01-18-2017, 02:12 PM | #21 (permalink) |
Also hw60a v4 have many reported problems with freewheeling and rpm sensing for brain. I am using it myself on chase 360 together with brain 2 mini without problems but I have disabled freewheling just in case after reading warnings in several forums...
01-20-2017, 04:42 PM | #22 (permalink) |
Did flight #122 today.
Keith - FrSky | OMP | KST | KC3D Protos 800X Evo | OMP: M7, M4 MAX | M4*2 | M2 EVO*2 | M1 EVO | So Many Airplanes KC3D LLC - Charge Cases, Starter Adapters, Heli Upgrades, and More |
01-20-2017, 05:43 PM | #23 (permalink) | |
V977, Gaui X3 (Brain) | Futaba 10J | Citizen 799 RCHN Listener Chat (Discord) - https://discord.gg/6SvCccC |
01-24-2017, 01:32 AM | #24 (permalink) |
I made some great progress putting it together.
The build video by enterprise hobby was very helplful. I should have it finished tommarow. I'm pretty happy with the kit. My only struggle so far was getting the main gear Jesus bolt on. It was a very tight fit. Otherwise everything is going in real easy. I like all the places to route the servo wire. Sent from my Pixel using Tapatalk |
01-24-2017, 02:45 AM | #25 (permalink) | |
V977, Align T-rex 470LM, Align T-rex 550X, Align T-rex 760X. |
01-24-2017, 09:53 AM | #26 (permalink) | |
Honestly my Mains and tails slip right in. No problem there. This is the LP kit, I'm not sure what kit you have, so I don't know if that matters. Sent from my Pixel using Tapatalk |
01-24-2017, 05:58 PM | #27 (permalink) |
+1, mine also slip right in, no problem. I have a LP kit. Everything went smoothly with the build.
Align Trex 550X (Spirit 2 FBL/Geolink), Trex 470LP (mini Brain 2 FBL), Trex 450 Pro (mini Vbar FBL), HCP100S, V977, V911, Taranis Q X7S OpenTX. |
01-25-2017, 02:33 AM | #28 (permalink) |
Delivered on my B-day 1/20/1947
I was able to finish the build up of my 470 Lm today..
Now, I jus need to get past MicroBeast set up #B.. Still won't change to next menu using my DX8.. Don't seem to know where I am doing something wrong..? I still need to plug away at it.. Many of the video setup on YouTube are all in a foreign language of German.. If I fail to figure what i am doing wrong with its Beastplus.? Then I will switch to of my trusted IKON...
Joe Moma'... |
01-25-2017, 12:05 PM | #29 (permalink) |
The changing to next menu should be done with the button on the beast. Maybe if you are more specific about what you are trying to do we could give you some more help.
SAB RAW and Kraken 700 nitro w/MKS X8, OS 105 and Hobbywing, EGODRIFT motors, T-rex 550X combo, Ikon2 all around with Jeti DS-12 (plus Oxy2 with microbrain for the backyard!) |
01-25-2017, 12:39 PM | #30 (permalink) |
You can look up how people do the ar7200 its 99% the same setup. Or go to the beastx section of the forum. Lots of info there.
01-25-2017, 04:14 PM | #31 (permalink) |
ordered the metal tail shaft today, hope to get it by next week.
Just a guy, tryin to Fly |
01-25-2017, 07:05 PM | #32 (permalink) |
I finished the swap out of my Mini VBar to a Brain1 FBL. Test hovered it in my driveway and all seem good. The HW 60A V4 seems to be working with the Brain1 ok, will know for sure when I can get out and fly it. I had problems with the HW 60A and the Mini VBar, Gov was erratic and log file in the VBar was full of "gov input contains glitches".
470LM HW Platinum Pro 60A, Brain |
01-25-2017, 11:03 PM | #33 (permalink) |
Got her all put together. This was a nice build. I think it was better then the X3 was. Like someone else commented. It was nice that the screws were already loosely fitted, it made things go really smoothly. This is my 3rd build from scratch, my other being the oxy3.
I'm just curious why they removed the support in front of the battery, it would make me feal a little better with the ESC wires being so close. Othereise, that's my only concern. This is going to be compared to my goblin 380. I'm trying to cut my repair costs down I did take a few photos of the two side by side Sent from my Pixel using Tapatalk Last edited by mattbeau; 01-26-2017 at 10:53 PM.. |
01-26-2017, 01:25 PM | #34 (permalink) | |
Looks like you are showing the weight of the Goblin 380 with battery and the 470LP without battery. If yes, I will be interested to compare the weight of both ready to fly without battery?
Team Synergy |
01-26-2017, 03:02 PM | #36 (permalink) | |
Or subtract 353 grams from the goblin Sent from my Pixel using Tapatalk |
01-26-2017, 03:06 PM | #37 (permalink) |
So the g380 is almost twice as heavy as the 470l? Looks like there is a lipo in the g380 in the 4th picture?
Citizen 242 |
01-26-2017, 03:14 PM | #38 (permalink) |
Sorry I edited my last post
01-26-2017, 03:53 PM | #39 (permalink) |
With Align 1850 6s 50C
