Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Old 02-10-2017, 07:25 PM   #1 (permalink)
Default Fes Upgrades
Hey guys I just bought a Fes Fbl edition. It already has the battery fence and new tail box, I'm wondering what would be NECESSARY upgrades.
Also what spares should I get in my first order? Any help appreciated.
Sent from my Moto G (4) using Tapatalk
kevindnyc is offline        Reply With Quote Quick reply to this message
Old 02-11-2017, 06:54 AM   #2 (permalink)
Just fly it. There are no upgrades necessary to go out and give it all you have. Tough bird you picked.
You may need a set or two TT gears if you don't get the adjustment right. Anything else would fall into bling or replacement parts due to crash damage department.
Gaui R5 Kosmik 200, Scorpion HK 4235-630
TDR (build in progress)
Raptor G4 720e xnova 4530-525 Kosmik 200
Gaui X5 Jive 100 Scorpion 910, Jeti DS-16
john2kx is offline        Reply With Quote Quick reply to this message
Old 02-11-2017, 10:00 AM   #3 (permalink)
Thank you John, much appreciated. I was really worried about the plastic boom clamp, should I replace it with metal?
Old 02-11-2017, 11:04 AM   #4 (permalink)
I bought the metal boom clamp a few years back thinking it might be a issue. The metal one is still hanging on the wall.
The only thing I would change is the weak landing braces if yours came with those.
Old 02-11-2017, 12:26 PM   #5 (permalink)
Wow that's says alot john, I had screws backing out on my trex 500 plastic clamp that's why I was worried. But I guess I'll hold off on it. Mine is coming with the ridgid skids.
Old 02-13-2017, 10:02 AM   #6 (permalink)
http://www.rcbooya.com/gaui.html
x5 is pretty tough
Main and tail gears
Boom
TT
Skid brace and skid set
Tail stab support rod clamp, plastic because sorry to say when your tail is struck it will break before it takes out additionaly the support rods. Cheap point of failure.
Main and spindle shaft
Links (ends & rod),
Assortment of bearings and screws.
I use SAB plastic servo rods, keep a few extra
Tail fin
Diabolo 700, Oxy 5 Nitro, OMP M2, Futaba
DanMcN is offline        Reply With Quote Quick reply to this message
Old 02-13-2017, 11:34 PM   #7 (permalink)
x5 is pretty tough
Main and tail gears
Boom
TT
Links (ends & rod),
Tail fin
Thank you very much for the tips. What are you referring to the sab plastic servo rods? And I read that the gaui link ends are weak should I buy the align ends?
Old 02-14-2017, 06:19 AM   #8 (permalink)
I am still operating with the stock linkage. 5 years and over 1800 flights without issue. I may try the rcb canopy mounts listed above.
Old 02-14-2017, 02:06 PM   #9 (permalink)
Guys I really appreciate the help.
Old 02-14-2017, 05:15 PM   #10 (permalink)
Kevin,
1. Have you got your motor, esc, fbl.?
2. Which pinion? Have you a head speed range in mind?
3. What kind of flying? Sport, 3D, smack?
Old 02-15-2017, 11:56 AM   #11 (permalink)
I have a fully built fes kit with the formula tail box. Stock everything except I'm adding a HW100 V3 and ikon. I'm a mild to smack pilot. From reading I am aiming for 2500+ headspeed.
The heli is not in my hands yet today or tomorrow
Old 02-20-2017, 01:54 PM   #12 (permalink)
depending on servo:
These are cheaper than servo gears.
https://www.helidirect.com/helicopte...ervo-horn.html
Old 02-21-2017, 08:39 AM   #13 (permalink)
Do those break in a crash better than the stock horns? I like horns that break
Old 02-21-2017, 10:04 AM   #14 (permalink)
drill a hole right on the words "SAB" 2-3mm weakens the arm but strong enough. vtownnick does it with the stock kst 215's and his break every time right at the arm..so that's where I got the idea for the sab ones. but with full size servos usually the plastic splines strip inside the arm.
tonys-heli is online now        Reply With Quote Quick reply to this message
Old 02-22-2017, 01:41 PM   #15 (permalink)
Arm has never broken for me but the arm to servo spline strip. Couple of crashes the link ball will pull out of the arm. Either one is better than a new servo gear set.
Old 02-22-2017, 08:58 PM   #16 (permalink)
Great tips guys I'll get a set. So I finally got and setup the heli. This thing flies fantastic stock
Old 02-24-2017, 08:13 PM   #17 (permalink)
I think there are two upgrades for the x5 that make it a lot better to fly. The Nx4 yoke lowers the head by a couple cm. With the high battery and motor it really gives the bird an aggressive feel. The second is the tail
Speed up pulley.
bgymr is offline        Reply With Quote Quick reply to this message
Old 02-24-2017, 08:30 PM   #18 (permalink)
With the x4 yoke I need the x4 linkage rods and main shaft? Am I right?
Old 03-13-2017, 06:38 PM   #19 (permalink)
Hey guys, will the Formula canopy fit the FES, or are any other upgrades needed? Don't like the FES canopy, but Formula one looks damn sexy
robi1kenobi is offline        Reply With Quote Quick reply to this message
Old 03-13-2017, 08:45 PM   #20 (permalink)
If you get the Gaui Formula canopy to replace your FES canopy the canopy comes with the special short canopy posts for the rear and you re-use the long FES posts in the front.
If you get a different brand, you may need to get the short rear canopy posts.
Agile 5.5, Logo 550sx, X5, Goblin 500, Oxy 3, Trex 450proV2, 250DFC #309
nflanagin is online now        Reply With Quote Quick reply to this message
