Compass 7HV, 7HVU and Chronos Compass Compass 7HV, 7HVU and Chronos Model Helicopter Discussion |
06-14-2012, 08:56 PM | #1 (permalink) |
My 7HV Tail Issues: Resolved??
Ok, so I've had this persistent wag since my initial maiden, and fighting it ever since. Mind you, this is the first time I've really had any time at all to work on my own stuff, in a long time .... so ....
At first, it was a real hard twitch every few seconds I had the gain down to 5% on my SK720 and it was still acting up ... hmm ... I checked continuity from the tail case to the motor - that was good. I checked tail assembly to make sure it wasn't binding - that was good. I checked for any binding in the drive mechanism - that was good. Bizarre. It seemed to happen after the governor took over on spool up, but then continued the hard twitch after landing with no throttle. I swapped the SK720 with another that I had in stock and uploaded my settings from the original unit. I took it to my back yard and spooled it up .... whaddya know?? No more hard twitch. Just a normal wag now. I had this unit on another machine that I hadn't flown (I built it and a friend wanted it so I sold it to him with out the SK720). I guess it was bad from the get go. Well, again even with the new unit, I was down to 5% gain and it was still wagging. WTF right?!! I checked the flight playback logs, voltage at the servo bus was nice and flat with no spikes, the vibrations were on average (almost a flat line) of less than 0.80 (holy crap that super low?!!! VERY impressive how smooth this bird runs!) I was absolutely baffled, so I brought it inside and plunked it on the bench. I took the tail grips apart just to be sure I hadn't assembled the bearings wrong. Nope. Everything was together properly, so I put a little grease on the thrust bearings since they seemed a little on the dry side and put it all back together. That's as far as I got last night. I also have a second rod guide holder on the tail boom. Ooops. It was loose, forgot the screws in it ... I'll adjust it tomorrow. It was riding about 6-8 inches from the frame, so I pushed it back about 14" from the frame thinking nothing of it. Today, I got home and plugged the helicopter into the computer. I turned off the governor mode, saved, and head out to the back yard to test out a theory that the governor and esc were not playing nicely and causing the tail wag. I plugged everything in and spooled up (man I love how smooth this helicopter spools) and lifted off the ground. No tail wag and at 50% gain! I bumped it up to 68% where I finally encountered a hint of oscillation, so I backed it down the 64% and tested it out - all worked great! I spooled down and took it back inside where I plugged it back into the computer to enable the governor again. I wanted to be sure it was the governor and try to replicate the problem again so that I could give the feedback / data to Art @ Skookum to see if he might know the issue. I enabled the SK-720 governor again and headed outside. I spooled up - everything good - governor mode kicked in - still good .... lift off .... tail holding. What the ... Tail gain at 64% still and tail is holding solid despite flying in 30kph winds with gusts over 42kph ... not the best day for testing (or is it?? ) ... I landed the beast and checked everything over in disbelief, then spooled up again and took off. Tail holding solid. Did a bunch of hard rudder movements in both directions and the tail stopped perfectly with no bounce or rebound. I don't know what solved my tail issue, but I suspect it was one of two things, or a combination of both: 1. The second tail rod guide, I still haven't tightened it up, but it is still about 14" from the frame. I can't help but think this was the cause and binding. 2. Maybe something was sticking in the tail grip bearing assembly and taking it apart for inspection resolved it unknowingly. Either way, I'm very happy now ... flight without a governor feels so touchy in comparison to flying with one. I figured I'd post this in case someone has a similar problem and might find some ideas to solve their own tail issues. Here's my vibration log from my last hover ... I still can't get over how low it is!! You can see where I landed to look things over in disbelief and then spool up again. For those wondering, I'm governed at 1950RPM. |
06-14-2012, 09:53 PM | #2 (permalink) |
I really want to build one of these, but I have to be honest - the tail has me worried. I can't stand a tail that isn't rock solid. Seems like a weak point on an otherwise stellarly designed heli.
06-14-2012, 10:00 PM | #3 (permalink) |
Jeff,
Outstanding, glad you got it resolved, sir! NRPY, I have never had a tail problem on any Compass machine, including the 7HV. I helped diagnose one that had a tail wag, via remote control (phone conversation). The person was very sharp and had tried everything. I asked them to turn off the governor (this was not a Skookum governor, by the way) and the tail was fine with the governor shut down. Same thing with a local friends Trex 500. He could not get rid of the wag. He shut off the governor (again, not a Skookum governor), and it was fine (so he has to tweak his governor setup). Governor issues can cause tail wag in a variety of machines. I would always set the ship up without the governor first, make sure it is solid, then turn the governor on. If it wags only after arming the governor, the governor is not set up right, but you know the tail was correct (as it flew fine without the governor). There is also a newer version of the 7HV tail coming out, to make it even better than it already is!
KBDD-Team Captain, JR DFA Team Pilot. Forza 450, Forza 600N, Forza 700, Compass 6HV-U, Warp, 7HV,Knight Pro,Knight 3D, Atom, Odin II, 6HV, 3D Plus, Knight 50, Chronos, Velos, Steam 550 and 600, OMP M2 (and anything else I can get my hands on...). |
06-14-2012, 10:24 PM | #4 (permalink) | |
My issue was a little different as it was initially caused by a bad gyro (hard twitching). I highly suspect the second tail rod guide was the culprit here and causing intermittant binding, especially since it didn't have a screw to clamp it to the boom properly. The winds were 30kph gusting well over 42kph this evening and the tail held ROCK SOLID. If that isn't a test, then I don't know what is. |
06-14-2012, 10:25 PM | #5 (permalink) |
Congrats on solving your wag. I love reading tail wag success stories as they are so frustrating.
For what it's worth I had a wag on my 6hv that looked like a gain issue, twitchy. I was about to tear the tail apart, and low and behold, I pushed the tail grip link too far past the ball, which causes friction and misalignment (to your point > "some sort of binding"). Those are hard to catch on your own. But again, congrats~ |
06-15-2012, 03:46 AM | #6 (permalink) |
It's great but it sucks when you fix something and aren't sure exactly why!
BTW that graph is super smooth, don't let the TDR guys see that
Beam E4 Formerly owned - Compass 7HV - Blade mCP X V2 - Blade 400 FBL BeastX |
06-15-2012, 04:00 AM | #7 (permalink) |
Happy you got it sorted mate, this is my first 700 size heli and no problems with it, one of our clubs top flyers tested it for and he said what a lovely heli they are, made me very happy to be told this as its my first 700 size i cant say to much but i wil say im a very happy man
06-15-2012, 06:25 AM | #8 (permalink) |
Great stuff. Always bliss when you catch things like that on your machine!
The 7HV is sooo smooth and fast. About the tail, I have never had any problem with it. Holds perfect, inspires confidence to do what ever, is really fast and accurate. All stock. BeastX3+curtis 105. |
06-15-2012, 06:45 AM | #9 (permalink) |
To tuning the tail and solve some little wag problems i see this video.
He used compass bolt 06-0222 on the tail assebmly and not the pins. [ame]http://www.youtube.com/watch?v=nqJx7tbKTD4[/ame] Anyone else done this?
Compass 7HVU - SAB Goblin 700 - Logo 550SE - All with Vcontrol |
06-15-2012, 10:42 AM | #10 (permalink) | ||
Great stuff
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep |
06-15-2012, 12:44 PM | #11 (permalink) |
I have a TDR. I like it, but for all the elitist rhetoric about how well engineered it is, it doesn't look so hot when you put a vibration analyzer on it. The "inferior Chinese helicopters" I've tested are an order of magnitude smoother.
06-15-2012, 04:27 PM | #12 (permalink) |
I thought my Logo was smooth. The herringbone gear sounds so sweet.
When I took the FLYBAR off and put a Skookum 720 on it I found that it was about as smooth as a chainsaw. The tail was buzzing the boom with vibes in the high 20's and the gear/ motor interface was pretty bad It took a lot of work and parts to get the vibes low enough to use the self level feature. I flew very well w/ the vibes but that can't be good I can't wait to see what the vibes look like on my 7HV
Compass7HV,Sk720HeliJive120HV Pyro 700 52L allHV Outrage 550: Scorpion 4020-1390,CC125A ESC,WR ESC Logo 5003D Scorpion Sk720 4020-1100, Blade130X MCPX TT E-620 SE x 2: Scorpion 4025-740 200srx, nano qx JR Parkmites x 2 |
06-15-2012, 05:43 PM | #13 (permalink) | |
My logo 600 was 50 without and <100 with tails on right out the box. |
06-15-2012, 10:14 PM | #14 (permalink) | |
As a few guys already know around here, this build took about 6 months to arrive at this point ... not intentionally, it's just my time is limited with the business. That said, it did forced me to be much more methodical in my build. By far, this is one of the best looking vibrations logs I've seen on one of my helicopters. I usually get between 1.5 and 3.5. Yeah, I was hoping to get to the field finally for the first time this year tomorrow, but it looks like mother nature wants me to stay inside and work on my buddy's 3D Plus to get him in the air. It's supposed to rain all day tomorrow. What's your tail gain at on the SK720? I can't believe I'm at 64% with no wag .... Good luck! I can't wait to see your graphs too .... Also, let me know where you end up on your tail gain. |
06-16-2012, 03:24 PM | #15 (permalink) |
Jeff. I'm @ 46 in the TX gov gain @ 32
Rail tails. Outrage servo @ 8.4v I did have to reduce my tail bank left stop accel to 28 to stop bounce back. Right side default 35. Sent from my iPhone 4s using tapatalk
06-16-2012, 08:38 PM | #16 (permalink) | |
I'm running the stock 115mm tail blades, MKS HBL980 @ 8.4V and the TX gain for the tail is @ 64. When testing the other day in the high winds, there was no tail bounce in either direction ... then again, the winds were awfully high. I'll let you know how it turns out. What are you governed at now? |
06-17-2012, 03:27 AM | #17 (permalink) |
115's ? Have you retro fitted them? Thought 105's were in the kits. I decided not to use the stocks as they felt like something you would smooth out 2 PAC filler with.
Guess that's why your getting away with such a high gain! I'm now settled on 1900 2000 2100 and seem to always be at 2100 due to the high winds here. Sent from my iPhone 4s using tapatalk
06-17-2012, 10:39 AM | #18 (permalink) |
LOL!
I'll go measure them again tonight, but I'm positive the yellow stock ones I received were 115s and look suspiciously like KBDD. Right now, I'm governed 1950 across the board and it seems to be holding nicely in the high wind. I'll have to experiment a bit more. Where did you settle on your cyclic gains? |
06-17-2012, 11:13 AM | #19 (permalink) |
Mt #2 kit is newer than yours (March,12') and has 105mm Yellow Compass not KBDD's.
My #1 has same Yellow Compass 105's, bought October,11') Maybe you got a bonus throw in from Mike or something.
06-17-2012, 04:25 PM | #20 (permalink) |
My yellow Compass stock tail blades measure a touch over 110mm
I bought this kit end of last month.
