Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > JS TZ-V2 Frenzy
JS TZ-V2 Frenzy JS Models TZ-V2 Frenzy Helicopters Discussion
Old 07-15-2009, 10:28 PM   #1 (permalink)
Default Setting up the swash....
How do you guys set up the swash on the Frenzy.
This is my first ever nitro heli. I have a couple of Trex450's and have the true blood swash tool for them, but not sure where to go on this one. I could eyeball it but I am sure that will bite me in the a$$ later.
I really want to set this up right from the beginning.
Are there any links to setting up this bird? The manual is kind of vague.
Also I was wondering if a header tank is needed. I noticed that not to many people run them.
But just about every other brand heli I see is using one...
crashagain is offline        Reply With Quote Quick reply to this message
Old 07-19-2009, 12:04 PM   #2 (permalink)
The swash is setup just like any other CCPM heli unless you are setting up for 140 degree CCPM. The following instructions are for a standard 120 swash setting. If your radio does not have a 140 swash setting and you want to setup for 140 configuration then you can always use a programmable mix of elevator to pitch. This will mix out the swash plate movement up and down when using elevator.
  1. Start with cleared model memory.
  2. Set the correct swash setting in the radio depending on type you are using (120 CCPM or 140CCPM).
  3. Set the correct direction of each servo if necessary.
  4. Find the best control horn for the servos so they are at 90 degrees while all sticks are centered. Use as little sub trim as possible to get the servos centered.
  5. Adjust the links if necessary to the lengths called out in the manual to start with. Adjust servo to bell cranks so the cranks are at a perfect 90 degree orientation.
  6. Adjust the links from the bell cranks up to the swash so the swash is level using any tool you prefer. I personally like the eyeball method as I can see when it is level no problem. Note: Must be at half collective stick during this alignment and there is no need to have the head on at this point in the alignment.
  7. Adjust the endpoints of each swash servo so the swash plate is level throughout the extrema range of motion (top and bottom). The type setting you use depends on the radio you have. Do not use radio settings to level the swash plate in the center of stick travel since we already accomplished this through mechanical means.
  8. Put the head on and work your way up the rest of the links in the head so that the washout arms and mixing arms on blade grips are level when pitch reads zero degrees. Note the fly bar should be level when measuring pitch.
  9. Adjust the overall endpoint travel of the swash plate so you get the +-11 or +-12 degrees pitch. The pitch curve must be linear when making this adjustment.
I don't use a header tank since I am using a fuel magnet clunck and it works fantastic. I did try to use a header tank at first with this model but I kept having leaks in the header tank that made the engine lean out on me so I removed it in favor of the fuel magnet.
One things for sure, there is a reason for everything. You just have to find it.
Align T-Rex 600 Nitro Pro, TZ Frenzy 50, Align Hyper 50, Align GP750 + DS620, Align DS610's on cyclic, Perfect Regulator V2 running 8V, Just added 2 180 cfx's.
simusphere is offline        Reply With Quote Quick reply to this message
Old 07-19-2009, 04:27 PM   #3 (permalink)
Thanks for the reply..
I ordered the swash tool and have the head all setup now. Everything looks great, I am really impressed with this kit.
I have been noticing alot of people talking about fuel magnets, so I ordered one.
What kind of cyclic pitch should I aim for?
I plan on tossing it around in the air once I get used to it and would like it setup as tight as my 450..
Old 07-19-2009, 05:31 PM   #4 (permalink)
I have mine set for +-11.5 right now and run the head speed at 2160.
