Old 03-28-2012, 04:03 AM   #41 (permalink)
Forget this piece of sh... Got one for a pusher plank and it is so far out of balance that it cannot be run past half throttle, makes zero power and all the mounting hardware as per picture was not with it in the box.
VControl
Old hand at Planks
Peter
Old 02-04-2015, 06:22 AM   #42 (permalink)
Default WITCH MODEL
what is the best motor for trex 250 pro dfc?
With the latest align stock I think I have necessity for some rpm more
I search:
scorpion 3900
scorpion 3600
scorpion 5300 ( Ithink so hignt rpm correct?)
Thx all!
artesina is offline        Reply With Quote Quick reply to this message
Old 02-04-2015, 08:54 AM   #43 (permalink)
I'm running 4500rpm on a stock align motor and this thing flies like a hummingbird on crack. What on earth do you guys do to these heli's that needs more power!! o_0
Radio & FBL: Spartan Vortex, MSH Brain, Jeti DS-14, Spektrum DX8G2
Sims: RealFlight & AccuRC
Old 02-05-2015, 08:58 AM   #44 (permalink)
Power isnt really the critical part, its the power to weight ratio, my latest motor choice weighs just 25gr and produces 230 ish watts.
It should perform well in my sub 300gr heli.
Lee Griffiths
Griff1 is offline        Reply With Quote Quick reply to this message
Old 02-05-2015, 09:26 AM   #45 (permalink)
OK, gotta ask, what was that choice?
Murph_d is offline        Reply With Quote Quick reply to this message
Old 02-05-2015, 03:41 PM   #46 (permalink)
sorry, wasnt trying to be cryptic, its the Turnigy 2623 4500kv.
Lee Griffiths
Old 02-06-2015, 09:36 AM   #47 (permalink)
I can't help but be curious. The motor is rated for 2S, but judging from the comments on the HK site, it can be used with a 3S battery as well. How do you approximate it's power output on 3S? I know that Watts equal Amps X Volts, but the HK site only lists its max current on 2S. I noticed they list the weight at 29g. Do you have one and have you weighed it?
What are you doing about a pinion gear? Seems like 2.4mm is an unusual shaft size. Looks like it comes with 2 or 3 pinions. Probably 0.4 modulus?
Sorry for all the questions, I'm always looking for alternatives.
Old 02-06-2015, 11:30 AM   #48 (permalink)
I've not tested it personally but i have it on good advice that is its output on 3s.
I've not weighed this motor yet either but the HK site listed weights are garbage or is an overall weight of the motor,connectors,heat shrink and 2 large brass pinions included.
The HK site also has the shaft diameter wrong, its a standard 2.3mm.
The included pinions arent of any use in the 250 but HK list a few for the foxbat heli that are correct.
I'll try and get a confirmation of the weight for you soon.
Lee Griffiths
Old 02-07-2015, 10:31 AM   #49 (permalink)
Looks like the 1 time i wanted HK to have the weight wrong they have in fact got it right.
This motor weighs in at 28.5gr and my chosen pinion is 0.5gr, a little heavier than id hoped for but still lighter than the scorpion 3900 and the stock align motor by 3.1gr and 5.0gr respectively not including the pinion.
while disappointed i think a 3-5gr weight saving is still significant.
Lee Griffiths
Old 02-07-2015, 12:17 PM   #50 (permalink)
The true question is how does it perform?
Specter 700v2 NME Nitro, RAW 700, RAW 700 Nitro, RAW 700 Piuma, RAW 580
VBar Control Touch
Saiteik is offline        Reply With Quote Quick reply to this message
Old 02-07-2015, 01:09 PM   #51 (permalink)
Thanks, I'm interested in your impressions after you've flown it.
Old 03-21-2015, 02:05 AM   #52 (permalink)
Default I'm not sure but
Originally Posted by VDFS View Post
The best option the motor for 250 is scorpion 3600KV with 16t??Or have other motor that is more powerful?
Tell me the best motor for 250 please...
I just got the scorpion hk2208-34 it's way bigger than stock barley fits frame
Brandon Hyden is offline        Reply With Quote Quick reply to this message
Old 03-21-2015, 02:11 AM   #53 (permalink)
Has anyone tried the hk2208-34 it's sold for the trex 250 I just got one am installing it now motor is huge .. It's a 2600kv though ?? It's sold for trex 250 I was told I needed a 20T pension hear ????? Is that right also the motor shaft was to long hit the servo I had to cut it a little is this normal ? Anyway someone please help lol
Old 03-21-2015, 02:21 AM   #54 (permalink)
Originally Posted by yoyoek1 View Post
I'm rating 5/5 for Scorpion HKII-2206-5300KV
you need to convert power source from 11.1v to 7.4v my config is rihno 1050mAh 2s (7.4v) 40C
it really have power!
http://www.ebay.com/itm/Scorpion-HK-...item1e8b384bc3
Has anyone seen or heard of this motor yet ?
Old 03-21-2015, 04:45 AM   #55 (permalink)
That's the motor I was considering for 4s.
Lee Griffiths
Old 03-21-2015, 02:24 PM   #56 (permalink)
I search:
scorpion 3900
scorpion 3600
Thx all!
To determine the power, you would have to get a motor with the highest watts, the higher the watts the higher the power. But don't forget the weight of your heli. It's the same principle as a car, power to weight ratio. There's a lot of motors with high wattages. I've got the 3900kv scorpion(150 watts), it's good enough, but I also have a 220 watts motor, both on 3S. There are motors out there that can go upto 350 watts, but they tend to be more on the piggy side. Find the motor with the highest watts, without compromising the weight.
Just a guy, tryin to Fly
gimbleguy is offline        Reply With Quote Quick reply to this message
Old 03-21-2015, 03:47 PM   #57 (permalink)
Brandon,
I replied to your post in my Visitor Messages and also sent you a PM with some info that may help.
This is what I know ;
Scorpion did produce a HK2208-series motor for the Gaui 200 and I believe this was prior-to the newer 2206-series that work well in the T-Rex 250-series of Helis.
The 2208-series that was for the Gaui was a 2S designated motor (I want to say it was 4100kv. (?)) but I do know of (1) HF-Member (snjbird) that was running his on 3S and it was extremely-powerful (and still a Flybar'd set-up).
To the best-of my knowledge the motor you have pictured is for an Align T-Rex 450 (?) as I see that there are more available pinions for that application.
I did send you the link for the Xtreme Production 14T. pinion (highest tooth-count that I know-of for a 3.17mm shaft)
As far as the "Most-Powerful" I do see that there have been a few-posts to help with this (wattage and pwr-to weight) and I'm thinking that there are quite-a-few more options to go with now then there were when I originally-purchased my first HK2206-3900kv. Scorp.
I will probably try to find another HK2208-4100kv. (like snjbird's set-up) at some point and go with very-strong C-rated (860mAh) packs.
Either-way I have found that my KonTroniks Mini-Jazz 20A esc has worked flawlessly.
T-Rex 250CF MiniCopter Joker V1 Mikado Logo 600 3D VBAR Henseleit TDR RIGID
Futaba 14SGH FASST / FASSTest
HilliHeli is offline        Reply With Quote Quick reply to this message
Old 06-12-2015, 10:24 AM   #58 (permalink)
Has anyone tried the Lynx Heli motor in the trex 250?
http://www.lynxheli.com/product_info...ducts_id=23584
Also was the result the align stock motor was best for the trex 250 dfc?
mrfred is offline        Reply With Quote Quick reply to this message
Old 06-13-2015, 06:54 PM   #59 (permalink)
This is original designed for 300, not 250. Mounting maybe an issue ....
Nano CPx, Hirobo Quark
250 SE, Pro Upper Frame, Talon25, KDE, KST215, DS95i, Mini Vbar
450 Pro (6s), KDE, Lynx, Tarot, RJX, YEP40, KST215 & 515, SK540
465 (6s), Align DFC, HW50AV3, KST315 & 8910A+, SK720BE
lcc014 is offline        Reply With Quote Quick reply to this message
