Old 10-29-2010, 06:27 PM   #1 (permalink)
Default Spektrum users - Which mode should I run? READ!
Edited since the playing field has changed:
If you run DSM2 satellites
- Run Spektrum Satellites 1 or 2 Digital Center in the VBar (will be 22ms/1024)
If you run DSMX satellites with a DSM2 radio
- Run Spektrum Satellites 1 or 2 High Resolution in the Vbar (will be 11 or 22ms/2048)
(or you can same as DSM2 satellites)
If you run DSMX satellites with a DSMX radio (DX8)
- Run Spektrum DSMX satellites 1 or 2 in the VBar (11ms/2048 with DX8)
http://heli.dacsa.net
Old 10-29-2010, 11:09 PM   #2 (permalink)
Does the setup default to lowres mode? I'm running a 9303, but I'm not sure what mode I'm running. I don't remember specifically enabling a highres more...
-David
Trex500 sk360 | Logo400 vbar | Logo500 vbar | logo 600se vbar | Synergy N9 sk360 | E-Aurora vbar | Mini Protos beastX | mcpX
whaleboy is offline        Reply With Quote Quick reply to this message
Old 10-29-2010, 11:14 PM   #3 (permalink)
Do you have any idea how this may affect the Total-G FBL unit. Can you further explain the 9303 bug?
MXRACERX43 is offline        Reply With Quote Quick reply to this message
Old 10-29-2010, 11:23 PM   #4 (permalink)
That's a little more info here http://www.vstabi.info/forum/read.php?26,51050
Old 10-30-2010, 10:33 AM   #5 (permalink)
The problem has also been evident with Hi-Res modes and the JR 11x with my own setups. I believe the transmission protocal between the JR series radios for 2048 resolution is the same.
-- KDE Direct, Inc. --
KDE Direct is offline        Reply With Quote Quick reply to this message
Old 10-30-2010, 12:27 PM   #6 (permalink)
How do I switch back to LowRes? There doesn't appear to be any instructions on vstabi.
vbar T700E v2 DFC head, Pyro 700-45L, Jive 120HV, BLS451/BLS251, Edge 693/115
vbar CF Protos Scorp 3026-880kv, Ice lite 75, 9650/BLS251, SAB 430/KBDD 82
terrabit is offline        Reply With Quote Quick reply to this message
Old 10-30-2010, 01:05 PM   #7 (permalink)
Download latest version, in the Bind screen (Receiver) there is Spektrum Satellites, that's lowres (other is specified as hires)
Old 10-30-2010, 04:15 PM   #8 (permalink)
Got it. Thanks!
Old 10-30-2010, 08:06 PM   #9 (permalink)
After 20 hours straight testing, this has been expanded to all Spektrum users.
I have edited the first post and added the official word from www.vstabi.info
Old 10-31-2010, 09:17 PM   #10 (permalink)
Is it safe to run hires mode if you're only using one satellite?
gravydrive is offline        Reply With Quote Quick reply to this message
Old 11-01-2010, 12:32 AM   #11 (permalink)
No not at all, thats even worse than running 2
Old 11-01-2010, 09:48 AM   #12 (permalink)
But, for a different reason. Shadowing is an issue with a single satellite, especially when CF frames are involved.
HeliFreak Support
Graupner MZ-32
Old 11-01-2010, 09:53 AM   #13 (permalink)
That too, but for the same reason as above, when you hit this "bad data transmission" using one satellite could mean 99% packet loss (managed that in a test)
Old 11-01-2010, 10:15 AM   #14 (permalink)
I though you had said that it only came into play with two satellites. This story just keeps getting curiouser and curiouser.
HeliFreak Support
Graupner MZ-32
Old 11-01-2010, 10:52 AM   #15 (permalink)
Then I wrote it unclear,
Lets say it happens 1% of the time with two satellites, it might happen 10% of the time with one satellite (just relative numbers from my testing, does not mean you will see it 1% in your environment)
Old 11-02-2010, 04:16 AM   #16 (permalink)
is it a VBAR internal receiver thing or a Spektrum thing?
I'm using the full size VBAR and a seperate Spektrum reciever.
I suppose I'm fine, but confirmation would be nice :-)
wrobijns is offline        Reply With Quote Quick reply to this message
Old 11-02-2010, 04:35 AM   #17 (permalink)
Depends on what receiver and how many total receivers (internal plus satellites)
Old 11-02-2010, 07:27 AM   #18 (permalink)
Spektrum DX8
AR8000 receiver
one satelite
Black full-sized VBAR (no internal receiver)
Old 11-07-2010, 12:55 AM   #19 (permalink)
Happened with my 12X today. Periodic brief uncommanded control inputs. Usually goes away if I reboot the Heli.
Switched to lo res and issue gone.
Robbie
rchaas is offline        Reply With Quote Quick reply to this message
Old 11-07-2010, 12:59 AM   #20 (permalink)
Rebooting the heli is not really the fix, rebooting the TX is.
Sometimes it looks like rebooting the heli does it but thats just coincidence
