BeastX FBL System BeastX FBL Flybarless System Software and Hardware Support |
12-01-2016, 05:41 PM | #1 (permalink) |
Gov setup F G H
I am looking into trying the beastx gov electric. I am hoping someone can help me understand F G and H. Thanks!
Model Align 600L Specification Drive Gear Ratio: 1:8.42:3.85 Tail Drive Gear: 34T Autorotation Tail Drive Gear: 131T Main Drive Gear:118T Motor Drive Gear:14T Is it 8.42? F-Purple flashing? G-Purple? H-Off? I am confused by.... For helicopters with a single-stage gear drive the reduction can be calculated by dividing the number of pinion teeth from the main gear tooth count. I am not sure exactly what that means but feel like my heli is not single stage gear drive. So if its not what method is used to calculate? Thanks Shawn |
12-02-2016, 05:47 AM | #2 (permalink) |
Hi,
in fact the TRex has a single stage gear, but it doesn't matter anyway as you already know the gear ratio. (Calculate it as it says: 118 maingear divided by 14 tooth pinion = 8,42) LED colors are as follows, as you can't set .42 let's use 8.40 (please take the Quickchart to comprehend the logic behind, it's really easy you just build up the sum of all three points): F = 8 (Purple flashing) G = +0.40 (Purple solid) H = +0.00 (Led off)
best regards from Germany Stefan BEASTX r&d Team freakware.com |
12-02-2016, 06:12 AM | #3 (permalink) |
Awesome thank you very much!
03-12-2017, 07:27 AM | #4 (permalink) |
gov setup fgh
hi ,can some one point me the right way as I'm using a nitro on my 700n,the gear radio is 112=main
14 =pinon I don't no how to tell the beast what it is I need ?? thanks if you can help ,thanks if you cant |
03-12-2017, 06:45 PM | #5 (permalink) | |
In the clutch bell LED off for 1 magnet, purple flashing for 2 magnets Gear ratio 112/14= 8.0 F Purple flashing -8 G OFF - 0 H OFF - 0
Align 450Pro 3GX, 500ESP/DFC 3GX, 500L, 550 DFC MicroBeast , Velocity 50 Vbar OS55 HZ-R, D380 DFC D420, G500 Sport Microbeast, All HW V4, X5 stretch 220 Flame Emax Bullet Force V2 VTX |
