Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600 PRO Class Electric Helicopters
600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 06-12-2013, 10:51 PM   #1 (permalink)
Default Align 600MX Motor Case to Motor Shaft Contiuity???
I have two RCM-BL600MX motors.
One motor has an electrical short, from case to shaft, and the other motor has an electrical open, from case to shaft.
Can someone tell me what the continuity between the Motor Case and Motor Shaft should be?
When the wife asks "How many helicopters do you need?"
The answer is always "Just one more!"
BlackTitanium is offline        Reply With Quote Quick reply to this message
Old 06-13-2013, 08:35 AM   #2 (permalink)
Default Re: Align 600MX Motor Case to Motor Shaft Contiuity???
I think it is normal to show continuity between the motor case and motor shaft. What you dont want is continuity between any of the three motor wires and the shaft. Check all three and if it is shows 0 continuity then it is alright, if it shows continuity then there is a short in the motor and needs repair.
Btw mine also shows continuity between the motor shaft and motor case.
Sent from my HTC Sensation XE using Tapatalk 4
Andreas M.
Compass 7HVU
Logo 600SX V2
Blade 450X
Heli.Maniac is offline        Reply With Quote Quick reply to this message
Old 06-13-2013, 12:21 PM   #3 (permalink)
Thanks for the reply!
There is no continuity between the motor wires and the motor shaft.
Looks like the motor, with no shaft/case continuity is bad.
Here's a little background, on that motor, as to why I'm inspecting them:
Two weekends ago, while attempting an Auto Bailout, the motor failed to spool up.
The Heli landed in some tail grass, no crash damage.
While the Heli was still powered, I sat it down, I cycled the throttle hold switch.
The motor still failed to respond. I inspected all the electrical connections and found nothing wrong.
It was my last flight pack for the day, and I did not fly again until the next weekend.
When I went to fly the Heli again, upon plugging in the flight pack, the ESC let out the magic smoke.
So, either the motor caused the ESC to Short, or the ESC shorting out damaged the motor.
Old 06-13-2013, 02:22 PM   #4 (permalink)
If it is a Castle, that is something to look at... bad reputation you know what I mean
But I had a similar case with mine where it failed to start or it would start-stop after 2 seconds and repeat. Went to disconnect the motor wires only to find that minor pulling revieled broken motor wires. The motor cables are basically an extension of the windings, which means that they are fragile. I would sugest to inspect the cables carefully (the insulation on them is really loose and comes back to original shape if you pull it back).
Also some reading for you: http://www.justgofly.com/techfaq.htm#MotorShort
Andreas M.
Compass 7HVU
Logo 600SX V2
Blade 450X
