| 130X Blade 130X Helicopters Information and Help |
Struggling with setup on transmitter JR9503, Heli is doing a 360-while spooling up and was tipping over to the left. Looking for help to get blade in air. Binding works fine to transmitter. Please help! Thanks
My HF Map location Join Date: Jul 2007
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
Did you start with a clean model in the transmitter? How were you spooling up? If you try to use a normal collective stick spool-up, the heli's tail will kick around unless you do it very slowly; if you use throttle hold and an idle-up throttle curve, the spool-up will be slow when you flip out of TH (soft start built into the ESC). In addition, the heli will act a little screwy while it's on the ground, so your best bet is to get it off the ground as quickly as possible.
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Nankin Hobby Field Rep, Compass Support Team Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX Experience is something you obtain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
#3 |
I have a 9303. I started with a clean model and followed the DX7 setup. I had no problems. Maybe I got lucky.
#4 |
I follow the dx8 set up becuz its closer to the jr9503 than the dx7.
Be blessed Isaac Sent from my A100 using Tapatalk 2
Jesus Rep all over, Team Outrage USA Rep Orange Power To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. O Fusion 50, BL mcpx ultra, 700e, trex 450 pro all FBL 3g, vbar 5.1(blk), 3g, kds ebar GOD BLESS |
#5 |
#6 |
I have the 9503 airplane version (its what I had) and did the same as tnt, followed the dx8. I overwrote my mcpx settings and rebound to the 130 and am having no issues.
Trex 700E FBL Vbar Blue, CY Rave ENV Nitro Vbar Silver, Trex 250 Pro DFC (stock for now), Blade 130X-1 stock, Blade 130X-2 Blingged, JR 9503X |
#7 |
Had a bad servo or something wrong with the swash. Got it replaced/swapped out and went down twice already...Trying night fly with 130X, I wasn't ready for that, but it was a blast. Thanks again for the support.
