Like Tree1Likes
Old 01-27-2012, 01:57 PM   #41 (permalink)
Great vids ! as always
maybe something worth mentioning in step J and K is the position of the head important ?
like 90 degree from the boom ?
DIABOLO - Spirit
goblin 500 Sport-- Spirit
joliecoeur13 is offline        Reply With Quote Quick reply to this message
Old 01-27-2012, 08:16 PM   #42 (permalink)
For step J the blades should be parallel to the boom. For K the position doesn't matter. If you have done the previous steps correctly, the min and max pitch degrees should be the same regardless of head position.
Gaui 200 •Gaui 550 •Gaui X5
BeastX Castle Scorpion Hyperion Spektrum JR
The Front Porch, Nexgens Lounge
nexgen is offline        Reply With Quote Quick reply to this message
Old 01-30-2012, 11:26 AM   #43 (permalink)
Just to say to Helico-pteron thanks for the thread and to Nex for the great videos. Just got one of those new Spektrum Receiver/Beast combos and it helped me understand the setup a lot - its the same basically - you just get a built in 7 channel Spektrum DSMX receiver too. Cheers guys
I always wanted to fly a model helicopter - I still do!
Trex 250SE - Trex 500ESP FBL - Trex 500 - Trex600ESP FBL-Trex700E F3C
Cobham is offline        Reply With Quote Quick reply to this message
Old 02-01-2012, 07:39 AM   #44 (permalink)
Hey Rob,
Just went through the videos last night. Thanks so much for this great resource. Setup makes so much more sense now that you have explained it. You even answered my question about skipping through the setup points in your final video - absolutely perfect!
- Sean
TREX 250 DFC, 450 PRO, 500 DFC, 600e PRO, 600 Nitro
Sean_M is offline        Reply With Quote Quick reply to this message
Old 02-02-2012, 08:44 AM   #45 (permalink)
nexgen amazing tutorials as always you are such a great ambassador to this wonderful hobby!
________________
Naked & Afraid
whippo is offline        Reply With Quote Quick reply to this message
Old 02-09-2012, 07:38 AM   #46 (permalink)
Thumbs up
Great tutorial video Nexgen, i'd definitely learn quite alot from watching your video a few times and getting it setup on my Trex500 EFL Pro.
Sabre22 is offline        Reply With Quote Quick reply to this message
Old 02-11-2012, 08:39 PM   #47 (permalink)
Im glad you find them useful. It was fun making them
Old 04-16-2012, 11:04 PM   #48 (permalink)
These are perfect.... I am such a visual learner..... I set up my 3G using YouTube videos and tomorrow I'll be setting up my beastx on my 450 sport tomorrow..... Thanks Nexgen sutty and others.....
Geoff
GOBLIN 500 BRAIN FBL, [COLOR=lime]BLADE 450X, [/COLOR TREX 600 EFL, MCPX BL, TREX 450 PRO , PROTOS 500, MQX,
Flyboy76 is offline        Reply With Quote Quick reply to this message
Old 07-18-2012, 01:27 AM   #49 (permalink)
JS
Excellent videos Nexgen and Ivan!
As a curious noob, these were done on V2 correct? Is there anything majorly different in V3 that warrants updated videos?
promulgate
JS is offline        Reply With Quote Quick reply to this message
Old 10-12-2012, 08:10 AM   #50 (permalink)
On step G, toward the end where you are setting zero pitch with a screwdriver or long rod, are you just eyeballing the screwdiver next to the shaft? I know a lot of people use a gauge here, but I like the idea of setting zero pitch relative to the shaft this way because it's very quick and easy. Is the accuracy ok using this method?
steveap1 is offline        Reply With Quote Quick reply to this message
Old 10-12-2012, 08:34 AM   #51 (permalink)
Member
I sometimes use a long allen wrench and eyeball it down the middle of the shaft. It's very easy to tell if there is pitch in either direction.
Old 07-22-2013, 11:02 PM   #52 (permalink)
when you setup your beastx v2 do you set it up in idle up with 0 pitch like you would do flybarred? seems like you would have to to set your full positive and negative pitch.
TREX 450 , V911, MCPX V2 ,dx6i hk450 hb800 fbl
tmepae is offline        Reply With Quote Quick reply to this message
Old 07-23-2013, 07:11 AM   #53 (permalink)
Default Re: Individual Menu Set Up Videos
Yes, but the mb takes care of 0° for you so you don't have to mess with your pitch curve to find 0° :-)
Old 11-17-2013, 08:55 PM   #54 (permalink)
Default FBL noob appreciation
...this is awesome! On behalf of FBL noobs everywhere, thank you!
ihunsche is offline        Reply With Quote Quick reply to this message
Old 11-17-2013, 11:27 PM   #55 (permalink)
No prob this kinda stuff is always relevant. After a brief hiatus, I am back in the heli dungeon, and it is nice to revisit some of this as a refresher.
Old 12-15-2013, 04:54 PM   #56 (permalink)
Default Micro beast problems giving Migraine
I understand that its very easy for some of you to do the basics like wire installation into the futaba receiver,But I bought my goblin used with a beast x and it did not come with a manuel,And im fairly new to flybarless helis.I believe that I hooked all the wires up right but when I hold the botton down for over three seconds to start going through the process,It does not come up to A? Im lost, I know my rec. is bound cause I can spool up my scorpion motor.
This Micro beast was used by a previous owner with specktrum and I want to erase everything on it and start fresh.I read that if you hold down the botton for over 10 seconds then it would delete all previous settings but this seems to do nothing
Any help would be greatly appreciated and be patient because this is my first flybarless,Well second because I tried hooking up the
hc3sx and I got half way through and gave up.I want to learn the MB before I attempt my hellicommand.So basically im wondering how to troubleshot and see if I have my wires hooked up right and figure out how to get to point A and I believe I can figure it out from there.Thanks
Youngbuck is offline        Reply With Quote Quick reply to this message
Old 09-16-2015, 07:25 PM   #57 (permalink)
Default any vids on before beast x
like how to setup you spektrum radio before you start
cruzroy is offline        Reply With Quote Quick reply to this message
