Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters > Fuselage Forum
Fuselage Forum Fuselage Discussion
Old 08-19-2014, 11:06 AM   #21 (permalink)
No settings just Standard setup!!
Bring it home in one piece 2 MD500E B400s/ 450 BO105/ B400 BELL 222/450 Hughes 300 / UH-1 Huey B400/A109 Belt CP/ AS350 450/ 2 Jetrangers 450s Love them All
bladerunner469 is offline        Reply With Quote Quick reply to this message
Old 08-19-2014, 03:44 PM   #22 (permalink)
Hi Bladerunner I haven't played with programming ESC or FBL units as all of my heli's have been bnf the fbl units I slightly understand but not the esc's I thought they were all PNP so why would you need a program card thanks for all your help so far can't wait for parts to arrive
Cheers mark
Master CP devo 7E Walkera 450 DO3 Blade 4503D conv to FBL Spectrum DX6i Building 550x
and a phoenix sim
fly,crash,order parts,repair and repeat
watho 46 is offline        Reply With Quote Quick reply to this message
Old 08-20-2014, 11:31 AM   #23 (permalink)
Ok here's how I got mine setup Brake/OFF Cut off Type SOFT/CUT Cut off Voltage HIGH Start Mode VERY SOFT Timing Mode LOW Governor Mode OFF you Definitely want start mode to Be Very Soft hope this help's
Old 08-20-2014, 03:48 PM   #24 (permalink)
Fantastic will have a look at that when parts come about another 2 or so weeks yet hate waiting for parts
Thanks again
Cheers mark
and a phoenix sim
Old 08-21-2014, 11:41 AM   #25 (permalink)
Yeah that's is a Bummer!!!
Old 08-28-2014, 04:33 PM   #26 (permalink)
Hi guys
Thought I would give you an update ( but it's not good) ,got the 5 blade head , couldn't use the sharft they sent with it as to short so went with the old 4503d sharft to get the length I need to phase it correctly ,phase the all the blades at 90degress as seen in some vids and left all settings the same ,had the maiden flight flow very doughy and very slow to respond ended up in the bushes so back to the build table , I have bought a turnigy 3DH V2 flybarless system that I think I will install to help me fly this monster I have created , are there any other settings I should adjust to help control this heli any help would be greatful as I really love the look of it and I would hate for it to just collect dust on the shelf
Thanks again for any input
Cheers watho
and a phoenix sim
Old 08-29-2014, 12:11 PM   #27 (permalink)
Hey I forgot to tell you that you will have to use the B450 shaft Sorry!!! You also may have too file the Shaft down in order to get the holes to line up to bolt the Head on
Old 08-31-2014, 03:44 PM   #28 (permalink)
Hi guys all good bladerunner got that all sorted, but now I have a new problem, thought I would set the heli up with a new model in the rx so tried to bind to a new model all I got was one blink on the rx and nothing else and it has unbound itself from the original bind and I cann't get it to rebind is there a reset button on the rx or has my rx died, this build is becoming a nightmare but I'm determine to see it through,
Thanks again for any help
Cheers watho
and a phoenix sim
Old 09-01-2014, 11:26 AM   #29 (permalink)
do you mean you tried too Bind the RX to another channel in the TX ?
Old 09-01-2014, 03:38 PM   #30 (permalink)
Hi bladerunner YE tried to setup a new model in the rx so I could start from scratch and I think that killed the rx , so I gess that I'm up for a new rx for the heli I have a walker 450 with a 6 axis gyro in it and was thinking of putting that into it so at least I could get it in the air and tune the blades in , and see how it flies , if all goes well with that I will get another rx and put the turnigy 3H D flybarless unit into it
Just another journey in the life of the heli's lol
Cheers watho
and a phoenix sim
Old 09-02-2014, 11:39 AM   #31 (permalink)
Oh ok hey what kinda Blades are you running?
Old 09-03-2014, 04:55 AM   #32 (permalink)
Hi bladerunner
I'm running 325 CF blades for now ,but I think I will be looking at the plastic 5 blade set soon, I am waiting on the 13 t gear as I forgot to order it at the same time I have everything else ready to go, motor , esc and have a new rx comming , and have replaced the main shaft as I think there was a slight bend in it,I think I will have a go at settingup the FBL system while I've got it on the bench as well, hopefuly a week or so away and I'm in the air for a trial run I will keep you posted
Thanks again for you info and help
Cheers watho
and a phoenix sim
Old 09-03-2014, 11:28 AM   #33 (permalink)
I have a Question you have the Motor rite the holes for mounting that motor are larger than the holes for your stock one so you have to get larger screws
Old 09-03-2014, 03:37 PM   #34 (permalink)
Hi bladerunner ,I have not looked at setting the motor up yet but will check that out this morning
Cheers watho
and a phoenix sim
Old 09-04-2014, 10:59 AM   #35 (permalink)
I know you will need different Screw's I had to go too my LHS sorry I don't remember the size of Screw You probably would have to take it with you too get the rite size that's what I did.
Old 09-10-2014, 07:01 AM   #36 (permalink)
Hi bladerunner
All good the bolts out of the old motor fit but found that the ESC I ordered dosen't have an internal BEC so I have to order a BEC I was wondering if the turnigy FBL unit will work with this setup, I'm not sure if there is an phasing in the unit or if it can all be done manuelly ??
Watho
and a phoenix sim
Old 09-10-2014, 02:52 PM   #37 (permalink)
I can't help you there I do not use any FBL's Units Before!!!
Old 09-10-2014, 03:34 PM   #38 (permalink)
Thanks bladerunner
I will endeavor to keep searching to get this project finished
Thanks again for all your help and will keep you posted
Watho
and a phoenix sim
Old 09-11-2014, 11:19 AM   #39 (permalink)
looking forward to seeing it competed!!!
