mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions |
11-23-2016, 03:45 PM | #1 (permalink) |
MCPX BL Elevator Connector
Hi guys, had a crash and the elevator servo connector popped off and that little pad is missing. Does anyone knows if that leg on the servo has a function? Does it need to be soldered? I tried to trace where it goes and it seems to go nowhere?! Please let me know guys Thanks! Sent from my iPhone using Tapatalk
T-Rex 450L Dominator | T-Rex 450PRO DFC MCPX BL heavily modded | DX9... and a lot of effort and passion! |
11-24-2016, 06:44 AM | #2 (permalink) | |
Team Newb pilot All my helis and quads were lost in a tragic boating accident. |
11-26-2016, 07:33 AM | #3 (permalink) |
You talking about the servo MCU? Is there a way to solder the connector leg to a little enamelled wire and to the correspondent MCU leg? Can you please indicate which? Thanks
11-26-2016, 08:18 AM | #4 (permalink) |
I have soldered jumpers to the remaining trace in the past for a quick fix. You have to carefully, very carefully, scrape away the enamel coating from the trace with an exacto knife to expose the copper. Then it's just a matter of soldering a jumper from the leg of the connector to the copper trace.
11-26-2016, 12:22 PM | #5 (permalink) |
Hmmm thanks for your reply. What is the jumper? The little tab where the connector leg is soldered to?
Thanks again 😁 Sent from my iPhone using Tapatalk
11-27-2016, 10:58 AM | #6 (permalink) |
Something like this.
I broke the ribbon cable on my 200 QX so I ran jumper wires to replace it. The wires are solder to the connector on one side and directly to the borad on the other side.
11-27-2016, 04:01 PM | #7 (permalink) |
I see! I will try to find which pin that leg belongs to using another working board. I will let you know.
Thanks Sent from my iPhone using Tapatalk
11-29-2016, 03:30 PM | #8 (permalink) | |
I failed to find the MCU (LOL). Are you able to indicate where it is and roughly where the servos are supposed to connect to? Thanks a lot! Sent from my iPhone using Tapatalk
