Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 09-25-2011, 02:08 PM   #41 (permalink)
HSC
Well after 14 days of accident today was the day !
Ewerythig works flawesly thanx to my mod, I ges there will be no more gears striping on my TDR, at least on first stage.
Ewerything runs much cooler than before ( I ges the belt take a lot of temparature too alu puley )
Regards
A je to ?
HSC is offline        Reply With Quote Quick reply to this message
Old 09-25-2011, 02:13 PM   #42 (permalink)
So did you use a pinion/belt/main gear combo from another heli?
Tapatalk on iPad
ElectricSheep is offline        Reply With Quote Quick reply to this message
Old 09-25-2011, 04:09 PM   #43 (permalink)
Cool, looks good, some more pics and details please. I guess it was custom made?
helicraze is offline        Reply With Quote Quick reply to this message
Old 09-27-2011, 11:56 PM   #44 (permalink)
HSC
Hello !
NO, this are not the parts of some other heli
This is full customization wich I designed and made it by my selve.
The belt is typ HTD 3M 14mm wide ( high torque drive ), the puleys and the motor trager are from 7075 AL grade.
The hole sistem is havier from the standard gears fo 20 Grams
Hear is some more pics :
Regards
ID:	256665   Click image for larger version
ID:	256666   Click image for larger version
ID:	256667   Click image for larger version
A je to ?
Old 09-27-2011, 11:59 PM   #45 (permalink)
HSC
Some more pics
ID:	256669   Click image for larger version
ID:	256670   Click image for larger version
ID:	256671   Click image for larger version
A je to ?
Old 09-28-2011, 12:45 AM   #46 (permalink)
WOW nice job, are you selling them? Do you think it can handle more power? What about gearing changes?
Old 09-28-2011, 01:43 AM   #47 (permalink)
I would be interested in trying this out. Great concept.
It works really well on my Voodoo, and I am guessing it would work well on a TDR too.
Edvard R is offline        Reply With Quote Quick reply to this message
Old 09-28-2011, 04:26 AM   #48 (permalink)
HSC
Hello !
Much, much more Power and load than delrin spiral gears !
The belt can take 2000N of load before breakink ( datasheet) and I have alsoo make some test on the pulley and it seems puley can take 100000N before plastic deformation, the picture wich is attached is calculated on 200000N.
Ewerything seems too run silenter and there is one positive ( side efect... I must admit ), the belt takes prety much temparature from motor pulley, this temparature transfer thrue the belt to the bigger pulley wich have holes inside............because the biger pulley rotates too it cools down automaticly.....so the hole sistem runs cca 15 deg cooler, wich is good on TDR where is cooking tempatature unter the canopy.
Regards
A je to ?
Old 09-28-2011, 04:30 AM   #49 (permalink)
Nice work HSC. Great to see so many different minds hard at work developing novel improvements to a great heli.
Mehari is offline        Reply With Quote Quick reply to this message
Old 09-28-2011, 04:53 AM   #50 (permalink)
Default I too would like to try this
Excellent work!
TDR, Srimok N x 2, Banshee 31, Dune!
jhunter is offline        Reply With Quote Quick reply to this message
Old 09-28-2011, 11:45 AM   #51 (permalink)
very good work !!
would be nice to know how much will be the cost of this solution
thank you
my Prôtos twins & Acrobat Shark
urgno is offline        Reply With Quote Quick reply to this message
Old 09-29-2011, 09:11 PM   #52 (permalink)
+1 -- I'd like to try it out!
Old 09-29-2011, 10:34 PM   #53 (permalink)
HSC and I are working on getting these quoted in Taiwan. Stay tuned.
Old 09-29-2011, 11:18 PM   #54 (permalink)
heck with a gear system like that i may have to invest in a tdr very nice work, any way I can convince you to make something like that for the 700e?
TRex-800E /Scorp 5035-478 5+5YY 1.8mm/VBar Blue Full 5.2Pro /CC Hv160/WR-Herc Super BEC/RJX 810mm 3D /RotoTech 115 + QuickUk Tail/ Hitec 7940th HV/TP 5000 65c
f22warzone is offline        Reply With Quote Quick reply to this message
Old 09-30-2011, 02:12 AM   #55 (permalink)
Wow! Probably the best upgrade one could ever do on a TDR! I would definitely get one should this become available. Pretty sure some other UK pilots would want this too.
G
iPhone & Tapatalk
TDR3DRigid Mikado V-Bar 5.1
Futaba8FG S-Bus
g-bru is offline        Reply With Quote Quick reply to this message
Old 09-30-2011, 05:46 AM   #56 (permalink)
Subscribed!
Heli G is offline        Reply With Quote Quick reply to this message
Old 09-30-2011, 06:08 AM   #57 (permalink)
Curious to know a few things:
Is the belt a commonly available belt that was originally produced for something else or is it custom as well?
What would the gear ratio of this set-up be?
Is the motor pinion custom as well?
Will different pinions be available to accomodate different kv set-ups?
While I don't have my TDR yet, I am still very interested in this drive system but, with the TDR already being a somewhat "custom" heli, in that parts are only available thru Jan in Germany, the thought of having a "super custom" drive system that may or may not have a limited production run has me kinda nervous about future availability.
I guess one could just buy a couple set-ups so that they would have spares.
Great work HSC and thanks Edvard for putting in the "leg work" to try to get these produced!
J.
700LE Vbar-YS91SR, SB-19 / 700LE Beastx-OS91HZ non-pumped, SB-20 / Henseleit TDR-Vbar, Jive 120/Pyro 700-52, 8917/9188 / Logo 600 SE-Vbar, 12s, 4035-3Y, Jive 120HV / Logo 600 3D-Vbar, 12s, 4030-3Y, Jive 80HV / Compass 3D+-Beastx, YS56, Outrage H56
jstarks is offline        Reply With Quote Quick reply to this message
Old 09-30-2011, 06:27 AM   #58 (permalink)
I was thinking the same, i think 90 percent or more users would have no issues with stock gear
Old 09-30-2011, 06:54 AM   #59 (permalink)
So we just had a helifreak user sit down and design a improvment over the TDR design, rumored to be the best engineered helicopter in the world? Seems most think they are amoung the very best designed helicopters in the world, and I'm slightly worried that suchs a important issue exsists, and that it takes a helifreak user to sort it.
felborn is offline        Reply With Quote Quick reply to this message
Old 09-30-2011, 07:24 AM   #60 (permalink)
Don't think anybody "needs" this, but it is amazingly cool nonetheless. One of those things that are just bling-bling and great function at the same time.
Again, I really like this system on my Voodoo, and I look forward to trying it out on a TDR too. HSC did a great job on this.
