Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > SR
SR Blade Helicopters (eFlite) SR
Old 01-01-2012, 05:48 PM   #521 (permalink)
Didn't get a chance to fly today because of nasty weather but I did get a few packs in yesterday. It was a nice warm calm day and the SR was really dialed in, had a lot of fun! Today I installed my bling parts and I'm really happy with the fit and finish. I have read about people having trouble with loose fitting center hubs on the main shaft....etc, but mine was a real nice fit. In fact I had to turn the hub back and forth on the main shaft to get it in place, nice slip fit. Everything seems to be real smooth and tight, can't wait to get it set up and spool her up for a test hover.
UPDATE: just finished a test hover (in our breezeway) to check blade tracking after setting up the new MH head. I was pleased to finally be able to check the pitch range and not have a few degrees of slop to contend with. Got her set to +/- 10* on collective and 7* on cyclic so things are looking good. It looked like the head has enough room to go another few degrees or more on collective but i think 10* is more than enough for me.I was shocked when I first checked the cyclic, it was 13* when I started, must be with the tighter head parts it was a lot higher than before. Blade tracking was dead on and it was SOOO smooth and quiet, like a totally different heli!!
ID:	277454   Click image for larger version
ID:	277455   Click image for larger version
Beam E4-(Scorpion HK-2221-6,11T pinion, Phoenix 60, HS65MG cyclics, GY520),120SR, Trex 250SE (stock) MH bottom plate,GY-520,Futaba R6106, MCPx,DX7se,Futaba 8FG Super, HPI Vorza on Futaba 4PL.Honda HS928K1TA
olemil is offline        Reply With Quote Quick reply to this message
Old 01-01-2012, 07:36 PM   #522 (permalink)
i decided i was going to sell it and get a trex 450
scottevilSR is offline        Reply With Quote Quick reply to this message
Old 01-02-2012, 11:38 AM   #523 (permalink)
looks SUPER nice! Thats planned for mine but i need to space my unscheduled landing out a bit further first
Duckblind is offline        Reply With Quote Quick reply to this message
Old 01-09-2012, 10:49 AM   #524 (permalink)
Thanks /\ /\. Just came in from doing a test flight after replacing my tail motor. First motor all summer and had 71 flights on it, not too bad. Hopefully this one will hold up as long as the other one did, but I better get another spare on hand just in case.... This was the first time I've flown it outside after upgrading the head with all the MH parts, seems real tight and much more responsive.
Old 01-09-2012, 11:07 AM   #525 (permalink)
I flew mine yesterday for the first time since getting my McpX and what an eye opener. the SR takes a lot more work to maintain a steady hover and this was with very little breeze (just a hint). I fly the McpX in my shop with a ceiling fan on (blowing down) and the furnace running which blows down from the ceiling but at an angle. This simulates a fair amount of wind which is a great training tool. I will have to get my SR out more often so I don't lose my edge.
B400 - HS65MG, GY401, JR DS3500G, Align 35a ESC, Sonic CNC tail
SR - 10T pinon, T450 skids, extreme orange blades
MCpX stock, my SIM
sanddan52 is offline        Reply With Quote Quick reply to this message
Old 01-09-2012, 12:32 PM   #526 (permalink)
Looks real tight Olemil While I keep hearing those parts bend alot, if you don't crash that shouldn't be an issue . Good that you put those in after getting super familiar with your heli. Nice job!
Danno
Blade 500x, Trex 500xt, just back after some time off. You don't ever really QUIT helis do you??
DKS_ONE is offline        Reply With Quote Quick reply to this message
Old 01-09-2012, 01:08 PM   #527 (permalink)
Thanks Danno! I too have heard about the MH stuff being soft but I've never had a problem with my swash and it has seen a few boom strikes just after putting it on. I've received a few PM's from members with the same head parts I have and they say the parts are solid in a crash, so who knows. Well like you said, don't crash and it won't be a problem. I'll go with that theory!!
Old 01-09-2012, 02:47 PM   #528 (permalink)
I've tried to follow that theory, I've had marginal success lol!
Danno
Old 01-11-2012, 08:59 PM   #529 (permalink)
I installed b400 landing gear and new blades, Carbon boom, fins and boom support. I had some test flights and everything nice. I crashed my other Bsr.
conejo is offline        Reply With Quote Quick reply to this message
Old 01-13-2012, 06:47 PM   #530 (permalink)
Conejo, the CF boom is nearly indestructible, and boom support makes it more precise in flight, nice. Must be nice to have those summer temperatures right now!
Olemil, that does look sharp, and a MH rotor head is next on my list. The most I've done lately is take an old main gear and put it on a telescope focus knob as a fine adjust....
7hvu, 6hv,,Prôtos,450Pro, DT520E
some planks
Jumna is offline        Reply With Quote Quick reply to this message
Old 01-13-2012, 10:46 PM   #531 (permalink)
Thanks Jumna, and it flys much tighter now too.. Nice job on the focus knob, can't beat joining the two hobbies, well other than $$$$$...lol. Didn't get to use my scope much this year, between working lots of weekends and flying the poor scope was on the back burner.
Old 01-15-2012, 10:51 AM   #532 (permalink)
Default Sundays project
Sundays project will consist of changing out bent main and feathering shafts and finishing the new boom and flipping the tail motor mod. My buddy just did the tail motor flip and his flies noticeably better so I'm headed to his place for some beers, football (Go Packers) and working on the SR. My neighbour has a sweet lathe setup and now straightens all my bent metal shafts for me. Saves some $ on buying new all the time. I've only had a few flights with the DX8, still looking to get it dialed in the way I like it.
Later
CrashCanuck is offline        Reply With Quote Quick reply to this message
Old 01-15-2012, 11:12 AM   #533 (permalink)
Replace head and pitch linkage.
Proceeded to have my swash completely separate 10 feet up.
Ordered a stack of new parts to include the MicroHeli swashplate.
jonjonwells is offline        Reply With Quote Quick reply to this message
Old 01-15-2012, 02:06 PM   #534 (permalink)
Money well spent, you won't have to worry about the swash separating again.
Old 01-15-2012, 10:00 PM   #535 (permalink)
I spend the majority of my time over on the 120SR page, but did try again to fly my SR. Rotor strike on the boom and tore up the landing skid. Thats two sets of blades that one has tore up the covering but blade after getting skinned still looks good. Flexed the blade looking for cracks and none appear. So, got some monocote and did a few trial and errors. Read somewhere how to do it and I think I now have two sets that are going to work. A few small ripples but hope they do not effect the performance. Will take pictures tomorrow and post them up.
Ya, I am sure that a few of your eagle eyes will note the marks on my tail boom just about an inch in front of the tail rotor. I think it will fly not that I bent it back.
Last edited by HopSkipFlop; 01-16-2012 at 08:53 PM.. Reason: Adding a photo, I hope
HopSkipFlop is offline        Reply With Quote Quick reply to this message
Old 01-16-2012, 09:40 PM   #536 (permalink)
Went to my buddies on Sunday and put in a new Main and feathering shaft as both were tweaked. Did the tail flip mod, fired a battery in it and got it hovering, my buddy made 2 small gyro adjustments and it was flying the best it ever had. Less buzz out of the tail and almost zero wag. Nice and stable and actually easy and fun just to hover and move around the garage a bit. I set it down nice and easy, give the TX to my buddy he lifts off brings it back toward us and then torpedoes it into his garage floor . Really, are you freakin kidding me. From maybe 3' up he managed to bust the frame, boom, blade grip, rotor head, flybar and one other small piece, surprisingly the main and feathering shafts are still dead straight. $40 in parts and lesson learned on letting a buddy (who owns a SR btw) fly my SR. The rebuild has started, hope it flies as well as it did, for one batt.
Old 01-16-2012, 10:30 PM   #537 (permalink)
All I can say is that this re-afirms what I have heard others say. DO NOT let anyone fly your bird, period.
Sorry to hear that you chopper was flying better than ever and then is destroyed. I also hope you can get it all back together and flying as well as before.
Old 01-19-2012, 10:41 PM   #538 (permalink)
Default up to 15
I have now put flight 14 and 15 on her today after gluing up my separated swash . Experimenting with the flight modes and the Dual rate as well as the SM TCM ADJ knob. Next flights I want to experiment with the Tail Rotor Proportional mix on the bottom of the SR. When popping the throttle the tail will drift a little and I want to get that set up better. I have the tail wag taking care of and like the way it sounds now. Having fun so far.
,SR ,mCPx, Trex 450 Pro, Sport, and SE V2, Pair of Trex 600esp's.DX7 & Dx6i. My head is set up proper. I have seen all of the videos.
TDubya is offline        Reply With Quote Quick reply to this message
Old 01-21-2012, 07:26 AM   #539 (permalink)
Crashed and burned, whats a good list of spare parts to have on hand as getting parts over here takes 2-3weeks?
LancerV is offline        Reply With Quote Quick reply to this message
Old 01-21-2012, 12:39 PM   #540 (permalink)
Im about to replace the orings and add some extra shims. As well, the flybar is lopsided by a few mm's so im going to fix that ... I'm going to tuck the motor wires up under the battery strap (as has been suggested in other threads) and start researching the tail motor flip thingie on this very forum ...
just waiting for a blade grip bolt from the mailman set and then I can fire her up, hopefully this week!
steubens is offline        Reply With Quote Quick reply to this message
