to this message
Old 01-23-2015, 08:02 PM   #35 (permalink)
Hmmm bigger is better?
Diabolo S #6
Diabolo
TDR
N7
Old 01-23-2015, 08:04 PM   #36 (permalink)
Well more surface area. Double the size.
Old 01-23-2015, 08:12 PM   #37 (permalink)
I added the motor support with the counter bearing to my 600se isn't this enough support against axial loads owb shouldn't be affected
Diabolo S #6
Diabolo
TDR
N7
Old 01-23-2015, 10:57 PM   #38 (permalink)
Thanks for the replies.
I am not hard on collective, i just fly in high temps during summer time. 160A esc is the way to go then.
|Michalis|
Old 01-24-2015, 06:55 PM   #39 (permalink)
will the new 400kv xnova motor on mikado usa site fit the 690sx?
http://shop.mikadousa.com/Xnova-4035...ng_p_1447.html
janol is offline        Reply With Quote Quick reply to this message
Old 01-24-2015, 08:09 PM   #40 (permalink)
The 600sx OWB is prone to stripping when run in the 690sx. The original release of the model used that configuration and resulted in a recall. They quickly switched to a double-stacked OWB arrangement, which is proving to be rather bullet-proof.
Unlike the 600SE, the 690sx is designed to be flown hard. If you're easy on the model then none of the durability upgrades are really needed, you could just switch your 600SE to 12S, put in a bigger motor, and call it good. But many of us are running the 690sx at headspeeds above 2000 RPM with collective in the +/- 13 degree range and flying hard. For that to work, the extra OWB beef is necessary.
Team MikadoUSA
